Question about Kenwood Car Audio & Video
Kenwood kdc 200u
Doe it hav rca hook ups
  • 132 Answers
SOURCE: kenwood kdc-x592
They dont work with classic ipod for direct ipod connection, also try updateing the firmware in your ipod this is a common problem, deck looks sweet tho eh?
Posted on Jul 25, 2008
SOURCE: Kenwood KDC-716S
FLEX CABLE has been worn out, its thirty bucks and easy to install.
Posted on Oct 25, 2008
Mike258
  • 1498 Answers
SOURCE: kenwood kdc x915 cd player
Hi there JT,
An Amp makes existing sound louder. If you aren't getting sound now, there's a problem.
From your description, it sounds like your stereo is going through all the motions, it looks and acts like it is functioning. Just no sound.
If that is wrong, let me know.
When you turn it on, do you hear anything from the speakers? White noise, a click, anything, any indication that they are hooked to any kind of power supply?
Let's do the basics (easiest) first:
  • Mute is off
  • Balance and Fader centered
  • Volume up
  • CD in and playing
Still nothing? OK.
  • I need you to access the back of the stereo. (Sorry)
  • Yellow and red are power. Black is ground. The unit works so these are ok. Blue is to turn on a remote device like an amp. There may be an orange, ignore.
  • There are four sets of wire for the speakers. Colors are White, Gray, Purple and Green. One of each set is solid colored, the other has a stripe.
  • White and gray are front
  • Purple and green are back. Same page?
  • These are what your speakers should be hooked to. One set for each speaker. Are they?
  • Eyeball the connects, look for shorts, disconnects, etc.
  • Get a speaker and test it right there behind the stereo on one set after another. Anything? If so, you have a problem in the wiring not the stereo
That's enough for now. I'd hate to write a book and have you solve the thing in chapter one. Get back to me with the answers and results. Those results will decide the next course of action (Unless of course it's fixed by then, in which case let me know with a nice FixYa rating).
Mike
Posted on Jan 07, 2009
  • 1126 Answers
SOURCE: how do i hook an ipod up to a kenwood kdc mp335?
Page 22 of this users guide discusses AUX input setting modes for your kdc-mp335.
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/KDC-MP3035.pdf
Yes, it contains KDC-MP335 as well as KDC-MP3035.
Posted on Oct 23, 2009
SOURCE: Kenwood with no sound
just had the same prob. you probably did not have the factory amp hooked up . its a blu wire on the factory harnes. if you used the aftermarket conversion harness. you would hook up either the remote wire or the elcect ant. wire. both blut with white strip on most decks. mine was also a dodge car. i had the prob on.
Posted on Jan 19, 2010
Kenwood kdc x597 no sound through the rca conection to my amplifier
Make sure RCA is on threw head unit,
2.make sure you have good cables
3.most ken units have 2 sets of RCA
hook ups one is for cd/changer the other
is a low pass for amp.
4 you have bad RCA channels send to
kenwood for service
Jun 01, 2014 | Car Audio & Video
Kenwood kdc-200u looses all of the setup when power is turned off
make sure your batt wire is hooked up correctly, there are two power wires one is constant and one is for the ignition, make sure the constant is hooked up correctly
Jan 26, 2013 | Kenwood Car Audio & Video
I installed my kenwood kdc 200U in my 83 regal it plays real nice till i start driving then the power cuts off and on what should i do
I got a Kenwood KDC-200U CD player.Wy is it that i cant play my IPOT Silver 6 GB on the IPOT setting but i cane ron it on AUX setting?
Nov 25, 2012 | Car Audio & Video
How do i set the rca settings for my kenwood kdc-217
Theres no way to change the rca settings. More than likely they put out 2 volts which is more common. Some newer more expensive models put out 4. What size remote wire you using? Try using a bigger (smaller #) gauge wire. That will give it a boost if your using the one that came with an amp kit. What kind of speakers? What kind of amp? If amp is mutli channel and only one sub then you will need to bridge the amp. Try different combos of + and - to see which gives the best. Also make sure everything is turned up on the amp and set to low pass frequency.
Jun 22, 2010 | Kenwood KDC-217 CD Player
Installing a kenwood kdc-135 in a 2001 monte carlo ls
Hello, my name is Israel and I will help you. The following should be able to help you out. Please rate and good luck.
constant 12+ orange
switched 12+ yellow
ground black/white
illumination gray/black
dimmer brown white
Left Front + tan
Left Front -
Apr 13, 2010 | Kenwood KDC-135 CD Player
Does the kenwood kdc-2025 have a way 2 hook up a mp3 or i-pod?
no, it says mp3 player because it can read mp3 discs that are burned with Kenwoods software.
Dec 30, 2009 | Kenwood KDC-2025 CD Player
I would like to know if an mp3 play can be hooked into this unit
You need this adapter or one like it:
KECA-C1AUX
Search Kenwood aux adapter on eBay or Goggle
heres tha manual to download:
http://inform3.kenwoodusa.com/manuals/KDC-MP225.pdf
May 30, 2009 | Kenwood Sirius KDC-MP225 CD Player
My kenwood kdc-mp235
I assume the amp is turning on (lighting up) No audio may be due to Burnt rca ground trace in your kenwood radio. If you have a ohm meter measure continuity from rca's ground terminal to radio chassis. Should be close to zero resistance. If there is no no continuity there are fusible traces on radios main board that burn open at times when to much current is flowing thru rca ground
Just a good possibility , haver seen this happedmany times.
If you need service manual let me know kstahl65@att.net
Jan 23, 2008 | Car Audio & Video
IHooking up mp3 player
Either buy the adapter from Kenwood and follow the instructions with that. Or go buy a headphone jack to RCA Audio cable and connect the RCA to the AUX RCAs on the back of your deck.
Dec 16, 2007 | Kenwood eXcelon KDC-X869 CD Player
Car Audio & Video Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
