Question about Dryers
Norcold refrigerator Thermal sensor #R-010 has power going in but no power out.
2 Suggested Answers
vetteman3002
  • 2299 Answers
SOURCE: I have a norcold refrigerator for an RV the model
There is nothing that could make a thermocouple go bad, other than quality of workmanship. That is becoming a very big problem. I would suggest buying a different brand of thermocouple. Have you tried any other brand?
Posted on Jan 06, 2011
I have a Norcold 2 door fridge. It works fine on propane or electric but I hear a VERY loud bang and see flames shoot out. It is a propane leak some place but checked fittings and lines -no leaks.
is this new? never been used before or old. ? please read this
Norcold, Inc. Product Recalls - Call 1-800-767-9101 Monday - Friday 8:00 am to 8:00 pm EST
The Norcold, Inc. refrigerators listed below have been recalled.
It is important to implement this safety enhancement to prevent an unsafe elevation in the temperature of the cooling unit should the unit fail in operation. This enhancement seeks to minimize the risk of injury or ***** due to fire.
Norcold Inc. has decided to recall certain 1200, 1201, 1210 and 1211 model gas/electric refrigerators with serial numbers from 315525 to 13088811, non-consecutively. The refrigerator's model and serial number are located inside the fresh food compartment. These refrigerators may have cooling units with a cooling unit serial number between 700000 to 13085759. This is a new recall campaign to include all 1200, 1201, 1210 and 1211 models.
Even if your refrigerator was repaired as part of a previous recall, it is necessary to have it repaired again to minimize the risk of injury or ***** due to fire.
If you have one of these refrigerator models, use the following procedure:
  1. Identify and write down the refrigerator model. If it is a Norcold 1200, 1201, 1210 and 1211 model, go to step 2.
  2. Identify and write down the refrigerator serial number. If the serial number falls in the range of 315525 and 13088811, go to step 3.
  3. Identify and write down the cooling unit serial number. If the serial number falls in the range of 700000 and 13085759, go to step 4.
  4. Call your dealer immediately.
The installation of the High Temperature Sensor will be at no cost to you.
Owners of recalled refrigerators should NOT operate their refrigerator until it can be professionally repaired by your dealer or a Norcold authorized service center.
If you have one of the recalled refrigerators and you:
Currently reside in the RV, you should immediately:
  1. Set the refrigerator controls to "OFF".
  2. Unplug the refrigerator through the service vent on the outside of the vehicle.
  3. Contact your dealer, a Norcold authorized service center or Norcold's Recall Center at 1-800-767-9101 as soon as possible to get assistance.
Do not currently reside in the RV, you should immediately:
  3. Disconnect from shore power.
  4. Contact your dealer, a Norcold authorized service center or Norcold's Recall Center at 1-800-767-9101 as soon as possible to get assistance.
Failure to follow these instructions can result in a fire causing injury or *****. To locate an authorized service center,
http://webcache.googleusercontent.com/search?q=cache:tnsP3IdSqhgJ:www.thetford.com/customer-support/recall-information/+&cd=10&hl=en&ct=clnk&gl=uk
if you have this model STOP using it!!!
Jun 19, 2017 | Refrigerators
THE HIGH TEMP.LIMIT SWITCH IS OPEN NEED LOCATION
The high temp switch connects to your power board at "Limit In" and "Limit Out". Follow those wires to the switch. I would see if you're under the Norcold recall. Give them a call and check. If you're not, here is where you can get an upgraded thermal switch:
Norcold High Temperature Limit Switch V2 0 by ARPrv
Apr 24, 2016 | Norcold Inc Norcold 1210IM Refrigerator
I shut down the fridge. Not getting any power to it now. I have checked breakers and fuses. There is power to 110 outlet where it plugs in. No power to gas valve. What do you think the problem is?
Your Norcold refrigerator is powered by 12V DC, not 110V AC. You need to check input power at the power board. If the fuses are good and you have good 12V to the refrigerator, check to see if you are getting 12V past the 5amp fuse on the board. If not, you may have a bad board. Norcold Power Circuit Boards for Sale The Norcold Guy
Jul 12, 2015 | Norcold Inc Norcold 1210IM Refrigerator
Norcold fridge in my motorhome
Norcold fridges are now part ofThetford one of the largest suppliers of mobile and marine products. You do not quote the model so not sure if a 3 way (gas/mains/12v) or AC/DC. The most common problem with all mobile fridges is the heater unit is faulty. Thetford have discontinued spares for a large range of norcold models. Information can be obtained on the Thetfold.com website.
Good Luck
Jul 09, 2014 | Refrigerators
Want to reset board on N611 norcold ref
The Norcold board reset is done by jumping a pin terminal to ground. There are several steps involved but it's all pretty straight forward. Here is an article on the steps of doing this: Norcold Refrigerator in Lockout Mode do you need to reset your power board
Jun 09, 2011 | Thetford Refrigerators
Dometic refrigerator will not stay lit
sand your thermal cupler off or replace it not centing the flam
Apr 11, 2010 | Thetford Norcold RV Cooler/Freezer
Norcold refrigerator burner will not stay lit. Ignitor lights the gas, but as soon as it the ignitor stops, the flame goes out. Thanks.
u need to replace the thermocuple or be sure its near the pilot also be sure to blow out any and all dust in that area
Nov 16, 2009 | Thetford Norcold RV Cooler/Freezer
How do you reset circuit board on norcold refrigerator
No way to do that other than to unplug refrigerator for at least ten minutes and then plug back in. Don't use surge protector, power strip, or extension cord.
Sep 21, 2009 | Thetford Norcold DE0051 Refrigerator
I have a norcold refrigerator in my rv. it works
Check if you are getting voltage to the heating element should be 120 volts
Apr 27, 2009 | Thetford Norcold DE0051 Refrigerator
Dryers Logo
52 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
