Question about Samsung RS2556 Side by Side Refrigerator
The refrigerator side is not cooling.
For the last couple of weeks, I noticed my vegetables and greens were freezing in the fridge side, on the shelves as well as in the bins. I set the temp up to 38 degrees yesterday. Today, I noticed that the temperature display was blinking at 38, and continued to do so all day. I checked Samsung troubleshooter, and unplugged the fridge for 10 seconds, as it said, and replugged to set the chip. It still doesn't cool, and now the display is flashing at 62 degrees, the actual inside temp, I presume. The freezer is OK, I think. Any suggestions?? I've had it for less than 2 1/2 years. Thanks!!
  • jannag Aug 21, 2007
    Thanks for your help. I had a service tech come by; he disassembled the inside of the fridge, and the defrost coils were frozen. He did some elec tests, thawed the coils, and reassembled it all. I need a new defrost heater (luckily, part of the sealed system, so covered by warranty), and a new temp sensor, as you indicated. The fridge works for now, but will freeze up in a few days, as I wait for the parts to arrive.
    Tip for other Samsung owners: push the top two buttons on the panel simultaneously, and a sly code will appear as a single bar lit up in one of the big digital numbers in the temp display. This is the secret diagnosis device used by the techies, and whichever bar lights up indicates the trouble. Also be sure to check BBB rating before you call one of Samsung's auth service people. The first guy I called was a total nincompoop.
    jg
  • Anonymous Mar 15, 2014
    there is power the display and lights in the fridge are on but it is not cooling or making ice
  • 909 Answers
ALMOST DEFINATELY YOU WILL HAVE AN ELECTRONIC CONTROLLED AUGER(MOTOR)CONTROLLING THE AMOUNT OF CHILL ENTERING THE FRIDGE COMPARTMENT. IF YOU SET THE FRIDGE TO MINIMUM AND LISTEN CAREFULLY, THERE SHOULD BE A SOUND INDICATING THE AUGER IS WORKING.( OPENING AND CLOSING THE FLAP). SET TEMP. TO MAX AND LISTEN. IF NOTHING, IT COULS BE A DEFECTIVE MOTOR OR FAULTY THERMISTOR(TEMP. PROBE).
Posted on Aug 17, 2007
SOURCE:
Maytag Dual Cool - fridge side too cold even on lowest setting - freezing vegtables
It's just as previous person, on warmest setting vegetables and meat are freezing in drawers
Apr 10, 2013 | Maytag MSD2651 HE Side by Side...
I have a new F&P refrigerator model E450RXFD upright fridge only, I have only just got it last week... I have water pooling on the bottom under the fruit and vegetable crisper part ???? any ideas what...
I have the same problem with my E450RXFD, 1st week i got it and noticed it pools water under the crisper. Not too sure what to do about it.
My parents have the same fridge (only 8 years old and theirs does not pool water)
Dec 26, 2010 | Fisher and Paykel Refrigerators
The refrigerator side started not cooling last week just half way up the fridge. Now the freezer half way up is not freezing.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
dhjhdg
Oct 26, 2009 | Samsung 26 Cu. Ft. Side-by-Side...
The side by side fridge either cools too much (at times freezing the vegetables in the bins) or stops cooling (when it starts getting opened a bit morethan few times a day)
This sounds like an intermittent bad cold control. If you catch it off and hear nothing running and it is warming up, use the handle of a butter knife and rap the knob of the cold control. If it pops on, you must replace the control. Good luck, AJ
May 22, 2009 | Refrigerators
Coils on Side by Side Refrigerator keeps freezing
sounds like you need to replace your defrost timer it is in the front underneath the fridge if you pull off the front kickplate you will see it in there
May 01, 2009 | Refrigerators
Vegetable and fruit crisper drawers freezing foods
You have a defective thermistor and damper control in the fresh food or a bad control board.
Check the thermistor first.
Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
Feb 21, 2009 | GE PSS25SGN Side by Side Refrigerator
Frequent frosting over
replace the defrost heater thermostat
PLEASE RATE THIS !
Jun 09, 2008 | Refrigerators
Samsung RS2556 Side by Side Refrigerator Logo
854 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
