Sercon 9000 a/c machine
How to operate
Feed dog on Janome 9000 will not come up
Have you cleaned it recently? There could be lint, dust, threads stuck in the area that are preventing the feed dogs operating. If that is not the cause, then the machine should probably be taken to a professional for service.
Dec 24, 2015 | Janome Memory Craft 9000 Computerized...
Sercon 5000
Donald, please don't submit multiple postings for the same request. It doesn't get answered any quicker.
May 11, 2013 | Computers & Internet
Willa sercon 5000 recovery unit recover r22
Try here. They seem to be specialists.
http://www.topicmuse.com/sercon+5000
Where can I find a operating manual for my Elna 9000
a operation manual will not so how to time the machine, what your
talking about is a service manual and elna does not sell them,,
only their sewing machine technicans have them, the machine
would have to be taken to a sewing machine repair shop for
timing or any other adjustments.
Apr 11, 2013 | Elna Sewing Machines
Touch panel freezing after approx 5 to 10 minutes operating
Your machine is a "computer" and needs a qualified Janome repair tech.
Mar 24, 2010 | Janome Memory Craft 9000 Computerized...
Where can i find an operating manual for an Elna Diva
Look up a manual for the Elna 9000. They are available on eBay and from sewing machine part suppliers. I used to sell Elna's, and they are the same machine. The first version (9000) had black face detail and buttons, which didn't sell well, so they just changed the facade to white with gold writing and renamed it "Diva." It is one and the same.
Mar 03, 2010 | Elna Sewing Machines
I have just purchased a second-hand Sercon Quickwash benchtop dishwasher. Is it possible to get operating instructions for this? The type No. is CB 2405050-6 and serial No. is 8350144.
Congratulations, you've just purchased one of the most indestructible dishwashers ever made. I ought to know, as mine is 35 years old, used at least twice daily and still going strong after only the addition of a door switch pushrod seal, a heater element and a water level switch in that time, although now on its third plastic door. They were often used commercially in labs for cleaning test tubes, etc. as the components were able to take the chemicals and punishment. Alas the plastic doors eventually crack around the hinges and need replacing but are no longer available so treat yours tenderly because if it cracks and can't hold water your dishwasher will be a boat anchor. You don't need an instruction manual, although I have one. Just use Finish dishwashing powder(no I don't own shares) and no rinse aid (the rinse aid dispenser is at the back and a pain to fill anyway and not necessary because you're using Finish remember?). Click on the water/waste pipe connector to the sink tap fitting, turn on the cold water, fill with dishes, sprinkle a capful of Finish powder over them, close the door and turn the timer clockwise ONLY to the Start position (about 1 o'clock) and wait about 20 mins til its finished (timer at about 11 o'clock) Then open the door to let out steam and aid final drying. All this with the toggle switch on 'normal' (and power plugged in and on of course dummy), although you can use 'economy' position for a few dishes or drink glasses, remembering that dishwashers will eventually turn glassware milky with that blasting action (ie not mum's best crystal) The Sercon Quickwash is a mighty mouse but noisy as it's not insulated around the single skin stainless steel cabinet and if the usual suspects aren't careful with bones, pips, stones, etc the waste pipe can become blocked, usually at the fitting near the tap and the cycle may stop with water still in the dishwasher. If it does, undo the hose and check for any obstructions, clear and restart. Farewell dishmop until the fateful day that plastic door cracks.
Feb 19, 2010 | Dishwashers
Resetting the key operator password
You must return the fax to factory defaults.
press
Function
7
monitor key slowly 4 times
* (asterisk key)
6
scroll down to SHIPMENT SET
set
set
wait for machine to reboot
Jul 27, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
Washing Machines Logo
138 people viewed this question
Top Washing Machines Experts
