Question about Hampton Bay Patio Furniture. Cibola Sectional Patio Armless Club Chair
Clean water spots off hampton bay outdoor furniture cushions
Water stains left behind after cleaning
Buffalo12980
  • 625 Answers
SOURCE: I need the default code for a hampton bay fan
I checked the hampton bay site and unfortunately whatever dip switch setting on the fan is, the remote needs to be matched to it. better get out the ladder!
Posted on Sep 12, 2007
night71
  • 328 Answers
SOURCE: Hampton Bay 36" Fan Hums but won't turn
The motor has gotten tired now after being on 24/7. With the blades off, it would turn easily but the weight of the blades strain the motor. You could check that there is proper 110 volt current to the motor because anything less will cause that problem too. You can also help the fan start by spinning the blades while it is on. Short of these suggestions, it is time for a new fan.
Posted on Nov 18, 2007
SOURCE: Hampton Bay Remote
Hampton Bay Almeida 52" Ceiling Fan 52101916 ... Had fan installed remote fan would not go on ... nothing not even light ... changed batteries electrician that installed it said take it back to the store he would install another fan .. just bought fan last year HELP
Posted on Aug 04, 2008
  • 26 Answers
SOURCE: Hampton Bay 52 In. Clarington. How do I reverse the fan?
Try these two: 1) look for a small switch up near the light area on the dark-colored area of the fan. If a switch is there, then simply flip the switch to the other position; 2) if you have a remote control for the fan, the reverse mode may appear on the remote control. Hope this helps.
Posted on May 19, 2009
alex_salve
  • 78 Answers
SOURCE: How do i remove the light to change a light bulb?
turn thr glass clockwise to open.
Posted on May 25, 2009
The base of our Sunbeam Pro Steam iron has become very stained and we want to clean it. What do we use?
To clean the base (soleplate) first, make sure your iron is completely cool before cleaning.
There are a number of things to remove various stains. For general stains rub the bottom of the iron with table salt and a soft damp cloth. For marks left by limescale (a powderey white) use undiluted white vinegar on a soft cloth. Some stubborn stains can be removed with a paste made from baking soda and water. What ever you use make sure you rinse and wipe the soleplate dry before using again. Never under any circumstances use a metal scouring pad or wire wool type cleaner, this will scratch, mark, and probably damage the soleplate beyond repair.
Dec 30, 2013 | Sunbeam Irons
I cleaned the sump of my DCS 36 inch cooktop with easy off as instructed but it left a black stain on the aluminum bases. I have asked DCS for some help but it's been over a month a they don'
Youre gonna hit me... Soak it with lemon juice then clean with water. And next time you gotta clean metals, use vinegar+salt or sugar + olive
oil.
Jul 05, 2012 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Excessive water left behind and posible leak. What is the best way to trouble shoot the cause and fix the problem ?
Hi your problem is most likely the suds valve, also known as the check valve piston, if it's worn out this will cause water to be left behind. It should be located towards the back of the dishwasher. There are two flap valves that could also cause the problem one is in the main pump and the other in the check valve body which connects to your drain. As for the leak, I had a similar problem and it was leaking where the drain solenoid o-ring is located. If that's not where it is leaking, then inspect all areas where there are any hose clamps for mineral deposits then either replace the hose or tighten clamps if necessary.
Apr 07, 2012 | GE Dishwashers
How do I get the white heat stain off of my tempered glass, air tight gas furnace?
You'll need to remove the glass from the fireplace, but not before turning off the pilot light. Then mix a 50/50 solution of White Vinegar & Water. Using a sponge soaked in the solution and partially wrung out, clean the glass on both sides using the solution & sponge. Reapply as necessary until the glass is clean. Dry thoroughly with paper towels, before reinstalling the glass.
The heat stain is not really a heat stain. It's left over residue, from when someone used commercial glass cleaner to clean the glass. The white stain is from the ammonia in the cleaner.
Hope this helps you and thanks for choosing FixYa.
Sep 16, 2011 | Heating & Cooling
Blue rubber glove in load stained dryer inside. How to clean?
take a boyyle of simple green solution, and get a clean rag, and this should take the stain off, after youwipe it down with this if it is coming off, wipe it down after with water, then dry it off with a clean rag, let me know if this gets it, it should thks larry
Apr 22, 2010 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
My A630 got wet and has a water stain behind the lens. Can I remove the lens to clean the stain?
You can but, you must be VERY careful.  It isn't like a film camera.  Everything must be lined up perfectly when you put it back together.  There is also a very small pickup behind the lens that will need to be cleaned.  It is about 1/8" X 1/4".
Jan 19, 2010 | Canon PowerShot A630 Digital Camera
Washer whining when washing and spinning leaving brown stains on clothes
Turn water off. Remove hoses and clean the rust out of the strainers at hose end. If they are clogged they will sound funny when water goes through them.
May 04, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
"fabric softner staining the clothes"
make sure you delute it with water. yes fabric softner will start to stain your clothes if you use too much of it. I would recomend stop useing it for a while. so you can clean the washer out. There is a product called Washer magic or Affresh that cleans out residues built up in your washer. or you can just run several loads of HOT water and bleach to clean it out. The hot water will melt the left over fabric softner in your washer. Fabric softner is kind of like hardend bacon fat thats what it looks like in your washer after time and if you do not clean your washer it builds up and builds up.
Also i do recomend alternating liquid detergent and powdered detergent. The reason why is powder leaves a residue that liquid takes away and vise versa. try this and let me know how it goes
Feb 12, 2009 | Maytag PAV2300 Top Load Washer
Hampton Bay Patio Furniture. Cibola Sectional Patio Armless Club Chair Logo
82 people viewed this question
Top Hampton Bay Garden Experts
Dennis Key
Dennis Key
john h
Are you a Hampton Bay Garden Expert? Answer questions, earn points and help others
