Question about Seiko Watches
A159-4039 User Manual
How to set time and day
User manual
Is this watch a knock-off or real.
Oct 21, 2013 | Tag Heuer Carrera Twin Time WV2116.FC6181...
G Shock
Hi, go to the following website G-Shock Website User Support
If you know the model number of the watch, enter it in the "Number" search field in the "Manuals" section. This should then find the correct user guide for you to download and help set the time and date. You will probably find that most models will function in the same way, so you may be able to find a similar model that sets the time and date in the same way as the watch you have.
If your not successful with that, let me know and will try and grab a manual for you that could work :-)
Cheers
Apr 29, 2013 | Watches
I just got a Invicta Corduba watch and I need to set the time. How do I do that? The number on the back is #6675. Thanks
this watch has a screw down crown. lift up the protector bar or start to unscrew down until it pops out, then turn slowly and pul gently all way out. set the time . tere is 2 positions there. full out time and inbetwwen them is the date and day settings.when there turn up or down until date chages, if it has day and date , up is day down is date.you have to turn few times for it to move..set the date ,set day before and go around . the 12 see number change to might date, set the correct time am or pm. push the crown in and screw in up til hand tight.
Jun 17, 2011 | Invicta Watches
How to set the date
Time and date setting
are only necessary if automatic setting by radio broadcast is unsuccessful.
To set time, date, and options:
1) With time and day showing, press and hold SET.
2) City code flashes. Press START/STOP to select city that represents your time zone. See table below
for city codes.
3) Press MODE. DST (daylight savings time) setting flashes. Press START/STOP to select AUTO (obey
setting in radio signal), ON, or OFF (disregarding setting in radio signal for ON/OFF).
4) Press MODE. Hour flashes. Press START/STOP to change hour (including AM/PM); hold button to
scan values
5) Press MODE. Minutes flash. Press START/STOP to change minutes
6) Press MODE. Seconds flash. Press START/STOP to set seconds to zero.
7) Press MODE. Year flashes. Press START/STOP to change year.
8) Press MODE. Month flashes. Press START/STOP to change month.
9) Press MODE. Day flashes. Press START/STOP to change day.
10) Press MODE. Date flashes. Press START/STOP to select M-D (month-day) or D-M (day-month) format.
11) Press MODE. Hourly chime setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch chimes on every hour.
12) Press MODE. Button beep setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch beeps for every button press.
13) Press SET, at any step, when done setting.
Press and hold MODE to switch between 12- and 24-hour time format.
Press SET to view date. Year is at top of display and date is below.
Press RECEIVE to view current city.
Press and hold RECEIVE to begin manual reception of time signal, as described in ATOMIC CLOCK
SYNCHRONIZATION section.
(from the User's manual)
May 03, 2011 | Timex 1440 Prizefighter 53032 Sports...
How to set the date and time on timex t20471
There are two crown positions on this timepiece. The furthest out, or second position, sets the analog time hands. The first crown position in one direction sets the day, and in the other sets the date. To access the first crown position, pull the crown out very slowly until you feel a "click" or pull the crown out all the way and push it in slowly until you feel a "click" with your fingers.
To set the watch:
1) Pull the crown to the second position and bring the hour and minute hand to the 12:00 position, if it switches the day and date after moving past, you are then in AM time.
2) Set the time appropriately to AM/PM. Use http://www.time.gov/ for the most accurate time.
3) Put the crown in the first click position. Set the Date and Day appropriately, having determined the AM/PM time setting. This will ensure that the day/date change at 12:00 midnight instead of 12:00 noon.
Feb 04, 2011 | Timex T20471 Easy Reader Expansion ()...
I don't know how to set the date properly on my Tag Heuer formula 1 watch. Is there a time of the day that I should do it?
If you go to http://www.tagheuer.com/the-collection/tag-heuer-formula-1/men/quartz-chronograph/index.lbl?w=CAH1110.BA0850 , you will see a menu on the right of the screen.
Clcik on "user manual" to download the manual for your watch.
There are no instructions about setting the date apart from saying the date changes at midnight but you can advance the date by winding it past midnight. If you want to advance it more than one day, wind it back and then forward past midnight again. Repeat as many times as required until you reach the date you need.
How far back you need to wind the watch you will have to find by eaperimenting and observing when the date changes. You might hear a soft "click" when winding it backward, you can the wind it forward again.
Feb 01, 2011 | Tag Heuer Formula One
I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
Dec 13, 2010 | Citizen Eco-Drive watch
I have a Timex automatic with day and date. How do I set the day and date?
I often sell vintage Timex watches which have a day and date feature. Setting the day and date feature can be a little tricky - if not frusterating if you aren't familiar with how to do it since most of the original manuals that came with these are long gone!
I'll try to explain the process - please feel free to contact me if this doesn't make sense.
1. Pull out the crown on the right hand side of the watch.
2. Advance the crown so the time advances clockwise until the day is correct.
3. Rotate the crown so the time is going counter-clockwise (the opposite direction) until the date "clicks". (the day will click first, then the date).
4. Rotate the crown so the time is going clockwise again and the date will advance.
5. Continue this back and forth action of rotation until the date is correct.
6. Push in the crown and you're done!
I'm considering making a video of this process. Please let me know if this is something you would be interested in.
Oct 30, 2010 | Timex Automatic Watch
How do you set this watch....4 buttons
SETTING THE TIME AND DATE ON AN OLD 4 BUTTON DIGITAL WATCH
[L1] [R1]
[L2] [R2]
SETTING THE TIME.
Press [L2] to move through the modes. When the time display flashes, you are in the correct mode to set the time. The hours first, then the minutes and seconds.
Press [R1] to advance the numbers, [R2] to go to the next.
Press [L2] to save your settings. [L1] is not used; it's the light.
SETTING THE DATE AND DAY. After setting the time (seconds flashing) push [R2] to move though time, backwards, to date, [R1] to set day, [R2] to move to month [R1] to set the month. Push [R2] to get to the day of the week, then [R1] to change. [L2] to end.
Jul 26, 2010 | Fossil JR9455 Watch
Watches Logo
55 people viewed this question
Top Seiko Watches Experts
Lawrence Oravetz
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
