Question about ViewSonic NX2240W 22 in. LCD TV TV/HD Combo
Viewsonic 4 digit codes - ViewSonic NX2240W 22 in. LCD TV TV/HD Combo
ViewSonic PJ55ID remote
What do you want to know? Setup codes? If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 15, 2013 | ViewSonic Televison & Video
Im looking for imusic passcodes
Hello Dear'''
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jan 12, 2013 | ViewSonic G Tablet
Programming remote control
Setup code to Viewsonic TV are: 0046 0072
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jul 16, 2012 | Televison & Video
Will it work on viewsonic
To control a Viewsonic TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the four-digit code 1755.
The LED will blink twice.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
Dec 24, 2009 | One For All URC-3021 Remote Control
What is the code needed to run a visio tv with the sony bdp-s360 blu-ray remote
Vizio use the same codes that: Gateway, Tatung, Westinghouse, Viewsonic, Teac, Sampo, Sanyo
I have 5 codes for Vizio, 4 are the same that the 4 that I have for Viewsonic, so start traying those if you find them in your remote book. But I didn't find a match for the 5` code.
Good luck
Dec 04, 2009 | Sony RM-V202 Remote Control
WHERE Can i get a viewsonic remote?
Try visiting the part store the following link, make sure you have the correct serial number. http://www.PartStore.com
Also to buy universal remotes try visiting http://www.ilektroniks.com
Thanks
Nov 21, 2007 | ViewSonic RLC-006 Remote Control
ViewSonic NX2240W 22 in. LCD TV TV/HD Combo Logo
20 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
