Question about Gateway FPD1760 17" LCD Monitor
Gateway FPD1760 the red in the rgb is suddenly gone
Screen only displays the green and blue. This has only begun happening in the last few days. We've had the monitor for about 2 years with no problem.
  • Pawel May 11, 2010
    are you using VGA or DVI? can you check the screen with other cable of same type you are using at the moment? if it's not working then try the other one.
  • 741 Answers
Your graphics card is not working propertly buy a new one.
Posted on Mar 15, 2009
SOURCE:
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
Gateway fpd1760 tft lcd color monitor i not warking
- isolate the problem first by checking all the cables for any bent pins and loose wire/ connections - unplug the lcd monitor and try to get a spare computer to check if its your computer's video card or the lcd monitor - if lcd will give display using a different computer it only means there's something wrong in the computer's video card - if lcd will not give display using a different computer it only means lcd had gone bad and needs to be replaced.
thanks.
Jan 03, 2011 | Gateway FPD1760 Monitor
Gateway FPD2275W LCD monitor lost "Red" signal of RGB display
Not really, first check your connections, normally when you loose red a pin broke off the VGA connector.
If the panel died then its probably not worth while. The red panel is however, under the most stress.
Jul 09, 2010 | Gateway FPD2275W LCD Monitor
All of a sudden, the color changed to a blue/green...
You might have brought the magnet near the screen so it happened like this it will automatically adjusted after few days
May 20, 2010 | Computers & Internet
Gateway fpd1760 lcd monitor no power at all the blue led clicks on for 5 seconds the screen flashes for a milla second then nothing
check if the signal cable has been plugged in properly at the back of the screen and at the back of the computer.
if you have another computer or laptop,.check if the screen works fine with it.as this could even be a boot up problem with the computer
Feb 04, 2010 | Gateway FPD1760 17" LCD Monitor
I have a Gateway FPD1760TFT LCD color monitor. I
What is the display resolution you have set in your display properties? For this monitor it should be set to 1280x1024 pixels, which should give you proper screen geometry.
Jan 24, 2010 | Gateway FPD1760 17" LCD Monitor
Monitor colors not displaying any red only blue/yellow
update the latest driver for your video card might help.
Mar 19, 2009 | Gateway FPD1760 Monitor
Problem with FPD1760 Gateway monitor
sounds like the LCD inverter gone bad.
you might get lucky in finding one on EBAY.
yeah gateway sucks on customer service.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jun 18, 2008 | Gateway FPD1760 17" LCD Monitor
Color Problem:
in Monitor CRT Red-Blue-green cathode guns are there.. Mixing of these colour we can get the original colour chrominace technique. if any of the colour gun is faulty we would get more REad or blue or green picture. Measure RGB voltages. you can verfify which gun is faulty. if then check RGB processing circuits. Else there might be problem Chrominance colour decoder system. Contact service centre
Jan 09, 2007 | Samsung SyncMaster 551 15" CRT Monitor
Blue Saturation with retrace lines visable
could be but there are a few checks that need to be donr first.. Try to turn down the g2 control just a bit on the flyback transformer. If no effect unsoder the blure drive transistor on the crt board If the blue is still there that means the crt is shorted and you could try to clean the elements with a crt rejuvenator and see if that helps. If the screen goes to red and green after you disconnect the blue drive transistor then you need to check the osd drivers as well as the rgb output drive from the video IC. If the blue gun in the tube shorted or leaky I have in the past and it really works a isolation transformer that plugs in to the crt socket and the other end plugs into the crt. What this does is isolate the the gun of the crt from the filiments and thats where they get shorted or leaky but for how long it will last who knows.
Mar 26, 2006 | Sharp 36U-S60 36" TV
Gateway FPD1760 17" LCD Monitor Logo
148 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
