Question about Vivitar ViviCam 5385 Digital Camera
ViviCam5385 Won't Turn On
I took a picture and it just shut off. I thought it was because the battery was dead, but I tried replacing the batteries a few times and it won't turn on. It isn't showing any signs that it works at all. Anyone have a solution? Also, does this camera have a reset button? Where?
  • 1 more comment
  • Anonymous Aug 02, 2008
    camera won't turn on even when connected to the ac power adapter
  • Anonymous Aug 13, 2008
    new batteries fitted starts up then switches off lens does not retract untill new batteries fitted tried to switch on red light appears
  • donald_g72 Aug 18, 2008
    wont turn on even after new batteries
  • 3 Answers
There is a small watch battery inside the camera that cauld reset the camera's bios but you will need to desolder it and i dont think you want to go that far.
Posted on Sep 16, 2007
I have a 2003 Buick century and my battery keeps
the voltage regulator in the alternator is not shutting off.
Dec 21, 2014 | Cars & Trucks
Battery is new, engine won't turn over.
The voltmeter should only go as high as 14-15 volts when the engine is running. I would check for a poor connection between the battery and starter.
Oct 10, 2017 | Jeep Grand Cherokee Cars & Trucks
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
Camera was low on battery. Took a couple of pictures with no problem then got it home to charge the battery and the camera is dead. Won't turn on or charge. Tried plugging it in directly with the...
1. Check if the battery is positioned and seated well in the camera.
2. If OK, and problems persists, exchange the battery and recheck.
3. If that does not help, your camera needs probably to be repaired.
Aug 05, 2011 | Olympus SP800UZ Digital Camera
My Kodak EasyShare C180 10.2MP Digital Camera is less than a year old and suddenly won't turn on. I thought the batteries were dead so I replaced them...twice...and tried changing the direction around...
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jul 06, 2011 | Kodak EasyShare C180 Digital Camera
Battery
A battery with a dead cell will not charge. Remove battery, take to Auto Zone get it checked. If battery is dead, replace with the best and biggest CCA available. Only cost $1.00 to go first class.
Mar 10, 2009 | 2006 Subaru Baja
Camera will not turn on
Like dotball said, It looks to me like the batteries have gone dead. First charge the batteries and if that doesn't solve the problem, try new batteries.
Feb 06, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
Not turning on and has strange smell
Powershot A640 Could Not Be Powered On, Burnt Smell
My Powershot A640 died during a picture shot, lens remaining open. I thought it may be due to the dead batteries. But after putting new batteries and pushing the on/off button, the on/off indicator blinked once then shut off by itself. After a while, a strange smell came from camera batteries area, and I could feel warm there too. Immediately I took out all the batteries from camera.
When checking the posts here the other day, I tried one solution and got the lens back to close: first took out the memory card from camera, then put the new batteries in; push the on/off button with no memory card. I found the lens retracted a little before camera shut off by itself. I pushed on/off button three times to get the lens fully close. However, the burnt smell came out again. I immediately took out the batteries.
Did I get a short circuit inside? Is there any ways to fix it?
Oct 31, 2008 | Cameras
Kodak easy share z612 will not turn on to take a picture
When the battery dies, usually the camera will retract the lens if possible. If the battery is so dead the lens can not retract, I would recommend trying to charge or change the battery. Or try to turn the camera on, and then manually shutting it off if you can.
Nov 16, 2007 | Kodak EasyShare Z612 Digital Camera
Vivitar ViviCam 5385 Digital Camera Logo
99 people viewed this question
Top Vivitar Cameras Experts
Tony
SHARCNET-USA
SHARCNET-USA
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
