Question about Kenmore 24 in. 15222 / 15229 Built-in Dishwasher
Dishwasher won't drain
I have a kenmore 363.15229 model that won't drain. It makes a clunk noise as if it is engaging the pump and it appears the solenoid pin is dropping but yet the water does not drain out. Is it the pump assembly and if so how diffifult is it to replace and/or does the part cost as much as a new dishwasher?
  • Needinhelp Dec 17, 2007
    I have a Kenmore 363.1404198 and it too is not draining well and is a leaking a little bit on the kitchen floor. I am not sure if the pump went out or if the discharge tube is just clogged wih old food. Do they all have a pump that extracts the water or do they ever work on a siphon principle? Thanks
  • Anonymous Aug 02, 2008
    not sure if the pump is broken, or if it could be something else. It's not the tube, and it is not the drain.
  • 641 Answers
SOURCE: dishwasher
Check whether the drain line was assembled exactly as per Kenmore's instructions. Good luck!
Posted on Sep 11, 2007
  • 1003 Answers
SOURCE: Dishwasher not filling
I WOULD REPLACE SOLENOID AND TIMER
Posted on Jan 18, 2008
  • 1073 Answers
SOURCE: kenmore dishwasher makes grinding noise while draining
disassemble the top of the dishwasher pump, remove the bottom spray arm and remove the screws on the top of the pump housing this will get you started
Posted on May 03, 2008
futureloginn
  • 734 Answers
SOURCE: Kenmore Dishwasher 665.1671590 Leaking water at fill funnel.
Step1
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
Step
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
Step
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Step
Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
Step
5
Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
Posted on Dec 02, 2008
  • 11 Answers
SOURCE: Dishwasher leak
ya
Posted on Jan 23, 2009
Troubleshoot my kenmore dishwasher won't drain
Check that the drain hose isn't kinked or blocked. Check that the pump inlet in the bottom of the dishwasher isn't full of gunk.
Oct 13, 2014 | Kenmore Dishwashers
Water is not draining after wash. What might be the cause?
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit ( there are others, this is just an example )
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock-out plug at connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Apr 01, 2010 | Jenn-Air 24 in. DW861 Built-in Dishwasher
The dishwasher wont stop drying to drain . The darin is not blocked
check the following:---- Check for hose kinks or food plugging drain hose. Start at the drain port exit
  1. Check the check valve and drain hose for debris.
  2. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  3. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  4. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  5. If you have recently installed a new garbage disposal, check knock-out plugat connection.
  6. Check pump impeller for damage.
  7. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
    thanks.
Oct 10, 2009 | Dishwashers
Dishwasher not draining.
Hi
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 01, 2009 | Frigidaire Dishwashers
Water does not drain
Hi
You can :
Please contact for further clarifications.
Thanks
Rylee
Jan 27, 2009 | Kenmore 17252 Free-standing Dishwasher
My dishwasher does not completely drain after a wash. what do i do?
  6. If you have recently installed a new garbage disposal, check knock out plug at connection.
Jan 08, 2009 | GE Nautilus 24" Built-in Dishwasher
Nautilus dish washer won't drain
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit (there are others, this is just an example)
  6. If you have recently installed a new garbage disposal, check knock-out plugat connection.
    ok.
Jan 06, 2009 | GE Nautilus 24" Built-in Dishwasher
Kenmore dishwasher makes grinding noise while draining
May 03, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Kenmore 24 in. 15222 / 15229 Built-in Dishwasher Logo
75 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
