Question about Pentair 15 Hp Superflo Swimming Pool Pump
PENTAIR SUPERFLO 1 1/2 HP SWIMMING POOL PUMP 340039 over heating
PENTAIR SUPERFLO 1 1/2 HP SWIMMING POOL PUMP 340039 was working for a year we shut down pool and now 6 mths later the pool is on pump worked fine but shuts off and gets very hot what would cause this.
    New Friend:
    Problem Solver:
  • 15 Answers
It's likely that the bearings in the motor have rusted from sitting up for 6 months. This causes resistance which in turn causes additional heat inside the motor. This is a water cooled pump that is designed to move just enough water through the pump in order to cool the motor under normal operating temps. Because the motor is running hotter than it was designed for, the motors thermal overload shuts it down. You can replace the bearings (hard) or replace the motor (easy). You can find the motor and the bearings at poolsupply1.com
Posted on Nov 09, 2014
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pentair Master
  • 1,448 Answers
Bad pump motor
Posted on Sep 07, 2014
SOURCE: Pump works in spa mode, but doesn't work in pool mode. Why?
We need more info. Which control system is it? Suntouch, easytouch, intellitouch.......? It sounds like a programming problem in the controller.
Posted on Jun 26, 2009
  • 114 Answers
SOURCE: I have new pentair 1 hp pump that was intalled by
to open the basket the pump needs to be off. all drains and the skimmer needs to be shut. otherwise all the water from the pool will leak out... now when you have done all of that. there should be a ring around the lid you take a hold of that and twist. it can be alittle stiff at first.. When you get that ring off the lid will pop off. now water will come out of it becuase it's just what's in the pump and in the line. once the water is out you can take the basket out and clean it. Now very important. when you put the lid and the locking ring back on open the skimmer and the drains to get water back into the pump. If the pump is not filling up go ahead and automatically put water in there until it's full. once the pump is full you can turn back on the pump and everything should work fine. if you have any other questions please let me know.
Posted on Aug 19, 2009
  • 990 Answers
SOURCE: Legend pool cleaner wheels not moving
You might want to pull the drive wheels and see if their might be a small pebel stuck in the drive gears on the wheel.
Posted on Oct 04, 2009
  • 366 Answers
SOURCE: Will Pentair Intelliflo pump save me enough money to justify cost
Here are a couple of thoughts. If you install an intelliflo pump and run it for the same amount of time and at the same rpm as your current pump, you will still have a savings. If you drop the rpms by 1k, you will have an exponential savings. Go to the pentair website and use the program to estimate your actual savings. You can still run the heater at a reduced flow setting but there is a limit, you have to check with the heater manufacturer to see what the minimum is.
If you are running a conventional pump 24/7 you are using a ton of energy. You should be able to run the pump for 8 hours a day and achieve the same results. For instance, running the pump from 4am to noon should give you a good window to maintain the heat and not run it all the time. It also depends on if you have a cover on your pool when it's not in use. If you don't, you will lose significant heat when it's not running, however, running it early morning should give it a chance to heat back up before you want to use it again. You will have to experiment with timer settings, etc..
I really do think the intelliflo pump is a great pump. The rare earth magnet design allows it to be way more efficient than the conventional pump. It is so much more efficient that when it's running, you can hold your hand on the motor and it is just warm. Your pump motor probably runs very hot, heat is a by product of inefficiency. I hope this helps.
Posted on Jan 19, 2010
heatman101
  • 43501 Answers
SOURCE: What are the specifications for
Take the cover off of the capacitor...it is the bump on the top of the motor...then look on the capacitor and find the numbers that end with mfd. that is the size or rating of the capacitor...also then look for the voltage of the capacitior...you need to match that also...there are so many different motors used, even for the same pump that it is hard to say for sure what you may need there with out looking at it.
You can do that and then you know you are getting the correct cap for your motor...
My guess is that you are looking for something in the range of a 20mfd 370volt cap. but please check it out for sure they vary alot!!
heatman101
Posted on Aug 28, 2010
Wiring
see side of motor it is set up for 220 volt 1st hot black or color to L1 2nd hot black or color to L2 green to case or ground
Jun 15, 2013 | Pentair Superflo 1 12 Hp Swimming Pool...
Pentair superflo swimming pool pump seal replacement
if seals bad probably ruining bearing in motor replace whole unit
Jan 13, 2012 | Pentair 15 Hp Superflo Swimming Pool Pump
My brand new 1.5 hp, 230/115 v pentair runs for several minutes, gets hot and then shuts off. (not tripping the breaker) ...wiring was already in place on previous 1.5 hp, 230/115 jacuzzi brand pump for...
It is probably only getting 115V from your circuit which will cause it to overheat and trip the overload yet it will not draw high current which would trip the breaker. Can you confirm your line voltage with a meter? If it is suppoed to be a 230V line then look for a bad leg of power, again, checking each leg to ground using a meter.
John
May 28, 2011 | Pentair 15 Hp Superflo Swimming Pool Pump
Hi, I have just installed a new Nocchi / Pentair 1 hp pump, 230v the problem is it is overheating after 7 mins & the thermal switch activates. after this it cycles on/off every 50 seconds, the pipework...
Sounds like you have done eveythig correctly - since the pump is new I suggest you contact the seller of the pump, or the local service agent as it could be a thermal overload problem.
Jan 24, 2011 | Pentair Superflo 1 12 Hp Swimming Pool...
I have a pentair 1.5 hp 177475 pump i would like to wire it for 115v need layout
ITS ON THE LABEL ON THE MOTOR HOW TO .. ITS BY MOVING THE BROWN AND WHITE WIRES
May 21, 2010 | Pentair 15 Hp Superflo Swimming Pool Pump
Pentair 15 Hp  Superflo Swimming Pool Pump Logo
243 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
