Question about Acer Aspire 5733Z 15.6 Inch Laptop Intel Pentium P6200 2.13Ghz, Ram 4Gb, Hdd 500Gb, Dvdsm-Dl, Lan, Wlan, Webcam, Windows 7 Home Premium 64-Bit
Shredder64 msi error 1706 - schredder64.msi
I am having problrm of locating Shredder64.msi file its asking different location
The solution to this problem that worked for me was to download a
little program called MicrosoftFixit.ProgramInstallUninstall.Run)
You can find it here:-
http://support.microsoft.com/mats/Program_Install_and_Uninstall
This gives the option to install/uninstall Shredder64.msi I uninstalled and the right-click problem disappeared. Hope this helps! Ian.
helps you! Ian.
Jun 29, 2011 | Computers & Internet
Icannot get rid of the folliowing: Error 1706 Win DVD.
hi there,
May you provide the complete details of your player like the maker model..
`jack
May 23, 2008 | HP Televison & Video
''Error 1706''
My colleague says that when Error 1706 occurs during an attempt to install an MSI file from removable media, the first thing you should try to do is check the Media Package Pathway and determine if the pathway does in fact track to the right folder. If it does not, scan the removable media and locate the file where the MSI file is housed. In some cases, you may find that the MSI file is found in a folder that is named App1. Once you have determined where to find the right file, it is a matter of resetting the Media Package Pathway so that the system will find and activate the MSI file. This will require you to make some changes to the command line or possibly make a permanent change in the registry.
It is important to note that making changes in the command line and especially in the registry are functions that someone who is familiar with writing code and general information system functions should perform.
If you are not knowledgeable about these sorts of functions, there is every possibility that the modification will not result in resolving the issue regarding the MSI file. Further, the change may create additional problems with the media package.
May 28, 2010 | Computers & Internet
My scaner is not working . Error Scan.Msi file missing
I have reinstalled software for my HP Officejet 7310 printer and in the final stages I get a 1706 error indicating I am missing a file called "scan.msi". Any suggestions?
Sep 02, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Windows installer is looking for FAX.MSI Error 1706 I am running Windows XP Media Center
Try This:
  1. Click Start and then click Run.
  2. In the Open box, type a command line similar to the following, and then click OK new network path\Setup.exe /fvm package name.msiwhere new network path is the full path to the alternative network administrative installation, and package name is the name of the Windows Installer .msi package on the root of this administrative installation (for example, Proplus.msi).
  3. Click OK when the update is finished
Jun 30, 2009 | Computers & Internet
Problems installing ms office pro 2007
hi Error 1706 is a Microsoft error that is sometimes generated when you install a Windows package from some form of removable data. Examples of removable data would be a CD-ROM or a DVD. Typically, the exact text of Error 1706 will include the phrase "no valid source could be found."
One of the usual causes of this problem is that the Windows Installer or MSI file is not residing in the root folder of the media that is found on the removable data. This does not mean that the MSI file is not somewhere on the media -- just that it is not in the folder that your system is checking. While, in most cases, the Media Package Path would be altered to create a clear path to the MSI file.
thank you
Oct 05, 2008 | Microsoft Office Professional 2007 Full...
Error 1706 & error occured while loading savrt32.dll
They are the manual instructions but Symantec to have an automatic removal tool floating around. put the CD back in the drive (or get access to it from it's directory or whatever) then repair it as follows:
C:\> msiexec /i "D:\SAV\Symantec AntiVirus.msi"
let it go through it's dog&pony show then when it's done, uninstall it properley:
C:\> msiexec /x "D:\SAV\Symantec AntiVirus.msi" or
Download the Windows Installer Cleanup Utility package from:
http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe
Install and run. Remove the offending Symantec Install Package from the list. Wella.
Dec 10, 2007 | Symantec Norton AntiVirus 2004 - (Open...
Acer Aspire 5733Z 15.6 Inch Laptop Intel Pentium P6200 2.13Ghz, Ram 4Gb, Hdd 500Gb, Dvdsm-Dl, Lan, Wlan, Webcam, Windows 7 Home Premium 64-Bit Logo
97 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
