Question about Watches
Quatrz ajanta OLC 104 -functioning problem
I have Ajanta Quartz digital wall clock. it runs on electricity as well as battery.because if power is not avl. it will run on battery But whenever power goes off it does not work on battery and when power supply restored it s start working but it's battery system does not work from power off to power restore duration. Every time when power goes and restored i have to set the date and time.
  • 14 Answers
SOURCE: Hands Stopped
This model watch uses two battery, an lithium battery is for digital and there is another silver oxide battery which were installed beneath the lithiem battery, all you need to do is remove the lithium battery then replace the silver oxide battery, the battery # is 377.
Tsai
Posted on Jan 27, 2008
  • 6 Answers
SOURCE: setting time/date on old Seiko
Good News you can find Seiko Digital Watches Instruction manuals from http://SeikoDigitalWatches.com its very good site about Seiko Watches.
Thanks
Kashif
http://VintageDigitalWatches.com
Posted on Apr 02, 2009
gemineye61
  • 831 Answers
SOURCE: i have a quartz
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Posted on Aug 15, 2010
    SOURCE: Elgin Westminster Quartz Chime clock won't work
    IF I GATHER CORRECTLY , YOUR CLOCK HAS TWO BATTERIES, ONE AT BASE AND ANOTHER ON THE BACK OF THE UNIT. THE ONE ON THE BACK OF THE UNIT IS RESPONSIBLE FOR CLOCK'S FUNCTIONALITY AND I THINK THE BATTERY AT BASE IS FOR THE ROTATING BALLS ( PENDULUM ). SO OPEN UP THE BACK IF YOU HAVE NOT DONE SO, AND REPLACE THE BATTERY. CAREFULLY THOUH AS THERE RE TWO SCREWS ON TOP AND A SNAP AT CENTER BOTTOM WHICH YOU COULD EASILY BREAK IF YOU DO NOT DO IT WITH CARE. OPEN UP THE SCREWS FIRST AND GENTLY USING A SCREW DRIVER PUSH BACK ON THE SNAP HOLE TO FORCE IT UPWARDS AND INWARDS. IF NONE OF THIS MAKES SENSE THEN WE ARE LOOKING AT TWO DIFFERENT CLOCKS.
    HOPE THIS HELPS.
    Posted on Oct 11, 2010
    • 16 Answers
    SOURCE: Quartz president wall clock, I need to set the chime
    I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
    *Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
    *Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
    If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
    John
    Posted on Nov 03, 2010
    How to set date and day in ajanta quartz odc-170
    Try Googling (Ajanta)(odc-170)(manual) without parens.
    Mar 17, 2018 | Watches
    How to set time,day,date in ajanta odc 130
    Try Googling (Ajanta)(odc 130)(manual) without parens for instructions.
    May 13, 2017 | Watches
    HOW TO STOP ALARM SYSTEM IN AJANTA QWARTZ ODC 120 MODEL WATCH. ALARM KEEPS BEEPING EVERY DAY AND I DONT WANT THAT.
    Ask the maker via the Contact page. Looks cheap and nasty!
    http://ajantaworld.com/index.php/products/time-products/picture-clock/digital/lcd.html
    Sep 28, 2015 | Watches
    How to adjust the correct time of ajanta quartz ODC-120
    move the plastic button at the back slightly to the right side where it says "Time" and than adjust the time by pressing 'Mode' and 'Up/Countdown' buttons
    Oct 14, 2013 | Watches
    I own a Ajanta Quartz odc 170 wall clock but have misplaced the operating instructions. Can someone please help me with the setting instructions. Many thanks. Joshua
    There is a sliding button on the back side to the right of inner frame. The slider has "Normal -> Time -> AL SNZ -> CountDown->Timer" marked on it.
    You need to move that button to time basically to the right side and then user up and down buttons to adjust the time.
    Hope this helps.
    -- Anant
    Jan 29, 2013 | Watches
    I just replaced the battery and now it won't let me set the watch, how do I do that?
    mcdevito75 here, If you replaced the battery yourself you may have moved the quatrz movement and mis-aligned the buttons the thier contact spot on the quartz movement. You"ll have to open the back nd check by pushing gently on each button 1 at a time to make sure each button is makeing contact at the right spot on the quartz movement, also even if the battery is new it can still be weak or dead as they have a shelf life, also you may need the exact battery number Casio recommends, a small watch repair shop in your area can advise. The 2 buttons you need to set your watch are MODE and SET. --------- Press and maybe hold in the MODE button, 2--3 seconds, MODE button usually on the right side of watch caseing, see the display flashing, now press set to set each function, (hour, minute etc.) press MODE after ecah function is set, (hour, minute etc.) once everything is set, press MODE again to see steady display.
    Jul 21, 2010 | Casio WVA105HDA Wave Ceptor watch
    My watch ar2434 is not functioning properly. the seconds hand moves for some time and then stops. i changed the battery but the problem still persists. what could be the problem?
    mcdevito75 here, The quatrz movement could need a little quartz oil or the quartz movement could be going bad, but foirst check make sure you have the correct battery and that it didn:"t work loose Return to whoever changed the battery to have it checked.
    Jul 21, 2010 | Watches
    My swatch model is swatch irony YSS112G. It stops working and when i took it to swatch shop the assistant told me its due to the mechanical problem since a new battery was restored. i was told that it was...
    mcdevito75 here, Once any Quatrz mechanism goes, it"s ususlly gone. New replacement Quartz mechanisms are sold but just the mechanism itself could cost $30.00---$70.00 then the labor to have it installed, A Swatch watch is a COLLECTABLE item, it may be worth the expense of a new Quartz Mechanism, spaek with the watch shop about details.
    Jun 27, 2010 | Watches
    John
    Apr 21, 2010 | Watches
    Watches Logo
    627 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
