Question about Electrical Supplies
Where is the oil filter on a 2000w gentron generator
4 Suggested Answers
  • 6468 Answers
SOURCE: Gentron 10000w portable generator w/electric start cranks but wont start
check for low oil some have a low oil shut off system
Posted on Oct 15, 2012
claudeinmo
  • 9098 Answers
SOURCE: Where can I get an owners manual ?
PDF]10000W Generator
scene7.samsclub.com/is/content/.../GG10020-Eng%20manual-cpdf
Gentron/UPC will repair or replace, at Gentron/UPC's sole option, products or components ... Expendable parts or accessories supplied with the product which are..... FILLED WITH OIL OF A HIGH QUALITY SAE 10W-30 GRADE ENGINE OIL.
Gentron - 10000 Watt Gas Generator with Electric Start
www.samsclub.com > Sam's Club > Emergency Supplies
Sam's Club
Rating: 4.4 - ?330 reviews
Gentron 8,000W / 10,000W Portable Gas Powered Generator with Electric Start ...... 1 year parts and labor limited manufacturer's warranty; For issues not ...
Gentron Pro2 10000w Gas Generator (GG10020)
https://generatornow.com/gentron-gg10020-pro2-10000w-gas-powered-...
Gentron GG10020 Pro2 10000w Gas Powered Portable Generator with Electric ... It's a one year/1000 hr parts and labor warranty for our residential customers.
Posted on Jan 21, 2016
adamplug
  • 197 Answers
SOURCE: ,How do i get a manual for this unit, Gentron pro2 generator welder manual pdf
Gentron Pro2 Owner Manual
Posted on May 09, 2017
Can the oil stay in my Gentron 10,000 watt generator for any length of time? Or do I need to drain it every time even if I only use it for an hour?
You change the oil after used for a certain period of time. If not used often you do not change the oil as often as in a car. The manual you have will give you so called recommended intervals which in most cases are a tad too often.
Sep 04, 2017 | Gentron Electrical Supplies
Gentron 10,000 generator will not start.
Spray starting fluid into the engine air intake and see if that starts it, if that does then you have dried fuel clogging up the works.
Nov 21, 2016 | Gentron Electrical Supplies
Gentron generator has low voltage
By 3000rpm try with a tachometer ? to know the right rpm.
If 3000 rpm +/- was correct A other suggestion it can be sometimes the voltage regulator damaged by faultering connection slide connectors ???? sometimes on some brands used they are terrible and still new from factory.
Oct 07, 2016 | Gentron 10000w Portable Generator w/...
You must be more specific. Here's a link to a .pdf manual for A Gentron generator; perhaps you may find your generator manual within this thread.
http://www.searspartsdirect.com/partsdirect/user-manuals/GG3500-Gentron-GENERATOR-manual
Mar 06, 2016 | Gentron Electrical Supplies
Sam's Club
Rating: 4.4 - ‎330 reviews
Jan 21, 2016 | Electrical Supplies
Try this again. Starter works fine, checked fuel line,sprk plg and cln carb, just doesnt fire
Try checking your oil sensor. These are common problem areas that will shut your generator down, and prevent it from starting.
Oct 28, 2015 | Gentron 10,000W Generator with Electric...
How do I wire the on/off switch on a gentron 10,000 generator?
Give us a call when you are with the Generator and we will run through it with you. Call your local office and speak to an engineer: http://www.generatorguru.com/ask-the-guru/
Generator Guru
Sep 24, 2015 | Gentron 10,000W Generator with Electric...
Generator will start but won't keep running
If it starts nicely and then stops, check the oil. There is probably a low oil shut off that is being activated. It may also be the oil pressure switch itself. If it starts and runs rough then dies, it is most likely a carburetor issue, and likely related to old/bad fuel.
Aug 13, 2014 | Gentron 7200w rated 10000w peak heavyduty...
Gentron gg3502d outlets have no power
First verify that the breaker for the outlets is not tripped and make sure that the generator is running at full operating speed. let it run for 5-10 minutes and check for output power. If there is nothing, there are two possible problems. One could be that the automatic voltage regulator is bad. The other is that the field needs to be flashed - a high possibility if the generator has not been run in a long time. There are many videos on the internet that show you how to solve both of these problems. Just do a search for No output from a portable power generator.
May 24, 2014 | Gentron 10,000W Generator with Electric...
Electrical Supplies Logo
18 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
