Thomson thg540 port forwarding
3 Suggested Answers
Technotch
  • 22 Answers
SOURCE: Port Forward a RCA Thomson DCM305R
it just a cable modem. I don't think it does have firewall. It won't block anything.
- Laxman
Posted on Nov 23, 2007
nelsontimmy
  • 83 Answers
SOURCE: open a port for u torrent in a thomson st 780 wl
here is what your look for. http://portforward.com/english/routers/port_forwarding/Thomson-Alcatel/Speedtouch780v6/Utorrent.htm
Posted on Mar 12, 2009
Changing NAT settings on TG585
Judging from your user name, I take it you want to switch your NAT settings so that you can play your xbox online. In order to do that, you're first going to need to set up a static IP address and then forward your ports on your router from there. Here is a simple and easy to use guide from portforward.com, just follow the steps outlined in the pictures and you should be able to get this up and running in no time.
http://portforward.com/english/routers/port_forwarding/Thomson-Alcatel/SpeedTouch585/Xbox_Live_360.htm
Mar 21, 2011 | Computers & Internet
I want to chance port forward in Thomson TG789vn router. How do i do that. It is for playing online with XboX360
Hello there!
I guess you want to port forward for playing online games trough xbox360
Ok you need to go on webpage portforwarding.com then there select which exact router you have, specify your static ip(if you have it) or some static range ip adress, other explanations for exact router you own, are on that webpage with step by step marks and explanations. Thats about it! =)
Please rate solution! =)
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Computers & Internet
Hi, I have just dowloaded blur beta for xbox360, i have thomson tg585 v7 router, with ISP: Plusnet Problem: cant connect to a game. Game is telling ny NAT is set to STRICT, needs to be OPEN. had a...
Now, avoid Port Triggering if at all possible. Before you follow any of these instructions, read what Port Forwarding is, and what Port Triggering is, and what it does.
Your router may have some built in forwarding, so check it out and see if you can locate your manual on those pages. This website has many manuals for such configurations, but it is best to do what you can in your router on your own.
What you need to look for on your router configuration pages is the Virtual settings. The page will have a drop down list with several dozen options to choose from. You will need to know what type of service or program allows the Xbox Live parties, and then look for it in the list. If it is in the list, click on it, and it will automatically be added to the list.
Another option you need to consider is enabling UpnP, in your router, which enabled your programs to talk to the router and make configurations automatically within the router automatically without any input from you. Locate that setting in your config pages and enabled it as it usually ships disabled on routers. After you enable this option, see if you can properly connect to the party before setting any ports manually or in the routers virtual config page.
If it doesn't work, leave it enabled, but locate your program in the list. If it is not there, then use the link I gave you to locate your router, and the program you need to use.
The worst scenario is that you will need to contact Microsoft with questions on how to setup Xbox Live as you need it in your router, or your computer manufacturer. You may even want to consider contacting the manufacturer of your router and see if the tech department can help you configure this properly.
Apr 09, 2010 | Gateway Cable/DSL Router - 4Port [ Belkin...
Part PM820148 of thomson lcdB03B is broken
Unfortunately the connection port you are talking about is on the tuner board, and cannot be found seperately. The tuner board is pretty inexpensive though. Costs just under 65$.
Get the tuner board for the your Thomson/RCA LCD tv by clicking here.
Jan 01, 2010 | Thomson LCDB 03B 27 in. Television
Port forwarding
This is for a slightly different model number but...
1. set your pc to have a static address
2. on router > tool box > games&applictation sharing > add new application
3. name it Axis Camera and assign port 2500
4. assign this to your PC
full instructions here:
http://66.102.9.104/translate_c?hl=en&sl=pt&u=http://www.portforward.com/english/routers/port_forwarding/Thomson-Alcatel/SpeedTouch536v6/Aleph_One.htm&prev=/search%3Fq%3Dspeedtouch%2Bst5x6v6%26hl%3Den%26sa%3DG&usg=ALkJrhjGtxlvTWKs7M9NJZrTc_5iz9Tb6A
Aug 11, 2008 | Computers & Internet
Xbox360 elite
do u have a router and if so u need to make sure these ports are open
If you have not already forwarded ports for your xbox through your router then that may be your problem.
The following ports must be available to your Xbox 360 console for Xbox LIVE to operate correctly:
  • TCP 80
  • UDP 88
  • UDP 3074
  • TCP 3074
  • UDP 53
  • TCP 53
Jun 14, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
ST585v6 router -how to set it up to allow forwarding of ports 5198 5199 & 5200 ? Trying to use it for a ham radio system called EchoLink. Thanks
ra config
Configure remote access parameters.
SYNTAX:
ra config [port = <number]>
[mode = <Permanent]>
I found the above command relating to port numbers in the reference manual for your access point. You can try this. If it does not work, below is a link to the Thomson website where you can view the pdf file for your access point's reference manual where you will find many other commands.
http://www.thomsontelecompartner.com/dsl-modems-gateways/products/product-detail.php?id=104
May 02, 2008 | Computers & Internet
- Laxman
Nov 22, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
My RCA router needs to be port fowarded
Go to this page: http://www.portforward.com/routers.htm Find your router on this list and it will give you a detailed description on how to port forward.
Aug 23, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
