Question about Car Audio & Video
Kenwood kac 626
The amp is not sending signal to my aamp. the red light flashes on nd off when I try to use it.
KaeZoo
  • 156 Answers
SOURCE: Amp Trouble
Actually, it's more likely that the problem is on the outside of the amplifier than the inside. Your problem may be caused by a ground wire that's come loose from the grounding point, a defective fuse or corroded connection on the power wire, an overload of the remote input wire, or a problem with the head unit that your amp is connected to. The easiest way to troubleshoot is with a voltmeter. Test the voltage at the amplifier's main power terminal and remote terminal while the meter's black probe is connected to the ground terminal. If you find voltage dropping on one of the terminals, you can focus your attention on that wire.
Posted on Mar 09, 2007
SOURCE: kenwood kac 859 amp
The amp will reset every time it's turned off. The red light flashing, instead of staying constant is a warning that one of the protection circuits are activated. If the amp is bridged wrong, it can do this. If the load impedance is too low, it can also do this... don't trust the speaker, it it says 4-ohm, it may actually be 3.8-ohm, which could cause a problem if two speakers are wired in parallel. If it's not getting enough power, it will turn off briefly, but will turn back on after a second. A capacitor is not necessary with this, just use 4 gauge cable and have a good battery... make sure the ground is good, that one is commonly ignored.
Posted on Aug 21, 2007
  • 5 Answers
SOURCE: Kenwood KAC-8103D Power Amplifier wont turn on
it sounds to me like its burnt.but with some amps the screws that hold it in place have to be screwed into the car chassisfor grounding. be careful not to srewe into hidden wires.
Posted on Apr 15, 2009
etirbynnor
  • 655 Answers
SOURCE: To bridge a Kenwood KAC-9102D
Hello laurogleal,
The Kenwood KAC-9102D is a mono amp. There is no bridging. Having two sets of terminals is just a more convenient way of connecting two subwoofers. The amp is stable down to 2 ohms impedance, so it is safe to run 2 4 ohm loads in parallel.
Hope this helps.
Posted on Apr 28, 2009
djmaximus_87
  • 26 Answers
SOURCE: kenwood kac-x1r flashes code e-03
HI DUDE EVERY REMOTE WIRE THEY HAVE FUSE NEAR THE BACK OF PLAYER TRY TO CHANGE IT .... R...TRY UNPLUG UR AMP .. AND ..FIX IT BACK
Posted on Jun 23, 2009
My Kenwood kac9152D turns on but why dose the red light on the top keep flashing?
The manual only says the power indicator burns when the power is on.
I can't find anything about it also should flash. The only thing I can think of, it has detected an error, like a blown amp or a low impedance on a speaker terminal.
Here is the manual:
http://images.kenwood.eu/files/prod/29/5/KAC-9152D_9102D_8152D_8102D_(EN).pdf
Jan 17, 2015 | Kenwood KAC-9152D Car Audio Amplifier
Red Light
that means you probably have a shorted speaker wire, a bad speaker or the amp itself is bad, try disconnecting the speakers one at a time and see if it turns on or not. if the red light stays on with no speakers hooked up it means the amp is bad
May 30, 2009 | Kenwood KAC-7252 Car Audio Amplifier
Kenwood kac-x1r flashes code e-03
Apr 16, 2009 | Kenwood KAC-X1R Car Audio Amplifier
Amp Problems
Unplug the stereo input signal from the amp. If the amp does not do it with the wires unplugged, you may have a problem with the radio sending too much voltage to the input of your amp causing it to go into protect mode. If it continues it is in your power source to the units. Let me know and I'll see what Ii can do. Hope this helps...
Jul 14, 2008 | Kenwood KAC-859 Car Audio Amplifier
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
