Question about Lasko 2517 Tower Fan
Lasko 2517 tower fan fuse - Lasko 2517 Tower Fan
  • 883 Answers
SOURCE: Fan will not work
open it. look for a wire that has become disconnected from careless factory assembly
Posted on May 20, 2007
SOURCE: lasko tower fan with ionizer
Try a can of compressed air. It's impossible to get inside.
Posted on Jul 22, 2008
SOURCE: LASKO fan problem
Check for a loose wire in the wiring harness
Posted on Sep 04, 2008
  • 3 Answers
SOURCE: Lasko 2554 Wind Tower Fan
I have a Lasko HVB, but this might apply to your fan:
Without taking the thing totally apart, here's an idea you can try: The power cord on some models (like mine) has a "warning" tag. I had the damn thing all apart when I noticed this. (Well, who reads 'em??) Seems like there's a mini-fuse in the PLUG itself that, when it blows, there's nothing you can do about it except send it for repair to a factory authorized yadda yadda yadda. Who's going to do that??
If you plug in and NOTHING HAPPENS, here's what might turn out to be an cheap and easy fix: cut off a few inches of the plug end of the cord and go buy another plug at Ace. Heavy duty might be appropriate: don't think I'd want a lamp plug on this baby. Get one that's easy to install. Bring the cut off piece and they'll help you find exactly what you want.
If you want to open it up, there's a screw behind the Lasko medallion, remove that and you can snap out the grille. You can see where the cord comes in from the back of the blower housing. Test the line voltage. If you're not getting about 120VAC, it's the plug.
If that's not it, IMHO, without some knowledge or a schematic, you're screwed. That'd be me. It wasn't the plug.
-Chuck
Posted on Sep 22, 2008
SOURCE: lasko ionizer tower fan works but does not blow
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} I had a similar fan which quit. I could sometimes get it to start spinning by banging on it. Finally took it apart. Lots of small screws, all small phillips. As I suspected, the "thrust bearing," which supports the rotating components, had become "stiff." I thought that it would be a non-friction (ball bearing), but it is only a bushing, with washers supporting the shaft. With the motor opened up, I greased the bearing with petroleum jelly, and reassembled everything. It is spinning very quietly now. Final comment - this is probably more work than the average fix-it person would want to take on, but it is doable. It took about two hours, start to finish. I could do it in less than one hour now that I know how to do it.
Posted on Aug 30, 2009
Lasko 2510 tower fan fuse
Follow the power cord. If they have a fuse, it will be attached to the cord.
Jul 02, 2012 | Lasko 2510 Tower Fan
I cannot open to clean
There are two screws in the handle remove them and the back panel comes off if they are tower fans
May 30, 2012 | Lasko 2517 Tower Fan
My Lasko 2517 tower fan won't turn on. Have tried
Here is my problem. MY Lasko 4820 Model, is having issues with starting up. Example I turned it on and the rotation stand that moves the tower works. But the fan motor or something realetted is not moving. The fan itself won't move on setting 3, 2, or 1. I don't use the ionizer (I have a smoke detector that picks ionized things and smoke) in my room. I've looked at similar issues or the same and a is different in some way or issue. I've never taken it apart, and one more thing I don't have any solutions because I bought it atva Thrift Store for $29.99 and dident know if someone broke it possibly in the past. No remote either. It has 5 buttons. Middle: Power. Top right: Ion. Botten right: Fan speed/setting (3, 2, 1) Top left: Timer (1hr, 2 hr, 4 hr.) Bottem left: Rotation for whole tower. Please Post anything that may help. Please do NOT respond with "Thats you're fault for buying it at a cheap junk sore" and something related to Criticizing me for getting it at a place that has used items. I know that, just give anything that Will help this issue.
May 16, 2012 | Lasko Dryers
Have 2 fans (1) Model #2517, (1) Model #4822. What is the best way to clean these two fans?
well take the cover off and take the oscilater which the long thing that gives u air out and take a soft brush to it
Aug 13, 2011 | Lasko 2517 Tower Fan
How do i take apart and clean my 2517 lasko t.f.
I took mine outside and hosed it down real good and then let it air dry for a day or 2. worked great! it was filthy!!! and that dang screw made it impossible for me to fully take it apart to clean it, so I decided it was either the hose or throw it away. mine was incredibly dusty and i was able to use a hose with a power nose and spray it really good. we'll see how long it works :)
Apr 30, 2011 | Lasko 2517 Tower Fan
It turn on , revolve but no air comes out
I am having the same problem. Did you ever fix your fan?
Aug 29, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
Lasko ionizer 48" fan
Hi suedevito,
In case an electrical appliance does not do anything anymore, I always first check the fuse(s). There can be a fuse in the electrical plug (in case of UK-type of plug for example) and possibly also somewhere within the fan's housing. In case you do not know how to measure a fuse, just simply replace all the fuses in one go with a new fuse of the same (!) rating. I hope this will solve your problem.
Nov 08, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
I have lasko fan sudenly it stoped oscillating can u help me with this ? Lasko 48" Xtra Air Tower Fan with Air Ionizer.Model 4820
I have the same issue, i determined the oscillating motor has a bearing failure. I need to find a replacement motor.
Jul 17, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
-Chuck
Jun 08, 2008 | Lasko 48" Xtra Air Tower Fan with Air...
Lasko tower fan with ionizer
Apr 21, 2008 | Lasko 48" Xtra Air Tower Fan with Air...
Lasko 2517 Tower Fan Logo
54 people viewed this question
Top Lasko Dryers Experts
Shehu Pro
Shehu Pro
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
