Question about Golds Gym StrideTrainer 595 Elliptical
My computer display went out.
I can control fan but read out is not working. Can this Be fixed?
2004 Yukon 6.0 V8 instrument cluster problem
No DTC'S stored any modules ? Any parasitic drain on the battery ? Does scan tool communicate with the instrument cluster ? Do you know about GM power modes
  1. Access the Class 2 Power Mode in the Diagnostic Circuit Check on the scan tool.
  2. Rotate the ignition switch through all positions while observing the Ignition Switch Power Mode parameter.
Does the Ignition Switch parameter reading match the ignition switch position for all switch positions?
What type scan tool are you using ? Can yours communicate with all the modules on the vehicle ?
Select the display DTCs function on the scan tool for the following control modules:
Transfer Case Electronic Control (TREC)
Body Control Module (BCM)
Electronic Brake Control Module (EBCM)
Instrument Panel Cluster (IPC)
Powertrain Control Module (PCM)
Sensing and Diagnostic Module (SDM)
Does the scan tool display any DTCs for the control modules listed above?
Does the scan tool display any DTCs which begin with a "U"?
Apr 09, 2015 | GMC 2004 Yukon XL 1500 Denali
Car turns over doesnt start then nothing at all
Happened to me several times in Florida, once in Canada. 1999 Chrysler Seabring Convertible Lxi 2.7. Computer locks out ignition for random periods. Took it to a Huge dealership in Florida, paid $350.00 for transmission shaft speed sensor stuff. Fixed it. Fine since. 1 yr. later body control module went (computer). Expensive to fix.$(800.00 just for dealer only part) Air door control, tachometer, and a rear window affected. I'll live with it as the 'failsafe' for loss of AC control is AC is 'Defrost/Floor'. Fan works fine.
Nov 27, 2012 | 2003 Chrysler Concorde
Display works well but is very hard to read even in the dark.
UNFORTUNATELY THIS IS A COMMON PROBLEM..THEY HAVE 2 SEPARATE LIGHTS IN THESE DISPLAYS AND ONE HAS WENT BAD...UNLESS YOU CAN SOLDER AND FIND THE REPLACEMENT LIGHT BULB THE ALTERNATIVE FIX IS TO REPLACE THE DISPLAY CONTROL ON THE UNIT....PLEASE VOTE...GOOD LUCK TO YOU
Jan 03, 2011 | Microwave Ovens
Refrigerator warm, display blank but freezer still works
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*#$^
Feb 21, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
2005 Chrysler Pacific-no heat and no fan-display works
replace the complete heater control unit was my only fix! over $700 in Cnada for control.
Feb 17, 2010 | 2005 Chrysler Pacifica
Canon ir 400 photocopier
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
Jun 03, 2009 | Canon imageRUNNER 400S Copier
Ac controls quit working blower fan is running on high all thetime. compressor is not working.
fan elays are under hood in black box by battery. 3 of them. 2 for high speed, 1 for low speed. Default is high speed when there is a probem.
Suspect maybe they shorted something out when fixing dent. Did they do any welding on the van? Connecting the cables to the body can sometimes send voltage where it's not wanted.
Nov 06, 2008 | 2000 Nissan Quest
Zephyr Milano hood fan and lights stop working. Power is on.
Hi ronio,
I'm Harvey the Master Plumber.
Your problem is: After the power went out your Zephyr hood lights and fan don't work at all. There is a faint glow on the digital display but the fan and lights don't respond to pressing the control buttons.
First check the circuit breaker. If OK then check the transformer in the unit. It's next to the fan motor. If no power on the high side then you have a loose or broken connection. If you have no power on the low side the you have a bad transformer. If OK then you have a bad control board.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 22, 2008 | Zephyr Milano-S ZMI-M90S Kitchen Hood
Display of vga card which is AGP Socket
It is unlikely that the floppy took out the agp display controller,
I assume that you have no video when the computer startsup also.
But if that is the case you can use a PCI video card.
Are the fans and hard drive running?
When you were in the case replacing the floppy did you make sure that nothing else was disturbed and were wearing an antistatic strap?
I would go over all of the wires inside.
Please let me know how you make out.
Dec 07, 2007 | Foxconn f845s Motherboard
Golds Gym StrideTrainer 595 Elliptical Logo
49 people viewed this question
Top Golds Gym Exercise & Fitness Experts
nursedeb1989
Level 1 Expert
Steven's...
Steven's...
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
