Question about Peg Perego John Deere Farm Tractor and Trailer
Will not go in forward only in reverse.
Put brand new battery in and had power. The tractor would go forward but would not shift into reverse. Took shifter assembly out of tractor floor and could press switch down and it would go into reverse. put shifter back in to floor and secured it and tried again. Nothing at all. I again removed and checked the wires making sure all were connected and not being pinched. Put back together and only reverse / What do I look for? Thanks
  • Peg Perego Master
  • 1,508 Answers
Check to make sure that the cables are not binding when mounted causing them to break connection
Posted on Aug 17, 2017
  • 156 Answers
SOURCE: gator will only drive in reverse
I would replace the reverse switch as seen in here and also the high low switch for this peg perego gator.
Sometimes the high/low switch will cause it to not go in reverse, so I would replace both switches in the shifter just to make sure.
They are really easy to replace. You can call these guys
They know what they are talking about because they sell and repair them.
Posted on Apr 08, 2009
SOURCE: only goes in reverse after recent charging
I would replace the high/low switch and the reverse switch.
I had the same problem of it not going forward, but I just replaced the high/low switch. It turns out 1 month later I had to replace the reverse switch.
Here is the link to the site that I found my switches on.
Hope this helps
Posted on Apr 21, 2009
  • 156 Answers
SOURCE: I just put together a Peg perego Polaris RZR ride
For this Peg Perego Razor model, some of them have a lever that slips over the foot pedal to keep it from going in reverse for safety reasons.
I would check the foot pedal and see if it has one.
Let me know what you find.
Posted on Jun 01, 2009
  • 110 Answers
SOURCE: Hello, I purchased this Peg Perego Cub Cadet
yes, very common. probably the thermal breaker under the shifter. you can replace it with a 40 amp fuse or bypass it. dont worry its safe to bypass b/c there is a 30 amp fuse on the battery also.
good luck!
Posted on Jan 29, 2011
  • 70 Answers
SOURCE: gator wont go
No, just the shifter. Just to check you can exchange the red and blue wires under the pedal(just for a second or so, do not do this permanently) to see if you get power to the wheels, if so then yes it is Definitely only the shifter, but I am still pretty sure it is just the shifter. you can also call Peg Perego Tech support which is excellent and they can help you too 1800-728-2108 and parts can be priced and found at
Posted on Mar 02, 2011
Clutch pedal sticks while in f/r.
brand/model number please... either a spring issue or a variable speed pulley issue
Aug 31, 2014 | Garden
Why will my snapper riding mower not go into gear? forward or reverse?
does the drive pulley ( on the engine ) mesh with the driven wheel ??? the engine pulley has a specific height... this is the first test... also do not be afraid to stand this more on end... just take the battery out and shut the fuel off as well as the gas cap vent.
Aug 23, 2014 | Snapper Garden
Why won't my riding lawnmower shift into reverse?
Some mowers will not allow you to shift into reverse with the blades engaged for safety reasons. Try disengaging the blades then shift into reverse.
Aug 22, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My lawn mower model 425613x8a only drives in reverse what is my problem and how do I fix it?
I'am not to familiar,with this model number,of this tractor. But i do know that there is a safety switch,installed below the shift lever. Usually this switch,controls the neural,forward and reverse for your tractor. I suspect the forward motion contact is bad in the switch itself. You will have to remove the motion drive assembly and purchase a new switch,sometimes the safety switch is part of the whole assembly. You can find this assembly,under the shifting lever under the tractor,s floor. It could be on the right side or the left side depending on the location of the shifting lever.Sincerely,Brad Locke DTD 12/03/15
Sep 07, 2013 | Sears Garden
JD mighty mover tractor, 27MHz, 3 function remote 1. forward/reverse, 2. left & right, 3. loader bucket up/down Problem: no forward or reverse, front wheels turn left and right just fine, loader goes...
My son and I took apart the toy as we have the same problem with ours. The green terminal on the motor moves when we apply pressure to it and the motor speeds up considerably. It appears that a weak or bad terminal is the cause of loss of power. We are not sure how to maintain the pressure on this terminal.
We are going to put it back together and see if it works.
Apr 23, 2011 | RC John Deere Mighty Mover Dump Truck
No reverse and shifts hard if forward gears
best bet is call scrap yard they are fairly decent priced unless you want new
Aug 25, 2009 | 1996 GMC Jimmy
Tractor will not go in forward gear, only reverse.
Try rocking the mower forward and backward while you try to shift it.
Aug 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Recheck your belts, does your engine have a pto
Jul 28, 2009 | Garden
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Peg Perego John Deere Farm Tractor and Trailer Logo
42 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
