Omal coin scale
The scale got unplugged and now the screen says " pc not connected". What can I do?
I have 1969 no mint what is it worth? ????
Numismatic Value: 1 cent to $15.00
Value: As a rough estimate of this coins value you can assume this coin in average condition will be valued at somewhere around 1 cent, while one in certified mint state (MS+) condition could bring as much as $15 at auction. This price does not reference any standard coin grading scale. So when we say average, we mean in a similar condition to other coins issued in 1969, and mint state meaning it is certified.
Apr 06, 2017 | Cars & Trucks
Laptop is probably 6yrs old, stays plugged in at all times since it has no battery, I unplugged it to move it for printing now it won't start up,
Coin Cell Battery Probably Dead (usually In Memory Compartment) Bios Memory Dead Renew Coin Cell Battery--Boot To Bios And Reset--Then Save Changes.
Mar 23, 2015 | Computers & Internet
How do I unplug the abs and tc on a 2000 cavalier 2.4
If you have an autozone ,or omally's they can scan and reset let you know what needs to be replaced. free scan
Feb 22, 2015 | 2000 Chevrolet Cavalier
Logik log32lw782
Go to settings resolution and try to play with it. See which is the best fit for your screen.
May 09, 2014 | Computers & Internet
Operating instructions for Volt -100 pocket scale
If you don't have the measured weights that sometimes come with scales or can be purchased individually, I'd recommend using a United States nickel/5 cent coin. They are supposedly an exact 5 g's each, and a Volt-100 scale requires 100 g's for recalibration. Therefore, you can recalibrate your scale using 20 nickels. I also use a Volt-100 and so far this has worked for me exactly; the most it's ever been off is .02 g, which is basically nothing.
What you do is remove your batteries, (I'd replace them with brand new ones if you have the option) then place the scale on a completely smooth, perfectly level, flat surface. Power the scale on, make sure it is reading 0.00, hold the M (mode) button until CAL comes on the screen, release the button for a quick second, then press it again one more time (quickly, don't hold this time), and then wait until "100.00 g" is flashing on the screen. Then you're going to place your 20 nickels on the scale as smoothly and with as little jostling or movement as possible. After a moment, the screen should read out "PASS". You then power the scale off (don't weigh anything before turning it off as it can possibly adjust the calibration you just set or weigh out heavily or light) and to test out your newly calibrated scale, turn it back on and weigh one nickel. It should be exactly 5 g's, with no more than a .02 digression in either direction if done properly. Good luck!
Jul 07, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
If there were 8 coins of the same weight kept on 1 side and one coin of different weight but biy mistake the coin of the more weight gets mixed in those coins .we have to find the coin using top pan...
Compare any 3 coins vs and other 3: If the weight is the same, weigh the 2 remaining coins. If one side is heavier remove the lighter 3, and compare 2 of the 3 from the heavier side: If they weigh the same, the one not weighed is the odd coin, if the weight is different, you have found your odd coin on the scale.
Feb 28, 2011 | Video Game Consoles & Games
When i try to weigh something on it it displays 'our2'. And does not work
OUR2 is probably OutZ or Out2, means you have to recalibrate your scale. Refer to your scales manual for instructions on recalibrating, usually you have to turn on your scale, press CAL button, wait till it displays for example 100g, depending on how much your scale can weight, then put that weight, for example 100g on your scale (you can use coins if you don,t have anything else, though be precise as coins can weigh more or less,informationon coins weight can be found in your country national bank site. After you put the weight, it should display OK or PASS, if it's FAIL or the scale turns itself off, it's either broken or the weight is not correct
May 16, 2010 | Microwave Ovens
Conair ww39 glass bathroom scale won't work- batteries in wrong maybe? Help please!
Googled around until I found specifications for an unrelated brand of a similar bathroom scale. It mentioned making sure batteries were flat side uppermost in their compartment, which did the trick.
Sep 25, 2008 | Health & Beauty
Equinox EX-300 Digital Scales OUR2 comes up on the screen when i turn it on
turn on your scales press and hold mode until cal flashes up the press and hold again until 100.0 flashes then put a 100 gram weight on it then will say pass if you havent got a 100 gram weight i used 14 2pence pieces and and a penny and thats it mine are working spot on now you can repeat the above when you get a 100 g weight but the coins are more or less **** on
Aug 14, 2008 | Computers & Internet
24 people viewed this question
 Grubhead
Grubhead
