Question about Vacuums
What is the predicate in this sentence
Henry likes to watch ants
What are some personal traits about henry hudson
Henry Hudson was born in London, England in 1565 to a wealthy family. Not much is known about his early life but in 1607 he was chosen to captain a voyage to find a northern route to Asia, the first of several voyages the explorer would take before his final voyage in 1611.
Henry Hudson Facts - SoftSchools
www.softschools.com/facts/biography/henry_hudson_facts/984/
Nov 18, 2016 | Henry Vacuums
I'm getting a horrible sour/sweaty like smell blowing out of my Henry when vacuuming, i've tried to clean the filter, but its still just the same & the smell also seems to be in the head o
You can buy little sachets of nice smelly stuff to put inside Henry. Most supermarkets have them. Makes the carpets smell nice too.
Feb 07, 2013 | Henry Vacuums
Hi i have a henry vacuum which my daughter used on wood/coal ash and now does not work.
OK... You are suggesting that Henry doesn't work because of what your daughter did with him. This may or may not be fair on your daughter! Depending on the degree of filtration in your Henry, he should be able to cope with ash (as long as it wasn't hot) without difficulty. Provided that your Henry had an undamaged cloth or paper bag, and that his "top-hat" cloth filter is intact, I think it unlikely that the ash is the cause of the problem. Many people use their Henry without a bag - this is a false economy, as dust always always finds its way in to the motor and, ultimately, that's terminal. Look at the underside of Henry's motor compartment (the black part) where the air goes in, and at the exhaust where the air blows out - if it's obvious that he's been sucking or blowing dust, you probably need to replace him. However, if bag and filter are intact, you probably need to look elsewhere for the source of the problem, and the first place to look is the electric flex (particularly for damage where it enters the plug). I hope this helps - but if not, please post a comment again and we'll look further. Good luck!
Dec 14, 2009 | Numatic Henry Bagged Canister Vacuum
Numatic henry making a strange spluttering sound coming from the motor
Sounds like the carbon brushes in your motor are worn out. They can be replaced with new ones, but you may not feel like doing the job yourself. Best not to mess with electrics unless you are completely sure you know what you're doing... in which case, take Henry to a repairer. The job is simple, quick and should not be too costly.
Mar 13, 2009 | Numatic Henry Bagged Canister Vacuum
Electrical Burning Smell from Henry HVR200 Vacuum Cleaner
Hi! Highly unlikely that you need a new motor.  Highly likely that you need new carbon brushes.  The smell is caused by excessive sparking between the worn brushes and the copper commutator segments.  Most carbon brushes (and from memory I suspect this includes Henry's) have a copper wire buried in their last few millimeters, and you really need to change them before that becomes exposed.   The longer you run it like this, the more likely you are to damage the commutator, so change them sooner rather than later.  When you change the brushes, you can smooth off the commutator with very fine abrasive paper (the objective is to smooth it, not scratch it!), and then blow all the dust away (or **** it away if you have another vac, of course).  Incidentally, you don't say if you are using a paper bag in your Henry. Some people, because the top-hat filter is so good, try to manage without a bag.  This is false economy!  You should always use a bag. I hope this helps! I value feedback, so please remember to rate this response.
Feb 28, 2009 | Numatic Henry Bagged Canister Vacuum
Henry's motor burnt out
You should have 3 wires one of them are green . gr. is the ground . the other 2 are interchangable. good luck DFD
Aug 07, 2008 | Henry Numatic "" Canister Vacuum
Vacuums Logo
59 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
