Question about Samsung CLX-6260FD COL LASER MFP 25PPM GIGABIT ETH DUPLX USB2.0 SCAN COPY FAX 1YR WTY
Replace Transfer Belt
I need to remove transfer belt for trouble shooting
4 Suggested Answers
jaylex
  • 417 Answers
SOURCE: reset transfer belt samsung clp-300
Unfortunately you cannot there is a resistor on the unit that when you replace it it blows resetting the transfer counter.
Sorry
J
Posted on Jan 20, 2008
SOURCE: transfer belt error
Transfer belt error, this is cause by the OPC drum which connects the belt. Make sure the drum sit well with the belt else replaced the drum.
Posted on Mar 14, 2008
SOURCE: transfer belt errors
helped me and solved the lever and transfer belt. Actually it is the combined black toner cartridge and transfer belt. The side plate is about 3 inches long and has the two screws fixing it on. The sensor has a single screw fixing it, but in fact just looks like a black cover plate. Lever it out easilly at the screw end, not the other end which is impossible.
I just blew out the **** in the sensor, wiggled the white 3 pin connector, and since it has the look of a reflection based optical sensor, then I cleaned the belt along its edge with antistatic cleaner , ie tissue paper soaked and rotate the gear to move the belt round. There is a silver patch on the belt which passes the sensor once every revolution of the belt, and I gave this a particularly good clean as it is probably the only bit that matters.
Anyway, several black refills (hole and a bit of tape sealing it) later and the unit still works fine. Actually I always refill everything and just high pressure blow off the whole printer every so ofter.
Posted on Jul 03, 2008
Trouble shoot problems
Might be a bad transfer belt, pull the belt out and look closely at the end that goes into the printer first. If there is a bunch of loose toner there then the waste toner system is backed or clogged. If printer is under warranty, get HP to replace the transfer belt.
Aug 04, 2014 | HP COLOUR LASERJET CP4525DN Printer
Color Print Quality
In my experience, the fuser has always been the cause of the lines.
Jul 09, 2008 | Ricoh CL3000E Laser Printer
How to fix transfer belt malfunction
depending on which modle do a trouble reset or refuse the transfer belt if still no replace try trouble rest first though
Jul 04, 2014 | Konica Minolta Office Equipment & Supplies
My printer can`t print and shows me to 'Check the transfer belt'
Your printer monitors the life of your transfer belt. When the transfer belt reaches the end of its
life, the printer displays
80 Belt Exhausted. This message indicates it is time for you to
replace the transfer belt. For best print quality, make sure you replace the transfer belt when
80 Belt Life Warning.
Press
Go to clear the message. The Supplies message appears on the second line of the
display to remind you that supplies need attention. You can open the Supplies Menu to see
80 Belt Exhausted
or 80 Belt Life Warning messages.
The printer continues to display the
Supplies message until you replace the transfer belt. To
replace the transfer belt, use the following steps or the instruction sheet supplied with the
transfer belt.
Nov 26, 2012 | Samsung CLP-610 Series
Have a transfer belt error What to do?
To fix this error, you will need to replace the transfer belt and/or reset the transfer belt count on your printer. If you are happy the the print quality of the printer, then you can try to reset the transfer belt count and that will clear the error. Otherwise you need to get a replacement transfer belt and swap it out before resetting the count.
To remove your existing transfer belt, you need to open the front panel, and remove the imaging unit by pulling the green handle. The belt is located above the imaging unit. Pull the belt down to release and then pull it straight out of the machine. Take your new belt and slide the back into the machine and push the front of the belt up to lock in place. Then you need to reset the belt count.
To do this, follow the steps below.
1. Enter Tech Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press OK
6. Enter Password 1934
7. Arrow to Transfer Belt and press OK.
Hope this helps you.
Apr 02, 2011 | Samsung CLX 3160fn All-In-One Printer
How to fix transfer belt error in my samsung CLX3160fn
3. Select Tech Menu
4. Select DataSetup
Feb 27, 2011 | Samsung CLX 3160fn All-In-One Printer
Lexmark X500N says replace transfer belt, what is it, and how do I change it?
The transfer belt is located inisde the printer and is what moves the paper back out the printer. You will need to open the back cover of the unit then you will lift the top part of the printer off. This will expose the transfer belt. There is a bracket holding the transfer belt with two screws that will need to be removed. Then two more screws that are holding the belt assembly in place. Once those are removed then you can slide out the transfer belt assembly. The new replacement transfer belt assembly will slide back in replacing the old one. Then repeat the steps opposite to install. Then remove the four spacers on the new belt(on each corner). Then you will reset the counter for the belt and will need to run the printer alignment settings.
Nov 13, 2009 | Lexmark X500n Color Laser All-in-One...
I need to know how to replace...
The transfer belt cleanning blade is under the transfer belt.Remove 2 screw and change it.The bias transfer roller is mounted in two bushings,remove the bushings and 2 springs.The fuser unit : upper fuser roller,lower fuser roller and the cleaning rollers.
Aug 25, 2009 | Office Equipment & Supplies
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
Samsung CLX-6260FD COL LASER MFP 25PPM GIGABIT ETH DUPLX USB2.0 SCAN COPY FAX 1YR WTY Logo
191 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
