Question about Samsung SGH-D600 Cellular Phone
Charging problem Hi, I've hard my SGH-D600 for close to a year now with no issues.Recently I've been unable to charge it. It simply drained and went off completly. Repeated attempts to charge it sometimes bear fruit but the charge holds only for a day and it goes off again. Any ideas?
  • Mfalme Aug 11, 2007
    I'm experiencing the same problem yet again after replacing with a new battery. Worked fine after the intial charge but am back to squre one again. Phone/battery can't hold charge
  • Celiabouey Mar 25, 2008
    Ok... had this D600 for like 2 years. all of a sudden it stops charging. send the thing for repairs and when i get it back it works for 2 days and starts its nonsense again. What happens is.. i put it on charge obviously when the battery is low... then it flashes after 3 seconds to say the battery is full. when i remove it from charge it dies again. It just wont charge at all.. whats the problem??
  • Samsung Master
  • 12,061 Answers
Your battery is shot... you need to get a new battery. When you get a new one, install in the Phone connect to the charger for the recommended period, about 12hrs or so, during this time DO NOT use at all!
Posted on Aug 08, 2007
SOURCE:
Cant get this one to start
this just happened to me. my battery was around 60 percent but my phone suddenly got drained and refused to charge or switch on.
so i simply held down the power button and the "volume down" button together until the phone entered recovery mode. After i did that everything went back to normal
May 07, 2013 | Cell Phones
My laptop battery sometimes gets so hot when I'm charging it that my pc shuts down
It might be to do with Windows 8, but what would be overheating is your processor or RAM. If it is the battery, Windows 8 might be too much drain, or it's simply coincidence and your battery is had it.
May 02, 2013 | Toshiba Satellite P750BT4G22 Notebook
Hi i am using dell latitude d600 problem with charging the battery 3 or 4 time orange light flash n 1 time green light . im unable to use my laptop with battery it working well with A.C power
Try to perform power drain. Take out the battery unplug the power adapter then press and hold the power button for 30secs. Put the battery back in then plugin in the power adapter then turn on the computer. If same issue occur, then you need to replace your battery.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
May 18, 2010 | Dell Latitude D600 Notebook
I have a samsung d600 but it has a problem the
i would suggest to back up all your files, phone book contacts,photos and images, etc, and do a hard reset.
type this code to your phone and check, *2767*3855#
good luck..
Feb 24, 2010 | Samsung SGH-D600 Cellular Phone
Lossing battry charging in 3second
the phone is not holding the charge you need to buy a new battery
Jun 24, 2009 | Nokia 2630 Cell Phone (Unlocked) - Black
Battrey fast discharges
dear, there are two possible reasons of battery down.. 1st is that your battery is not ok and the other is your phone's charging IC is going to drain it.. so check the battery with other set or try with new battery in your phone.. regards, hope it will fix the issue so dont forget to rate it...
Jun 04, 2009 | Samsung Cell Phones
Dell D600
If the docking station is not charging the laptop while docked, it may simply need to be plugged in using the power cord to recharge the battery.
Jul 21, 2008 | Dell Latitude D600 Notebook
How to unlock my sgh-d600
samung helio model # SPH-A503
FCC ID: A3LSPHA503
Apr 13, 2008 | Samsung SGH-D600 Cellular Phone
Not charging
got same problem ??? did u get it sorted  ??? if so how ???
Dec 22, 2007 | Samsung SGH-D600 Cellular Phone
Interesting problem
make sure the pins going to the usb port on it are all ok and they are not touching then, find someone with a similar D600 and relace your mem card and see if there is a difference, then try the battery and also note any difference. if its the battery, wich is likely, get it replaced, however there are cases of ic damage from faulty usb's, so if a working battery or mem/flash card dont work, send it to a repair man, after backing up all your personal stuff onto computer via BLUETOOTH. good luck!
Oct 04, 2007 | Samsung SGH-D600 Cellular Phone
Samsung SGH-D600 Cellular Phone Logo
274 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
