Question about TJF Apps OBDII Trouble Code Lookup Lte
P2430 code what should I do on 2007 trailblazer
P2430 trouble code on what is the problem
What could code P2430 in a 2007 chevy impala mean
code p 2430 refers to secondary air injection(AIR) system, air flow/pressure sensor bank 1---circuit malfunction===causes --wiring---air flow/ pressure sensor
Jan 30, 2018 | Cars & Trucks
My 2008 Trailblazer has OBD-II code P2430. How do I replace the secondary air injection pump?
This code doesn't mean to replace the air pump ,
DTC P2430 : Secondary Air Injection (AIR) System Pressure Sensor Circuit
Circuit/System Description
The secondary air injection (AIR) system aids in the reduction of hydrocarbon emissions during a cold start. The system forces fresh filtered air into the exhaust stream in order to accelerate the catalyst operation. An electric air pump, the secondary AIR injection pump, provides filtered air on demand to the AIR control solenoid valve/pressure sensor assembly. The AIR control solenoid valve/pressure sensor assembly controls the flow of air from the AIR pump to the exhaust manifold. The AIR solenoid relay supplies the current needed to operate the AIR control solenoid valve/pressure sensor assembly. A pressure sensor is used to monitor the air flow from the AIR pump. The engine control module (ECM) supplies the internal pressure sensor with a 5-volt reference, an electrical ground, and a signal circuit.
This is a pressure sensor problem . What this video on testing !
Chevrolet Malibu P2432 Secondary Air Injection System
May 11, 2017 | Cars & Trucks
Abslight stays on. How to fix? This is a2007trailblazer?
First you need to have EBCM - electronic brake control module check for DTC'S - diagnostic trouble code's . If the light is on there is a code stored . I think most part stores can do this and for free . After you find out what code is stored , looking up that code in service repair information for diagnostic trouble shooting chart would be next step . There are a few codes too.
DTC C0035 or C0040
DTC C0045 or C0050
DTC C0110
DTC C0131
DTC C0161
DTC C0186
DTC C0196
DTC C0201
DTC C0240
DTC C0241 or P0856
DTC C0244 or P1689
DTC C0245
DTC C0283
DTC C0287
DTC C0290 or C0292
DTC C0455
DTC C0550
DTC C0558
Find the code do the diagnostic's , fix the problem , wiring issue's , a sensor , bad module ,what ever it is . The light will go out then . Here is a sample of code discription .
• DTC C0035 Left Front Wheel Speed Sensor Circuit
• DTC C0040 Right Front Wheel Speed Sensor Circuit
Dec 30, 2016 | 2007 Chevrolet Trailblazer
2.2l. Where is air pump located and how do I test to determine whether it is working?
fix the reported code fault sensors then reset the ECM using a scan tool
turning off lights does not fix problems
Jan 09, 2016 | 2007 Saturn Ion
I have a 2007 Trailblazer and I have been having trouble with the horn what can I do?
help us try to help you, what is it doing? honking when ever it wants or what? I would hunt down the horn and check the wires..
fuses, ect
Sep 27, 2013 | 2007 Chevrolet Trailblazer
Code p2430 and check engine light is on
P2430 Secondary Air Injection System Air Flow/Pressure Sensor Circuit
carprog full
Mar 08, 2013 | Cars & Trucks
Trouble codes C0305 C0327 U0100 U0101 U0140
co327 is a code for your transfer case encoder motor and the U codes are communication codes. Most likely cause is the encoder motor needs replacement
Feb 11, 2012 | 2007 GMC Yukon
How to fix P2430 code on a 2006 Pontiac Grand Prix
P2430 Secondary Air Injection System Air Flow/Pressure Sensor Circuit,
The AIR diagnostic uses 3 phases to test the AIR system:
DTCs P0411 and P2430 run during Phase 1
DTCs P2430 and P2440 run during Phase 2
DTC P2444 runs during Phase 3
During phase 2, only the AIR pump is activated. The solenoid valve is closed, this is p2430 and p2440. -The AIR system pressure sensor is stuck. good-day !!
Jul 15, 2011 | 2006 Pontiac Grand Prix
What are the trouble codes p1400 and p0506for 2007 chevy trailblazer 4.3 6cylinder
Go to Auto Zone ask the technician to run a computer scan and print out the results and the computer will tell you the meanings of the trouble codes.
Jun 17, 2011 | 2006 Chevrolet Trailblazer Ext
How to fix trouble code p2430 on a 2005 pontiac grandprix?
CODE P2430 - SECONDARY AIR INJECTION AIR SYSTEM AIR FLOW PRESSURE SENSOR BANK 1 CIRCUIT MALFUNCTION.
Dec 31, 2010 | 2005 Pontiac Grand Prix
TJF Apps OBDII Trouble Code Lookup Lte Logo
41 people viewed this question
Top TJF Apps Apps Experts
Brett Duxbury
Brett Duxbury
Are you a TJF Apps App Expert? Answer questions, earn points and help others
