Question about Emerson Quiet Kool 6GC53 Air Conditioner
Turned air conditioner on. Fan started normally. But thermostat refused to kick in and start the compressor. Steps taken: 1. Tried various fan speeds. 2. Tried various thermostat settings. 3. Tried various combinations of 1. and 2. Result: Fan still running, but no cooling. At first, changing thermostat settings from MAX to MIN, there wasn't even a click, nothing. After running it for an hour or so, it now clicks (at the compressor on/off point), but still no compressor start, no cooling.
  • Chesapeake Aug 09, 2007
    Very impressed with SolutionGuy's expertise.
    Not being a DIYer, I may not try it myself.
    But excellent and impressive analysis and advice.
    Thanks!
    President:
  • 331 Answers
Chesapeake, given your symptoms you'll be looking at installing a new Selector Switch. But, before you go there... UNPLUG THE UNIT OR SHUT OFF THE BREAKER!!! Your selector switch does two things at a time, It energizes the fan motor (which it IS doing) and energizes the compressor at the same time. The voltage to your compressor goes from the wall into the selector, out of the selector, through the temp control then to the compressor. When the temp control is satisfied, it interrupts power to the compressor. The click you hear is the temp control being NOT satisfied and trying to send power to the comp. But if there is "no power" to send (i.e., the selector switch has failed)the compressor won't know to engage. Remove the front panel and filter. Remove the control box housing. Remove the knobs from the controls. You will now see the selector switch. Remove the 2 screws that fasten it (don't remove the wire yet!) and install the new switch. Then, one wire at a time, remove the wires from the old switch and install them on the new one. ***If you have an OHM meter, check the temp control before ordering a selector because this may be the problem and NOT the selector! To do this... remove the 2 wires from the temp control, set the control to "coldest". Then with your meter, test OHM's between the terminals. If you see "zero" OHM's, it's good. If you see no change in your meter, it's bad and THIS is the source of your problem. If you don't have a meter... you can test using this procedure... cut a 6" length of wire and strip the ends to about 3/8", twist the copper ends tightly. Remove both wires from the temp control, then insert one end of your jumper wire into one terminal and the other end into the other terminal. Make sure the "jumpered" wires are away from anything metal!!! And plug the unit back in. Now turn the unit on. If the unit fires up? It's the temp control, If not? it's the selector switch. Here's a link for parts...http://www.repairclinic.com/0080.asp
Posted on Aug 09, 2007
  • XXXREX
    XXXREX Mar 08, 2012
    I must correct the asssertion made,
    out of the selector, through the temp control then to the compressor. When the temp control is satisfied, it interrupts power to the compressor,
    Wrong, the fan and compressor are independant and the fan only mode is why, .
    You further asserted,
    THIS IS CORRECT
    The click you hear is the temp control being NOT satisfied??
    THE TEMP CONTROL BEING SATISFIED = OPENING!
    NOT SATISFIED = CLOSED!
    TRYING TO SEND POWER = CLOSED! YOU EVEN STATE ITS 'FAILING TO BE SATISFIED, WHICH MEANS REMAINS CLOSED!AND WONT "OPEN "UNTIL COLDERWHICH WITHOUT COMPRESSOR ISNT HAPPENING,, CORRECT!?
    YOU ASSERT INITIALLY THE COMPRESSOR AND FAN CYCLE TOGETHER AND CONTROLS ARE IN SERIES, WHICH MEANS BOTH REQUIRED TO INITIATE, EITHER ALONE MAY TERMINATE, YOUR EXPLANATION MAKES CO SENSE AND IS CONTRADICTORY TO BOOT..
    Now, what this really means is the thermal overload is "clicking" or opening up due to the start capaciitor, or PTC thermistor start assist device/s Google hard start kit, also thermal overload, they are external on the compressors and a common part to find doing this. If it has no start assist devices from the factory, many units require them after awhile to add torque to boost starting ability for "tired' units, very common to run into.
I need to remove the blower motor from my Emerson Quiet Kool model 1350, how do I do this..
First open the control panel and remove all wires of your fan motor from the control switch and the capacitor. Remove also the compressor wires. Unscrew all panels and move the evaporator farther from the mounting base Pull-out the fan motor assembly with the panels. Unscrew the blower, fan blade, and them from the assembly. Unscrew the motor and now it is free.
Aug 31, 2011 | Emerson Quiet Kool 6GC53 Air Conditioner
I need a master control knob. I don't know the model number of the Emerson Quiet Kool air conditioner.
Without the Model Number, it's hard to know what knob fits your model. However, the link below, may provide some help. But, having the Model Number would be a bulls eye. Remove the front of the AC unit. There may be a manufacturer's data plate inside, which would provide the model number.
http://www.appliancefactoryparts.com/airconditioners/emerson/emerson-knobs.html
Hope this helps you.
Jul 13, 2011 | Emerson Quiet Kool 6GC53 Air Conditioner
I need a select knob for model #10mw42k-d part#a5 1121 22410-001 1121-900000-001 knob broke
If you need one quick I buy generic knobs from my local ACE hardware store they work fine and are cheap. good luck
Aug 10, 2010 | Emerson Quiet Kool 6GC53 Air Conditioner
Ac makes a grinding noise...does it have to be lubricated? my neigbor below complains that the noise keeps her up all night. need your help. thank you,
mcdevito75 here, Either the fan motor or compressor, I'm leaning toward the compressor, Hve your local a/c repair shop look at it, they come to the house, if compressor, expensive repair maybe better to replace a/c altogether
Jun 21, 2010 | Emerson Quiet Kool 6GC53 Air Conditioner
Emerson quiet kool model.eqk 1350 f serialo 20e 808320 wont heat, does it have an element? where is it located?
I looked up the model number parts
Their does not appear to be a heating element associated with this ac nor a reversing valve so I don't think it has a heat feature. You could mount it backwards and heat an area. That would look weird.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 29, 2010 | Emerson Quiet Kool 6GC53 Air Conditioner
Heat/AC unit in working order, plugged in 20Amp outlet.. no fan?
Hi1
Do you have at least 200 volts at your outlet? Check that first. You said you brought it home from work, so when you plugged it in at home did you plug it into a 120 volt recepticle?
Jan 01, 2010 | Emerson Quiet Kool 12NW46HK Air...
Have just bought an airtech elite have no manual...we not sure if we operating it right
Almost all Emerson product manuals are available on line in pdf format. It may take some time to locate them, but they are there....
Feb 03, 2009 | Emerson Quiet Kool 6GC53 Air Conditioner
Emerson Quiet Kool A/C Filter
If you know where to find a filter for a Emerson Quiet Kool--Model # 18DD4H-EE
Serial # 21A 927552 Please let me know
beverleyed@yahoo.com
Thanks
Ed Beverley
Jun 07, 2008 | Emerson Quiet Kool 10GV13 Air Conditioner
Emerson Quiet Kool 6GC53 Air Conditioner Logo
315 people viewed this question
Top Emerson Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
