Question about Emerson LC320EM2 32" LCD HD Television
Emerson tv closed caption wont turn on
Have turn on thru features doesn t work
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: Emerson tv light repeatedly flashes green then doesn't turn on
This sounds like a very common issue.
If set is hard to turn on (takes several tries)but will eventually turn on hereis what my guess would be.
Every set has a standby power supplythat is running 7/24 if the set is plugged in and it supplies voltage to theremote circuit that turn on the main power supply for the tv and hence turn theset on.
This is an area where companies cut corners by using lower rated voltage caps.By this I mean Standby usually provides under 10 volts to trigger the seton----what they do is use filter caps rated at say 10 volts max in a circuitwith 9 volts (example)=with the standby on all the time the filter caps(electrolytic caps) dry out and fail.
The problem usually begins where you have to turn set on or or two times andgradually gets worse--takes longer and more tries to get it to come up.
Once on it will stay on until turned off for a period of time.
The caps will begin to work better (regain some of thecapacitance) as they get hot--hence one it is on it will seem ok.
The beauty of this problem is most of themhappen when set is a year or two old (no warranty) and all you have to do islook at the top to locate bad ones.
They are generally black or blue and round and vary in --they have twoconnections each--a + for positive and a - for negative--not unlike a batterywhich in a way they are. The + and - are marked on top and bottom of most boards.
They are easy to replace and not expensive parts.
The tops are silverand metal looking with creases on top and if bad they will be puffed up ontop---tops must be perfectly flat with no brown material leaking top or bottom.
If this is your problem once you id them (make a drawing) you can begin.
Here is the critical part---on each cap is also marked the value like 220uf 10vdc---220 micro farad at 10 volts maximum.
If you find for example 6 puffed up and all are 10 vdc replace them with thesame value capacitance (like the 220 uf) but go up to at least in this case(from 10 volts) to a 16 or higher rated voltage cap.
The only issue is when you go up in voltage rated value the cap is larger sosometimes there is an issue of physical space for the replacement on the boardto fit them in.
The reason they cheapen these sets in this way is if 10 caps and you make25,000 sets there is a considerable savings in parts cost.
They do not care as long as it lasts past the usual one year parts warranty.
I have taken the time to be long winded because this really sounds like it maybe the problem you have.
See attached photo of a typical cap and if you have questions or need advicelet me know.5_14_2012_1_45_04_pm.jpg
Posted on May 14, 2012
I have no remote, how do I get off close caption on a TS2554C101
There is a Menu button on the TV for the TS2554 C101. Press this button to get the OSD menu. Then press the vol +/- buttons to highlight Set. Use the Ch +/- buttons to get Closed Caption. Then press Vol+ or Vol - to get the closed caption menu. Use the Ch+/- buttons to set the desired closed caption setting and then press Vol + or Vol - to confirm the selection. Press Menu again to exit.
This will only help if the captions are being interpreted by the TV. If there are open captions, they will not go away. If the closed captioning is on at a set top box, you will need to turn them off using the controls for the set top box. (I know satellite receivers have independent captions available.)
I hope this helps. If your TV doesn't have a menu button on the set, you will need a remote that has a matching Menu function. Some universal remotes should have this feature.
Apr 28, 2011 | Philips TS2554C 25" TV
Cant turn off closed caption
sherrillbrom
With our VIP receiver models, you have an option to turn on/off closed caption through the receiver. Press the Menu button on the remote, which will display the Main Menu on the TV screen. Press 8 (Preferences) and then press 6 (Closed Caption). On the Closed Caption screen, press 1. On the Closed Caption On/Off screen, select CC Off and then press Done from the TV screen (using your DISH remote). This will turn the feature off on the receiver. Test to see if it is turned off by watching a program that has CC. If it still appears, then the feature is activated through your TV. Please refer to your TV manual to turn the feature off. I hope this helps.
Ray Calo
DISH Network
Feb 21, 2011 | Televison & Video
I have a Emerson (LC3203MC) "32 flat screen tv and on certain channels the closed caption in on, even with the captiions off, it still come up. How do I get rid of this?
If you have this TV connected to a cable box or satellite receiver, the captions may be coming from there. Some of these devices support captioning on their own, separate from the TV. Check the device setup to be sure captions are turned off.
Feb 14, 2010 | Emerson Televison & Video
Cannot turn CC off.
Features preferences
Caption service
This allows you to select the Closed Captions service levels of analog
broadcasting to be displayed.
Closed Captioning allows you to read the voice content of television
programs on the TV screen. Designed to help the hearing impaired, this
feature uses on-screen ‘text boxes’ to show dialogue and conversations
while the TV program is in progress. Captions will appear on the screen
during captioned broadcasts.
& Select Captions service.
é Press the cursor right.
“ Select the desired Caption service:
• CC 1, 2, 3 or 4
Dialogue (and descriptions) for the action on the captioned TV program
shows on screen.
Usually CC 1 is the most used. CC 2 may be used for alternate languages
if they are being transmitted.
• T 1, 2, 3 or 4
Often used for channel guide, schedules, bulletin board information for
Closed Captions programs, news, weather informations or stock market
reports.
Not all Caption services are necessarily being used by a TV channel during
the transmission of a Closed Caption program.
Features menu
& Select Features in the TV Settings menu.
é Press the cursor right to enter the Features menu.
“ Select the menu items with the cursor up/down and adjust the settings
with the cursor left/right.
Closed captions
This displays the transmitted CC- or CS-text on the screen according to
your chosen CC or CS service in the Setup, Features preferences menu,
This text can either be permanently displayed (assuming that the
service is available in the broadcast) or only when mute is active.
& Press the cursor right after having selected Closed captions.
é Select On, Off or On during mute.
Oct 28, 2009 | Televison & Video
By the numbers! How do I turn on the closed
there is no closed captions on dvds, you can use subtitles, very similar to closed captions. just load dvd
look into either extra features or subtitles
it would say "english for deaf/hard of hearing." or just plain english subtitle. either way, it works.
Oct 17, 2009 | Emerson EWD2203 DVD Player/VCR
I need to turn off my closed captioning and i lost
Emerson had individual buttons on there remotes just for the CC settings. You will need the original remote.
Oct 14, 2009 | Televison & Video
I have a black box going across my screen with blue numbers it will not go away. I have an emerson 32in hdtv flat screen
Make sure closed captioning is turned off on the TV as well as your cable box or satellite receiver (if you are using them and they have that feature). Captioning is probably on and set for text mode.
Apr 30, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Sylvania Superset II Closed Captioning
is there a cc button on your remote hand unit.if not its in the setup menu .
Mar 25, 2008 | Sylvania 6427TE 27" TV
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Emerson LC320EM2 32" LCD HD Television Logo
60 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
