Question about Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm
PENTAIR SUPERFLO 1 1/2 HP SWIMMING POOL PUMP 340039 overheating and shuts off
Worked for a year shut down the pool and 6 mths later we started pool pump seemed fine but shuts it self off over heating
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pentair Master
  • 1,448 Answers
Bad motor
Posted on Sep 07, 2014
SOURCE: Pump works in spa mode, but doesn't work in pool mode. Why?
We need more info. Which control system is it? Suntouch, easytouch, intellitouch.......? It sounds like a programming problem in the controller.
Posted on Jun 26, 2009
  • 11 Answers
SOURCE: Pool pump starts & stops on its own outside of programmed run
There are several potential problems:
  • freeze protection circuit causing pump to start - could be a bad outside air temperature sensor.
  • It is possible the new relay is bad.
  • There could be a short in the control wires to the relay
  • old programming shadow stuck in memory (not likely since you changed the boards)
Yes, the starting and stopping can harm your pump.
Posted on Aug 11, 2009
Testimonial: "The problem has been fixed----it was a bad outside air temperature sensor. Thanks for your help."
  • 114 Answers
SOURCE: I have new pentair 1 hp pump that was intalled by
to open the basket the pump needs to be off. all drains and the skimmer needs to be shut. otherwise all the water from the pool will leak out... now when you have done all of that. there should be a ring around the lid you take a hold of that and twist. it can be alittle stiff at first.. When you get that ring off the lid will pop off. now water will come out of it becuase it's just what's in the pump and in the line. once the water is out you can take the basket out and clean it. Now very important. when you put the lid and the locking ring back on open the skimmer and the drains to get water back into the pump. If the pump is not filling up go ahead and automatically put water in there until it's full. once the pump is full you can turn back on the pump and everything should work fine. if you have any other questions please let me know.
Posted on Aug 19, 2009
  • 990 Answers
SOURCE: Legend pool cleaner wheels not moving
You might want to pull the drive wheels and see if their might be a small pebel stuck in the drive gears on the wheel.
Posted on Oct 04, 2009
  • 366 Answers
SOURCE: Will Pentair Intelliflo pump save me enough money to justify cost
Here are a couple of thoughts. If you install an intelliflo pump and run it for the same amount of time and at the same rpm as your current pump, you will still have a savings. If you drop the rpms by 1k, you will have an exponential savings. Go to the pentair website and use the program to estimate your actual savings. You can still run the heater at a reduced flow setting but there is a limit, you have to check with the heater manufacturer to see what the minimum is.
If you are running a conventional pump 24/7 you are using a ton of energy. You should be able to run the pump for 8 hours a day and achieve the same results. For instance, running the pump from 4am to noon should give you a good window to maintain the heat and not run it all the time. It also depends on if you have a cover on your pool when it's not in use. If you don't, you will lose significant heat when it's not running, however, running it early morning should give it a chance to heat back up before you want to use it again. You will have to experiment with timer settings, etc..
I really do think the intelliflo pump is a great pump. The rare earth magnet design allows it to be way more efficient than the conventional pump. It is so much more efficient that when it's running, you can hold your hand on the motor and it is just warm. Your pump motor probably runs very hot, heat is a by product of inefficiency. I hope this helps.
Posted on Jan 19, 2010
Wiring
see side of motor it is set up for 220 volt 1st hot black or color to L1 2nd hot black or color to L2 green to case or ground
Jun 15, 2013 | Pentair Superflo 1 12 Hp Swimming Pool...
Whisperflo pump super hot
motor overheating replace motor or pump
Aug 26, 2012 | Pentair 15 Hp Superflo Swimming Pool Pump
Pentair superflo swimming pool pump seal replacement
if seals bad probably ruining bearing in motor replace whole unit
Jan 13, 2012 | Pentair 15 Hp Superflo Swimming Pool Pump
Hi, I have just installed a new Nocchi / Pentair 1 hp pump, 230v the problem is it is overheating after 7 mins & the thermal switch activates. after this it cycles on/off every 50 seconds, the pipework...
Sounds like you have done eveythig correctly - since the pump is new I suggest you contact the seller of the pump, or the local service agent as it could be a thermal overload problem.
Jan 24, 2011 | Pentair Superflo 1 12 Hp Swimming Pool...
I have a pentair 1.5 hp 177475 pump i would like to wire it for 115v need layout
ITS ON THE LABEL ON THE MOTOR HOW TO .. ITS BY MOVING THE BROWN AND WHITE WIRES
May 21, 2010 | Pentair 15 Hp Superflo Swimming Pool Pump
Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm Logo
141 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
