Question about GE / Profile PFSF6PKXBB
Ge refrigerator parts water door model
Water collects on bottom of refrigerator
  • 126 Answers
SOURCE: Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Posted on Dec 14, 2007
  • 4 Answers
SOURCE: Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Posted on Jul 15, 2008
MNTECH
  • 1543 Answers
SOURCE: GE WMR04BAPBBB parts
These are not common parts, so would need to be special ordered. Any GE servicing dealer could get them for you, or you may be able to call GE answer center to get parts (1-800-626-2000), but don't expect any deal from GE on price or shipping costs. I looked up and found "door gaurd" rods for a WMR04BAPABB and they are WR17X10586, WR17X10587, WR17X10588, and WR17X10589 and all were in stock at GE parts. You may need more than one of some parts.
Posted on Sep 20, 2008
  • 35 Answers
SOURCE: no water from door dispenser
BAD WATER VALVE OR CHECK FOR CLOGGED FILTER
Posted on Jun 18, 2009
Sea Breeze
  • 4654 Answers
SOURCE: No water from door dispenser
This is most times caused by a defective dual water control valve on the back near floor of the refrigerator. Unplug the two wire connections and check both coils with an ohm meter. The both should read the same amount of resistance. Or set your meter on voltage and place the probes in each side of the plug and have someone press the dispense button. You should show the household voltage at the end of that plug. Sea Breeze
Posted on Jun 23, 2009
Water in bottom vegetable drawer and bottom of refrigerator ge profile side by side
This model has two evaporators, so Do you have an ice ball in behind the crisper (should be on the left)? Is there brown looking water going down the back and collecting under the crispers? I need two things, a complete model number (there is 8 different model with this number you gave) also where is the ice and water located? Thanks
Jul 25, 2014 | GE Profile PSW26P Stainless Steel Side by...
Water accumulating inside fridge bottom make GE Model #gta18pbnaww
That's normal especially if you tend to leave the door open alot. Moisture from the outside air condenses and drips to the bottom. Also, if the refrigerator is automatic self-defrosting it will melt ice collecting around the refrigerator and the resulting water will collect at the bottom. Check under the food drawers for a drain hole. If it is clogged, clean it out. If it doesn't exist, periodically sponge out the bottom under the drawers.
Jan 12, 2013 | Refrigerators
I have an ge french door bottom freezer model gfss6kkxass. it has started collecting water under the vegtable drawers and leaking down front of freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
ll
Sep 26, 2010 | General Electric GFSS6KKXSS Stainless...
My GE Profile PS123SGPA BS side by side keeps dripping water from the water dipenser
Frigidare Model FRS26H5AS Side by side HELP!!!
Water collects and freezes in the bottom of my Freezer eventually leaking out the freezer door.
Thank you!!! bstrickmaker@neo.rr.com
Feb 15, 2010 | Frigidaire FRS26H5AS Side by Side...
Water collecting at bottom of fridge. GE 17 Model 34769-3
pull bottom tray and look for hole in the back on the bottom try a clothes hanger straightened out and push thru hole
Feb 06, 2010 | Refrigerators
GE Refridge #tbx21jablraa Water collecting in
The defrost drain tube is plugged. Move the refrig out from the wall and remove the tube which goes from the center middle of the back to the bottom part of the refrig. Clean out the tube and check the part that goes into the refrig. That part usually comes off with a quarter turn or so, then pull.
Sep 24, 2009 | Refrigerators
GE Profile PSS26SGRB SS small water seep
under the trim there are 2 openings on on each side insert a flat head screw driver and twist so it will unlock and then it will be off hopefully you dont have to remove all insternal parts inside dispencer i will try one tomorrow at work and let you know
Oct 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE / Profile PFSF6PKXBB Logo
26 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
