Question about Canon MV700 Mini DV Digital Camcorder
Canon mv700 not loading tape
Hi there. The camera is fine but when I insert a tape it doesnt want to close. On the screen it tells me to remove tape and there is a continuous beeping. Without the tape it closes fine. I have try this with different tapes so it is not a problem at the tape it self. Help!!
  • weeron Oct 22, 2008
    mine too, its a pain in the rear.  also beeps 5 times. I've heard it may be a condensation problem, but have had it on radiators, in cupboards and all sorts to no avail.
  • 169 Answers
If you hear the cylinder drum running to fast try take out the connection of the drum at the circuit and back it again...try this in you can open your camera....
Posted on Aug 09, 2007
Hi i have a cannon MV700E and it hold the batt charge so thats not the problem the tape was working fine but my grandson touched something on it and now the tape will not play propley and the screen has line and fuzz pictures across it can you help
Posted on Nov 19, 2008
SOURCE:
How can I connect my Canon Camcorder MV700 to my computer Acer aspire L3600 ?
Please refer page 118 of the manual of Cannon MV700 available from this website.
http://files.canon-europe.com/files/soft24377/manual/MV690_MV700_Series_CUG_EN.pdf
You can connect camcorder with Acer Aspire using a USB port and cable.
But this interface only allows transfer of still images from the SD card on the camera. It will not allow video images to be transferred from the tape.
Some models of Acer also have flywire interface (IEEE1394) and also SD card reader. You can use these also to download video images from the camcorder.
May 07, 2014 | Canon MV700 Mini DV Digital Camcorder
Hi Donald. not sure how many calls you get from
The fault seems to be in the sensor and the mode switch of the loading system which is connected with the main controller processor and loading driver.
This can be a failure of the tape end detector which is a IR - infra red- emitter which is placed in the center of the tape tray and MUST feed continuous signal to the END IR detectors placed at either ends.
Also the tape seems to load with a false detection of the cassette within when the tray is closed for this reason of the failure along with a possible misplaced mode switch settings. This triggers to make the loading move without a reason and so can be due to failure of the the mode switch or unbalanced settings.You will need some experience to remove the tray unit, then check on the IR sensors and also check the settings of the loading drive and mode switch.
Nov 27, 2011 | Cameras
Sony dcr-hc38. inserted tape. hear beeps. screen states to "reinsert the cassette". it continues and wont play or record --Solution #1- change the mechnical assembley of casete ...Can you explain how to do...
try it without inserting cassette if it closes correctly and doesnt load with cassette then 99% problem is with drum motor.look out for drum motor connector remove it clean it with pencil eraser and try again if it works, fine or just replace drum motor
Jun 11, 2010 | Sony DCR-HC38 Mini DV Digital Camcorder
Canon mv700
Hi
I have had this camera for around 4 years now. It works fine. I basically plug in the firewire connection on my camera switch it on to playback/camera mode then plug the other end into to my computer my operating system picks it up fine without any problems. It doesn't require any drivers windows will auto install any drivers it needs. Not sure why you are getting this problem.
Nov 09, 2008 | Canon MV700 Mini DV Digital Camcorder
Import into imovies
convert your video to mp4, mov, or dv with imovie converter, and then import them to imovie for editing.
Jun 29, 2008 | Canon MV700 Mini DV Digital Camcorder
Canon MVX200 will not load dv tape
The "remove Tape" error message on Canon DV camcorders is a general message meaning something is not correct with the tape transport system. These are miniature precision mechanisms and It could be anything from dew sensors to head motor, capstan drive etc. If the cassette drawer closes OK with no tape inserted then the tape sensor/ end tape sensor is operating. With no tape inserted the head drum does not run when the drawer closes but it does with a tape present. Does the head drum start up when you load a tape or is there no noise at all? If the head runs then it is possible the capstan is not starting or is jammed. If the head does not run then the cure will be either extremely tedious and delicate or very expensive. These units do not dismantle easily so unless you have some experience with this, or are willing to take a risk, then I would not recommend it. However, without such action you may have to write-off the unit anyway. Canon's repair charge will exceed the camera's value unless it's still under warranty. Your best option would be to find a local repairer that is willing to look at it, but I wouldn't be too optimistic .To some, this error message is a major issue when deciding to buying canon dv cameras. However, they are great little cameras and treated kindly will give many hours of excellent service. Don't store the camera with tapes loaded. don't subject it to sudden temperature changes or excessive vibration. Store it in a dry protected atmosphere and refrain from taking it onto the beach (salt AND sand !!!!) when on holiday etc.
Dec 17, 2007 | Canon MVX200 Mini DV Digital Camcorder
Tape insertion
It's dirty inside, you need to send it off to be cleaned.
Nov 28, 2007 | Canon DV-MV830i Mini DV Digital Camcorder
Canon mv700 Camera displays an error code
I have one of these. Sounds like you have a fault. Try removing the battery and any tapes. Also you might want to try and replacing the penny size battery it has which keeps the time and date up to date.
When did it last work and what did you last do with it. eg. if you've taken it out of a cold storage such as a loft and then into a warm place you might find that it fails to work because of condensation build up in the internal circuits. Keep it it a warm place for a while and see if it makes any difference.
Nov 27, 2007 | Canon MV700 Mini DV Digital Camcorder
Loading tapes
I had the same Problem. My Solution was i open the camera, then i take the batery away. I put the tape into and close the camera, then i put the battery into and the camera close with the tape
Nov 05, 2007 | Sony Handycam CCD-TRV40 Camcorder
Newly Inserted Tape Ejects Automatically
Usually the drive mechanism is made up of rubber rollers, belt, etc. If these are worn out (in time), the drive mechanism will slide and will not be able to rotate the tape. If the cam cannot detect the movement ?n the tape then it will efect it.
May 14, 2007 | Panasonic PV-GS31 Mini DV Digital...
Canon MV700 Mini DV Digital Camcorder Logo
300 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
