Question about Garmin zumo GPS
I have the following in my Zumo 550 inventory: Splash D0681-00 2.00 zumo Splash Screen FAIL (Fail is in orange). Prior to downloading 2013.40 via Garmin Express my 550 was working perfectly, afterwards any Address functions switched the device off. A fix was sent via the support desk to load 2013.41 via the old Garmin downloader, this solved the switching off fault but now I have chequered mapping areas, slow map resizing plus this inventory fault. Can you fix it please?
marcelbakker
  • 174 Answers
SOURCE: no road maps ( Zumo 550
Do you see a map, with street detail? Any SD card installed?
Tap the wrench symbol, tap mapping, tap about, any maps checked? if not, check the apropriate map and go back to the map screen
Posted on Jun 09, 2008
marcelbakker
  • 174 Answers
SOURCE: Zumo 550 - Failure of call functionality on Bluetooth
Try the garmin webupdater with the unit connected to the computer to see if your bluetooth firmware is the latest. Beware however, I lost phonebook functionality!
Posted on Jun 10, 2008
marcelbakker
  • 174 Answers
SOURCE: Zumo 550
You'll have to select the europe map and deselect the usa map. Also you might have to change the locales. to do the first thing
tap wrench/tap map/tap about there you should see both maps, select the one you need and return to the wrench menu, select locales slect change all and walk through the menus (especialy the country!!!)
marcelbakker
  • 174 Answers
SOURCE: garmin zumo 550 cannot find satellites
I'd remove the battery first, leave it out some time, put it back, fully charge it and use webupdater to see if all is up to date. There is a test menu on the Zumo to see if all works. I will tell you how to get there, only after you have tried the above first!
Posted on Jun 16, 2008
SOURCE: garmin zumo switch on problem
Use the allen wrench to remove the battery. Let stand for 5 minutes and replace the battery. It should start fine. Mine has done this 3 times since I purchased it.
Posted on Jan 30, 2009
When pressing letters wrong one show up zumo 550
Have you tried recalibrating the touchscreen?
To calibrate the screen of the Zumo 550, press and hold the power button for about a minute until the screen calibration appears.
Sep 21, 2013 | GPS
Zumo 550
is the battery working fine.
Oct 21, 2008 | Garmin zumo 550 GPS Receiver
When I turn my Garmin 550 on it says loading maps, then goes to the select a local: It's frozen their on United States i push OK and nothing happens can not change the Locale it's frozen I tried...
Hi tkfranks331,
Press the power key and hold it if the screen of your Zumo is frozen. Keep holding the power key while pressing the key that has a plus symbol ("+") on it. This will reset your device and unfreeze the screen. You can also try calibrating the screen by pressing the power key for one full minute.
If this does not work, please follow these steps.
1. Update the internal disk software. Download and install WebUpdater on the computer. Please visit this link to download the WebUpdater.
2. Open WebUpdater on the computer.
3. Connect the Zumo 550 to the computer with its USB cable.
4. WebUpdater will automatically search for updates.
5. Follow the prompts to download any pertinent updates for the Zumo 550.
Hope it helps.
Thank you for using FixYa.
Aug 17, 2011 | Garmin zumo 550 GPS Receiver
Zumo 550 User Guide
You can find the different user guides for this unit (in different languages too) to download on this page: https://buy.garmin.com/shop/store/manual.jsp?product=010-00567-00&cID=135&pID=414
Jun 13, 2009 | Garmin zumo 550 GPS Receiver
Garmin zumo switch on problem
Jan 05, 2009 | Garmin zumo 550 GPS Receiver
Can't end Bluetooth phone call with Zumo 550
I have a motorola phone, and it's fine.
I have paired the phone to the zumo, and the phone is set to connect to the zumo automatically.
Check the phone is set up this way, and all should be well.
Hope this helps.
Dec 24, 2008 | Garmin zumo 550 GPS Receiver
My touch screen has froze up & know matter what i do i can't the proble
Assuming that you cannot switch it off and on again, try removing the battery for a couple of minutes before re installing. Failing that a cold reboot my work ..... with the unit switch off press and hold the bottom right corner of the touch screen and the press the power button. The Zumo splash screen should appear....continue to hold the botton right corner until the reset default screen instrution appear and follow them. This has work in the passed.
If you have recently download a latest software via the Garmin web updater this can sometimes cause conflicts and you may need to re-install a prervious version. from the Garmin link attached.
http://www.gpsinformation.org/perry/zumo/
Sep 07, 2008 | Garmin zumo 550 GPS Receiver
No road maps ( Zumo 550
Jun 07, 2008 | Garmin zumo 550 GPS Receiver
Mar 04, 2008 | Garmin zumo 550 GPS Receiver
Connection problem between a nokia n95 8gb and zumo 550
I have recently purchased a Zumo 550 and successfully copied across selected phone book entries from a Nokia N95 without the need to use any additional apps:-
1) Assuming the N95 and Zumo are paired via BlueTooth
2) In N95 Contacts - use 'Mark' / 'Mark All' as necessary to select the contact entries you wish to transfer to the Zumo 550
3) In N95 Contacts - select 'Options' then 'Send Business Card' then 'Via Bluetooth'
4) Select the Zumo 550 device from the list of paired Bluetooth devices
5) Contact data is transferred from N95 phonebook to Zumo 550 phonebook
Interestingly, Garmin don't seem to list the Nokia N95 as being a supported device on their website, but the above process worked for me!!
Feb 15, 2008 | Garmin zumo 550 GPS Receiver
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
