Question about Mitsubishi WS-55807 TV
Mitsubishi WS-55807 tv and my x-box 360, no high def
My tv will not show xbox 360 in high def. I have the switch on the xbox set to high def and plugged into the 1080i out lets on the back of the tv. I heard there was some item i needed inbetween the two.
Its under the settings on the xbox system, in the dashboard.
Posted on Oct 09, 2007
SOURCE:
Mitsubishi WS-55807 Error Code 24 Vertical Deflection Failure. 5.
Hi. The service manual is in more than one part.
Schematics are in part 2 here:
Download Service Manuals for free
Jul 30, 2016 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807, screen removal / cleaning
Hi, thank you for visit fixya.
Pull out the speaker cover ( slow toward your self).
You will see screws in the middle , take it out ( maybe is 4 o 6 screws), be careful with any wires connect to panel control. Disconnect any connector to panel control. Pull toward your self , slow and slide up . Use a fine brush for best result, use glass cleaner liquid.
Any question, I will be here.
If you need additional help, please send me a picture front tv and I will show the right process.
Thank you
Dec 05, 2009 | Mitsubishi WS-55807 TV
Is my hd1080 that i bought about 8 to 9 years ago a high def
If your TV has HDMI inputs or if your receiver has component video out, then answer is yes. Please repost if you need any help.
Aug 30, 2009 | Mitsubishi WS-55807 TV
Xbox 360 sound but no picture can any one help
If you've just bought your xbox 360, then you probably haven't got a HDMI cable.
Which I think you could need.
Aug 18, 2009 | Microsoft Xbox 360 Console
High Definition--WS-55807
IF the MITS has 3 component inputs blue red yellow RCA jacks on the back then yes at 480 or 720p, you'll need to attach 2 audio cables for sound. If it has a HDMI input then absolutely.
please rate!
Mar 11, 2009 | Mitsubishi WS-55807 TV
I cant get high def 1080-i to work on my mitsubishi 55807
IYou have to have your comcast box tuned to a channel that is broadcast in HD. On your Comcast remote hit menu. This will bring up several icons, one is HD. Select that icon and it will bring up the TV Guide for just HD channels. Select one and tune to that channel. Once your on that channel use your original remote and hit menu, then advance features, then go down to video display and change it from 480 to 980 or 1080. Let me know if this helps.
Dec 15, 2008 | Mitsubishi WS-55807 TV
Cable box
Yes, this TV will need a converter box if you are getting off-the-air reception. It does not have a DTV tuner built in (too old) although is a high-def capable set.
Dec 06, 2008 | Mitsubishi WS-55807 TV
Can't get my TV to go to 1080i
Your tv is either 1080p or not 1080 compliant. Try 720p or you may be forced to keep it at 480
Dec 25, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Cannot get my tv out of 480
you have to go into the xbox 360 settings and change the output screen resolution to 1080i and also check your tv settings input to receive 1080i also.
Sep 10, 2007 | Mitsubishi WS-55513 55" Rear Projection...
HD resolutions
Your TV would have to be HD ready and will automatically set itself to 1080i, but if you go into the XBOX 360 console settings' the top menu enables you to change resolution, but if the x box does not recognise 1080i it will not show up. See if 720i shows up as this is still High Def. and also that 60 Hertz is the setting and not 50 hertz
Dec 30, 2006 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55807 TV Logo
109 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
