Question about Husqvarna 223L
Husqvarna Manuals throttle assembly
Rebuild the throttle housing to a 128ld
Not sure if you are asking about the throttle assembly or carb. Both of these are available as kits from Husqvarna and will save you a big headache trying to rebuild.
Oct 15, 2016 | Husqvarna 128 LD Weedeater
I installed a new after market gas tank on mi 365 huski when i start it, it runs at full throttle, with and without the throttle cable attached
Recheck your assembly...Something is either has the carburetor throttle plate held open or you have an intake air leak. Nothing to do with the tank other assembly problem.
Dec 15, 2014 | Husqvarna 362 365 371 372 Aftermarket...
How to disassemble the throttle/trigger assembly on at Husqvarna 150BT blower.
Internal or external snap rings usually require a special pair of pliers to remove. In absence, you might try a very pointed pair of needle nose pliers or even a pair of dental tools or similar. Once the ring begins to dislodge from its groove you should be able to work it out. Reinstallation might require the specific tool.
Oct 03, 2014 | Husqvarna 150BT 50CC Gas Leaf Backpack...
Installing throttle cable on Husqvarna 445 chainsaw
Try blocking the throttle arm on the carburetor in the wide-open position with a small stick, then deal with the trigger mechanism. In order to remove the cable from the carburetor, you need to remove the carburetor itself, then unhook the cable end at the throttle arm. Keep track of which fuel hose goes where if you do this. Hope this helps!
Mar 31, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a 353 with the throttle stuck on high. the throttle rod does not move when pulling the trigger. what's wrong?
Open the handle around the throttle trigger to look for part damage or jamming with sawdust. Check operation before reassembling. Hope this helps!
Feb 28, 2010 | Garden
Replacing a broken chain break
Use the IPL (exploded parts list) as a guide for repair. You can also order a complete assembly (use it as pattern for repair of the first).
The complete assembly is usually at the top of the illustration containing the clutch cover. A complete assembly for my 359 is less than $23 at Jacks Small Engine.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
I hope you found this helpful.
Lou
Jan 16, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Broke handle that includes gas tank on a 262xp husqvarna saw what # will interchange./ Jewell
This is a tank assembly for a 1990-03, it is available. $151.07 http://www.partstree.com/parts/?pn=503+49+74-01
Try to find the correct IPL here:
HusqvarnaUSA.com
06 1500198
The tank part number is listed atop the "Tank Assembly" page (Detail E on the IPL I used) HTH
Lou
Jan 09, 2010 | Husqvarna Garden
Husqvarna 365 order to install trigger, throttle catch and spring
Here's a link to the husky parts list.
http://www.usa.husqvarna.com/support_manual_search.aspx?webecsearch=10527&O=true
Mar 23, 2009 | Husqvarna Garden
Husqvarna 223L Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
