Question about RTO BE Pressure Washer Gun and Wand Assembly 59" with Fittings
Simoniz s1800 gun assembly is leaking need new washers
The trigger on my Ryobi pressure washer won't turn off and ter leaks out from it. Anyone know what the problem could be?
I had this problem as well. The valve inside the gun cracks causing it to leak. I repaired mine with fast setting epoxy and a hose clamp. Disassemble the gun taking note how the parts are assembled taking pictures helps. Look for the crack sometimes it is not very visible check the ends where parts come together. Mine was where the tube that the trigger connects to enters the tube where the hose connects to. Epoxy the OUTSIDE of the crack not inside the tube because it needs to be smooth in order for it to seal properly. Try to get some epoxy inside the crack then use the hse clamp to hold it together while the epoxy cures.reassemble the gun and test. Sometimes the O-Rings will need to be replaced oil the orings while assembling the gun to prevent damage to the orings.
Oct 25, 2016 | Garden
Gun leaking when i use my simoniz 1900 pressure washer
The simoniz 1900 gun is very poorly designed. It is held together by a dozen small screws.
First open the gun by taking all the small screws out. No worries, it is much more simpler and worse constructed than a 5-year-old toy gun.
After opening the gun, you will see there are only two parts inside. One at the front connecting to the wand, and one at the back connecting to the hose. The trigger is looped over the joint part.
Make sure the back part is firmly fitted into the slot properly, otherwise it leaks. And be careful don't lose the spring, because there is no object to hold it in place.
Now all you need to do is to put all one dozen small screws back in. Don't over tight the screws, otherwise they will punch through the plastic cover.
Now your simoniz 1900 gun is fixed but it leaves you wonder which 10-year-old designed it?
Jul 30, 2012 | Honda Water Pump 2 Inch IntakeOutlet 5 Hp...
Hello i have a s1800 simoniz washer pressure the pressure is realy poor, i have tried a lot of thing to fix it without success?
Try pouring liquid TSP into the fresh water inlet and letting it sit for a couple of days
Aug 14, 2010 | Garden
I would like to take apart my Simoniz pressure Washer
I have simoniz 1750 less than 2 years old it works,no leaks,but water is not coming out ,thank you for any tip.
Mar 31, 2010 | Garden
S1600 Simoniz gun - I took it apart and I have a spring left - where does it go? I need a schematic or something.
There are no schematics available because the manufacturer doesn't sell parts for the gun. The spring usually goes right into the end of the hose, then the little bullet like valve follows. Did you know you can buy a new gun for about $22.00 Canadian?
Aug 11, 2009 | Karcher Garden
Manual needed for Simoniz S1800 Pressure Washer
I contacted the Company in US.
Thank you for keeping in touch.
Jun 21, 2009 | Garden
I have a Simoniz 1900 presure washer and had to take it apart to fix it. I need to know how to put it together again as it has been awhile since I have had a chance to work on it. Can anyone tell me how to...
i took my pressurewasher simoniz s1900 apart, i had to take off the pump and all oil leaked out.
how and where can i fill the oil in to the pump
and what type of oil would i use
thanx ernte
May 17, 2009 | Garden
Looking for Owners Manual for Simoniz S2600
Hi my simoniz electrc power washer will not go off when I release the trigger , leaks trough the water inlet hose , I replaced the O rings but keeps leaking ..THANKS
Apr 21, 2009 | Garden
Simoniz s1900 electric power washer with no water pressure
What a jacka$$ response.
Do you think its the seals? wow that describes f**Kall!!!
Aug 19, 2008 | Electrical Supplies
RTO BE Pressure Washer Gun and Wand Assembly 59" with Fittings Logo
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
