Question about Micro Connectors Computers & Internet
Ssd3f BROKEN CONNECTOR
Model d52w20. The F connector on the rear panel is broken. How can I replace it?
The F connector probably is soldered to a circuit board inside your TV. You would have to disassemble the TV to get access to the board to unsolder the broken connector, remove it, and solder the replacement connector on the board.
Mar 30, 2016 | RCA Televison & Video
Fan connector broken hp ml350
Cannot disble CPU FAN CHECK / Systemboard to be repaired
Aug 13, 2012 | HP ProLiant ML350 G4 Server
ACS295 speaker cable to subwoofer, one of the pins of the connector is broken, how can I fix it or get a new connector?
if connector is broken, you need to buy a new connector, but it takes a little handwork and some tools a screw driver some electric iron and solder.
u need to open subwoofer case and check for the connector is soldered in a board is 2 jack 3,5mm female connector and one red mini-DIN connector. replace the connector take a attention on soldering the connector, dont damage the board wires and pins, if the iron above 300ºC.
take a special attention on electrostatic discharge, normaly burns sensitive boards.
Jan 30, 2010 | Altec Lansing ACS 295 Computer Speakers
Gestetner GX 30000 error 999
Error 999 is Maintenance Stepping Motor Out of Home Position
The maintenance motor HP
sensor failed to detect the motor
at the home position.
• Maintenance HP sensor connector loose,
broken, or defective
• Maintenance motor connector loose, broken,
or defective
• Movable Feeder connector loose, broken.
Jan 10, 2010 | Gestetner Office Equipment & Supplies
Water dispenser line is broken at connector end in the back of the refrigerator. Pieces of the broken pipe are glued inside the connector. Can we buy a new connector and glue it to the existing pipe? If...
The connector is a push on . Push in on the ring , while pulling out on the broken plastic line . Cut the end of the existing line , and just push into the connector snugly . Uses no glue or adhesive .
Nov 22, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Cable input connector broken off
Usually the connector or at least a new connector can be put back on. If there is minor damage to the board, a tech can repair it in most cases.
Jul 25, 2009 | Televison & Video
Broken 22 Pin,sync,charge,connector
Here's a solution for the broken socket on Mio 168 and Medion Micromaxx mdppc150 clones. Cheers
Mar 17, 2008 | Mitac Mio 168 Pocket PC
Broken RF Connector
you would have to get a new part for it. try looking online and out in your model number and put in rf connector needs replacing
Mar 10, 2008 | Apex Digital AT2002S 20" TV
Green plug won't connect to audio out/headphone jack
Yes.. It is a broken connector. What to do is to purchase a replacement 1/8 mini connector at an electronics supply store such as Radio Shack, cut off the broken connector and strip the ends off the wires and solder the wires onto the new connector.
Oct 09, 2007 | Boston Acoustics MicroMedia Computer...
Computers & Internet Logo
46 people viewed this question
Top Micro Connectors Computers & Internet Experts
David Payne
David Payne
Are you a Micro Connectors Computer and Internet Expert? Answer questions, earn points and help others
