Question about LG Heating & Cooling
My ac window unit. Can I make it colder.
I have a few different brands of ac units in my apartment.i have to have them run almost 24/7 because my dogs have thick coats and are always super hot.two units are really old and one is maybe 5 years old if that.they blow out air and everything kind of cold but not like it used to.in the past I would just throw out the unit.now that my wedding is around the corner can I do anything to make the air colder?
  • 1,613 Answers
Dirt and dust on an evaporator coil is like putting a sleve on a beer. It insulates the coil so that when the air passes through it it can not pick up as much cooling OR ACTUALLY transfer as much heat. Chances are this is why your units are not cooling like they once were. Clean the coils with a pump sprayer with water with a mild detergent, being sure to rinse well.
Posted on Jul 29, 2017
    Top Expert:
  • LG Master
  • 12,962 Answers
U do not have control over the temperature of the air; you can control how long the compressor operates with the thermostat. A longer running time equates to a cooler room.
Clean condenser out to maximize efficiency and cooling.
4 Suggested Answers
  • 9 Answers
SOURCE: Not cold air cool air?
Check your air filter. if its ok call the guy who installed it and have him fix the leak. It prob is a bad weld joint. Check the joints on the copper tubing inside at the coil and outside at the a/c and feel around and see if there is oil leaking from the joint. If not you may have a leak in a coil or on the txv inside on the coil.
Posted on Jan 22, 2009
  • 16 Answers
SOURCE: window ac unit is not blowing cold air
When the unit is running, go outside and put your hand near the condenser fins, this air that comes out should be slightly warmer than the ambient temp. If it is not you will need to take the unit out of the window and out of its outer case and clean the condenser fins from the inside, this is no easy task as it is very hard to reach. You will want to get a small (toothbrushed sized) brass bristled brush with a long handle. Make sure the evaporator coil (in the front) recieves the same attention and wash the mesh filter that goes in front of the evaporator. Re- assemble and enjoy the cold air.
Posted on Jun 07, 2009
  • 86 Answers
SOURCE: Portable Air Conditioning unit no longer blows out cold air
Clean out the condenser fins with a vaccumn try this first. God Bless have a nice day.
Dickson
Posted on Jul 02, 2009
My ac window units are not draining water and creating mold in my house
Check the drain tube between the evaporator side to the back of the unit. It may have a packing plug installed. If there is one remove it or clean the drain tube.
Jul 23, 2014 | Frigidaire FRA08PZU1 8,000 btu Window AC...
Why is a brand new in wall ac not dehumidifying room
could be to small for room or could be to big for room. It the unit is too big it will cool the room down to fast and shut off to soon, this will not remove the humidity. Try running the unit on a lower temperature the slower the fan the colder the coil which will remove more humidity from room also make sure the fresh air vent is closed and not bringing humidity from out side.
Jun 11, 2014 | Friedrich Heating & Cooling
Why same different AC companies has the same model number
There are a number of manufacturers that make equipment for many different brands and just have different paint schemes. Rheem and Rudd...one is brown, the other green. Carrier, Day and Night, Payne are the same units with subtle differences. Kenmore, Whirpool, and several others are manufactured by the Heil Quaker Corporation that became ICP a few years back. The list goes on and on.
As a matter of fact, some have the different badges in a baggie delivered in the box so the appropriate one can be place on the unit when installed.
May 14, 2014 | Comfortmaker C4A348GKD 4 Ton 14 SEER AC
Brand-new window unit emits musty smell when compressor shuts off
It SHOULD NOT ... (smell in... even in WEST TEXAS).
BRAND NEW... Rush on down and get a good
NEW one.
I would suspect the condensate drip pan is plugged...
Common for AC units ..
But NEVER in "brand new"...
Get that (previously owned (my opinion)) UNIT
back from where you bought it ... Trade it in for a CLOSED BOX... and make your sales CLOWN write up why you are returning it.
Mold can be quite dangerous!!
Carnac the Magnificent
Apr 26, 2017 | Frigidaire Heating & Cooling
M6X08F2A Air Conditioner problems not blowing cold, not cooling off apartment
Sounds like the heater is on as well. Even if ac is not working it shouldn't get hotter than outside air temp. Possible stuck relay.
Mar 01, 2017 | Maytag Heating & Cooling
Window ac unit only blows 60 degrees through vent should this be colder?
depending on outside air that pretty cold it should only be 20 degrees different
Jul 14, 2010 | Heating & Cooling
Air conditioner wiring diagrams
What brand of A/C is it? Are you looking for the thermostat wiring? Different Brands use different wiring, but the usual is as follows:
R terminal at furnace is 24 volt Hot
W is the control for the heating cycle
G is used to start the furnace blower
Y is used to start the outdoor A/C
B or X depending on Brand is the 24 volt common
Yellow and B or blue is the other wire that goes to the outdoor unit
If you want more info, I need Brand, and type of unit, gas furnace and A/C, electric furnace and A/C, or is it a heat pump for the outdoor unit?
Hope this helps./
Sincerely,
Paul Gibson
Mar 29, 2010 | LG LWHD1800R Wall/Window Air Conditioner
AC Thermostat is set to 78 but wont cool past 79 or 80
If your unit is running 24/7 you are either low on charge or the unit is to small for your house.
A 20° temperature difference is about normal for the room air vs the air coming out of the ducts, but the room air and the leaving air should keep getting colder and colder.
An air conditioner should cycle approximately 3 maybe 4 times in an hour if it's properly sized.
As for the thermostat thermometer they are very cheap and are more for reference than actual temperature, so if 78° is not comfortable, then you should set it lower but not rely on thermostat being accurate or what the thermometer is saying as long as it is consistent.
The air conditioner and thermostat can also be set below 78°, there's a lot of people set them at 72° and below with no problems.
the only thing is if you have real low humidity you'll need to watch indoor coil or the suction line (the big line) on your outdoor unit and make sure it doesn't freeze up on you.
Sep 13, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
NO POWER TO DOWNSTAIRS FURNACE NO FAN NO AC ??
what brand? most likely fuse is blown on furnace control board if there is no fuse then transformer could be blown sounds like a short in system look for bare wires at ac unit small wire outside especially if your have dogs around ac unit
Jun 24, 2009 | Heating & Cooling
Goldstar Window A/C Unit Model GWHD5000
I recommend that if you have animal and you want to have the unit on all day that is fine if you have an ac unit with a thermostat and it is big enough to handle.  The unit that is in the window is ok if your home but it could cost alot if there is no thermostat because it will run and run and run.  Then if it don't cool the house enough means its not the right size.  The unit / compressor could overload and kick on and off and might not work when you get home and the house will be like a firecracker.   Best bet would be to replace it with a unit for the size needed for the apartment.  It would be effecient. if we can help further just let us know.
Jul 15, 2008 | LG Goldstar GWHD5000 wall/window Air...
Heating & Cooling Logo
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
