Question about Konica Minolta bizhub Office Equipment & Supplies
Bizhub 20 says scanner locked and the switch is on unlock; won't copy from scan glass, how do we fix?
    Sergeant:
  • 180 Answers
Reinstall it
Posted on Sep 08, 2016
  • 279 Answers
SOURCE: Dell Photo All in One Printer 964-scan/copy problem
This sounds like a problem I've had with a Lexmark scanner. It turned out that there was a switch on the bottom of the scanner that would lock the mechanism in place for shipping. Do you see anything similar on this unit, or am I barking up the wrong tree?
Posted on Aug 28, 2007
SOURCE: Samsung SCX-4720F reads "SCANNER LOCKED" and won't copy or scan.
the lock is underneath the scanner where the printed paper gets delivered. when you reach in to get a printout you more than likley have pushed it into the lock position.
Posted on Jan 06, 2009
  • 15 Answers
SOURCE: Konica Minolta Bizhub 350
You are getting a failure sheet. This happens when the scan doesnt go through. I think you are reffering to SMB scanning, which needs to have the following setup on both the MFP and the copier.
Host ID or NAME - IP address or hostname with DNS resolution.
Share Name - This is your SMB share name or folder share name on the remote PC
User Name - This is an account that is configured on the remote PC
Password - This is the password for the account setup on the remote PC.
Some things to keep in mind: Third party firewalls can block the bizhub from writing files.
Set share permissions to full control. (under sharing tab> permissions buttion)
Set NTFS permissions to at least write access. (if you have a "security" tab on the shared folder.
Or, you may see something like "allow network users to change my files" on the sharing tab. This basically does the same under different configuration scenario.
One last thing. If you havent changed anything since the problem started, it is probably just something like an expired password on the account that is setup for the copier.
Good Luck.
Posted on Jun 09, 2009
SOURCE: dell laser mfp 1815 dn "scanner locked" message
When you lift the scanner lid look to the left bottom. you should see a green slider button. If you stick your hand in the output tray and get it rigth under the green slider you will find a lever. Move that thing backwards or forwards, that is your unlocker.
Posted on Jul 20, 2009
  • 23 Answers
SOURCE: Sanner is locked!
Service Manual at
http://hotfile.com/dl/28988134/55113fe/CLX-3170-3175.zip.html
Posted on Feb 17, 2010
Where is the sensor lock switch?
The scanner lock is situated at the left side of the flat bed scanner. switch it to UNLOCK.
Sep 04, 2014 | Oki Brand Oki MB480 MFP Multifunction...
Bizhub C652 has horizontal lines.
its important to find out whether the \'lines\' are in scan direction/ or only through Radf or only from scan glass,
if the lines are only showing when documents are fed throught the Radf, then the problem lies with the document scan plate( left of the main glass platen (about 2" in width)) or with the scan plate blade cleaner
if the lines ONLY appear when copying from the Glass then the issue lies within the optics (probably nothing more than a clean will be needed)
another question would be to ask if the lines are solid (black line overprinting image) or if they are \'missing\' lines where the image has failed to copy, sometimes it can be hard to work out which side the fault lies,so try shaded greys as a copy original .
if the scan lines are appearing on both Radf and Glassplatten ,mode then the issue may be dirty optics/ccd sensor or it could e an indication of the ccd failing or image control pwb in error while interpreting the image file.
what to do
1) place a grey sheet of paper in the Radf and have the copier photocopy both sides of the original and print to single sided sheets ( so the printer turns the original over to complete the task)
observe the result.
2) have the copier photocopy directly from the platten glass- single sided.
observe the result.
ckeck to see if the error has appeared on both sets of prints ,
if the error has only appeared in the first set of prints then the issue may be a tiny DOT on the slit glass (left of platten) - a dot on this glass will indeed appear as a Line as the original is scanned across the glass.
hhope thhis helps
Feb 19, 2014 | Konica Minolta Bizhub C652 Color&b/w...
Why does lines appear in my printed copy?
If you're getting lines, especially when making copies or scanning, it could be due to some dirt on the scanner glass. Wipe your scanner glass with a lint free cloth. Then try scan or make a copy again to verify that the problem is fixed.
Mar 04, 2012 | Lexmark X1150 All-In-One InkJet Printer
Printer will not scan ( says scanner locked) it is not locked also will not copy from glass either
Open the latch on the front of the unit above where the paper comes out, underneath the lid on the right side is an orange switch. Flip the switch, turn off the until, wait about a minute and turn it back on. The scanner is physically locked by this switch. I believe the proper position for unlocking is towards the front of the unit, but the diagram is underneath the lid next to this orange switch.
Jul 12, 2010 | HP OfficeJet 9120 All-In-One InkJet...
Scanner bar will not move to scan the paper to be copied.
a piece of plastic locks your scanner in place, it is under the scanner up above where the copies come out. It turns 90 degrees.
Maybe some one turned and locked it.
Good luck
Bob
Apr 23, 2009 | Sharp AL 1631 Copier
Light bar does not move. copies come out blank
Have you verified that the scanner is not in the locked position? There is a unlock switch located underneath the paper exit. First power the printer down lock and then unlock this switch then repower the printer and try your scan again.
Mar 23, 2009 | Xerox WorkCentre M20i All-In-One Laser...
WHAT DOES A L1 MEAN
The L1 is indicating a scanner lock.
1. Turn machine off.
2. Make sure the scanner lock is unlocked. This is a clear plastic knob. (it is located on the left hand side of the machine under the document glass in the copy exit area - check your manual for a picture.)
3. Turn machine back on, watch scanner to see if it moves.
4. Try a copy.
5. If you still get an L1 then it might need service because the scanning bar is jammed.
This also is a fix if you are getting blank copies.
Hope that helps...
Jun 23, 2008 | Ricoh 3310LE Copier
Where is the scan head locking switch
hi dear
Release the scan head locking switch.
The scan head locking switch is under the document glass.
If the switch is locked ( ), the machine will not operate. Unlock the switch
oke
cropp
Mar 19, 2008 | Sharp SHP AL1655CS Printer, Scanner,...
Scanner Imaging problem
Your scanner’s lock switch may be locking up the carriage unit. Depending on the model you own, your scanner’s lock switch resides in one of two locations. You can find it beneath the scanner itself or in a corner next to the scanner bed after you lift the lid. The switch should be marked with a locked and unlocked padlock symbol; slide the switch to the unlocked padlock to unlock the carriage unit.
It’s also possible that the supplied USB cable is improperly connected to your computer. Connect the cable directly to your PC. Canon’s online documentation indicates that scanners that connect via a USB hub may not work properly. Once you have unlocked your scanner and properly connected it directly to your computer, try to rescan the image.
Mar 01, 2008 | Xerox WorkCentre PE120 All-In-One Laser...
Copier Locks up L1 Error Code
there is a locking dial under the left side of the machine that maybey holding the scanner in home position.... be sure its unlocked.
Dec 09, 2006 | Sharp AL 1631 Copier
131 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
