Question about Garden
Ferris lawnmower IS2000 -how to install deck belt
How to installdeck belt
2 Suggested Answers
rwvanlue
  • 486 Answers
SOURCE: how to measure belt for riding lawnmower
Understand your idea, however, after 35 years of repairing mowers, most manufacturers have designed drive sheave pulleys to certain specs, and generic fractional horsepower belts do NOT work. The material, cord design, and cross-section measurements are specific to that particualr application. Fractional horsepower belts are normally just rubber, and the heat created by driving a mower will melt the rubber quickly.
Go to the local Cub dealer and get the proper belt. It will save you tons of time and money. If you do not have a local dealer, cub has a website that would provide a dealer locator for your area.
Posted on Nov 10, 2009
Is 2000 ferris lawnmower. put up running then would start but die once brake released..all safety switches have been checked for fuctionality , fuses ok, relay ok, and time delay module ok.
If the mower has sat with fuel in the tank, fuel is probably bad. Drain ALL existing fuel in tank, apply fresh fuel. Then see what happens. Have had this happen to me many times, not only w/mowers, but chain saws, edgers, etc. Worked just fine after dumping bad fuel then using fresh gas. Got 'em all going. Let us know if this was your problem.
Apr 26, 2015 | Cub Cadet 46" Lawnmower Deck Drive Belt...
Cub Cadet 1525 belt diagram
Attached is the blade diagram for correct placement of the deck belt. There is some bleed through from the back page, but you can see the direction of the belt. I have a 1525 mower for the last 11 years, still running and going. Hope this helps! 25105582-ergctme4kokczpvvmmku3zkh-5-1.jpg
Sep 15, 2014 | Cub Cadet 46" Lawnmower Deck Drive Belt...
Ferris mower cranks but won't start
FIRST DO HAVE GAS IN TANK,CHECK TO SEE IF VTHE BLADE SWITCH IS ON.NO THAT OUT OF THE WAY STILL NO START YOU WILL NEED TO CHECK FOR SPARK AT THE PLUGS,CHECK WITH A PLUG TEST LIGHT,IF YOU HAVE SPARK AN FUEL,PULL THE FUEL LINE FROM THE FUEL PUMPTO THE CARB,HOOK UP A TEMP LINE PLACE IN A POP BOTTLE AND CRANK IT OVER,IF YOU HAVE NO FUEL ETHER YOUR FILTER IS PLUGGED OR THE VACUME FUEL PUMP IS BAD.STEVEH
Apr 16, 2014 | Ferris IS2000 61"" Zero Turn Lawn Mower...
Blade belt diagram for an is 2000 61 inch
I don't have a diagram but we just had to replace our belt and Here's how we did it. Note that the shiny gold/silver pulleys make contact with the flat side of the belt while the black pulleys make contact with the u-shaped side of the belt. If you look at the pulleys you will see they have different shapes to correspond with the different shape on each side of the belt. The drive pulley at the back makes contact with the u-shaped side of the belt.
Release the tension spring and thread the belt. Belt slips under the middle back pulley with the tension spring released. Then use a spring pulling tool (there is such a thing) or another method to pull the tension spring back over the bolt. Ensure belt is threaded properly with no twisting and nothing caught in the pulleys before firing it up.
Hope that helps.
Oct 27, 2012 | Ferris IS2000 61"" Zero Turn Lawn Mower...
My MTD riding lawnmower is burning thru the new belts I just purchased.The new belts are 954-0371A which replaces 754-0371A. The old style belt lasted 5 years. Even before engaging the clutch, the belt...
My idea is not about the belts, but is about the deck. If the tensioning mechanism on the deck is getting stuck in an intermittant position than the belt may be just tight enough to turn blades while slipping through the pulleys, this may cause enough friction to start melting your belts. If this is the case you will have to remove your mower deck and see what is preventing the mechanism from functioning properly.
Jul 07, 2011 | MTD LAWN MOWER PART 1909404 BELT
My husband was injured and cannot replace the main drive belt for our riding lawnmower. Is there a place to get the schematics of how to put it on? If I have a picture I can do it. Model 917271041,...
Normally the belt diagrams are in the owners manual. Seeing this is a 12 year old machine the diagram stickers are possibly gone, but the drive belt diagram is normally on the bottom side of the foot rest, and the mower belt is on the top of the mow deck. Both are typically on the left side of the tractor as you sit on it. Please vote 4 thumbs up. Thank you.
Here is the link to a typical 42" Craftsman mow deck belt:
http://www.askmehelpdesk.com/attachments/tools-power-equipment/21777d1247094945-craftsman-lawnmower-belt-diagram-aypwobrk.gif
Oct 16, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
