Question about Freestyle Shark Classic Mid Size Watch
Light not working
The backlight is not working
How do I change the backlight setting?
How to adjust the backlight strength, time-out length of the ...
www.cnet.com > Mobile > Wearable Tech
CNETJul 23, 2015 - In order to adjust either setting, your Pebble Time watch will need to be updated to version 3.2. Launch the Pebble Time app on your device ...
how do i adjust backlight time on my iphone ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Nov 18, 2012 - Not sure what you mean by Backlight time. But you can adjust how long it is before your phone auto locks at. Settings> General > Autolock. How do in change my backlight settings on my iP...
Dec 31, 2013
Did they do away with the backlight timer for i...
Nov 6, 2011
how do change the back light to time out?
Jan 14, 2009
More results from discussions.apple.com
Dec 25, 2015 | Watches
I bought this watch "origo guide pro" off the Internet in used condition, however the backlight does not work. Could this be a blown bulb?
it can be several things to cause this, from the looks I would immediately say that the batteries needs to be replaced, it takes power to turn on the light and when it tried the power is taken from other components like the lcd, and never actually light because there is not enough power,
next it could be the bulb, it could be dead, short circuited. The issue is they are usually hard to replace and or irreplaceable, it needs the be rated the same for voltage a multimeter would help you a lot, to see if voltages are coming from the wires that connect to the bulb.
next the watch could be malfunctioning and may no longer have proper working circuity to run the backlight, this will be extremely hard to repair it will be better to replace the inside or take to a jeweler to have it repaired, in any event if you choose to repair it then you look for damaged parts and replace them- in the event that fails take you digital multimeter and trace the circuit to see if you can find the faulty part this requires you to have adequate knowledge of electronics and it would surely help to have the schematics to the watch--Good Luck.
Jan 28, 2013 | Watches
Tag kirium f1 crown does not work, light does not come on for 6 seconds, also buttons do not work
Is the digital display blinking? If it is, it would mean that the battery is weak and thus, the backlight won't work.
Dec 17, 2010 | Tag Heuer Kirium Formula 1 Chronograph...
Casio F91W-1 Wrist Watch- backlight color
You can change the backlight on a casio wristwatch by holding the Light button, but only if it has an LED light in the side of the screen such as yours does. There is Light Blue, Red, Pink, Blue, Green LEDs in the side of the screen and you can change between them. There is also an option that flashes between all the LEDs when you press the button.
May 06, 2010 | Casio F91W-1 Wrist Watch
I cannot get my nike torque watch backlight to work
Have the battery checked! First thing that stops working is the light when the battery fails! :-)
Jan 08, 2010 | Nike New Torque WC0068 502 watch
Balck screen when using the backlight
Your battery is most likely failing. The first thing that stops working is light and sound because those functions use the most energy! When your battery voltage is below 2.5 volts the light will stop working!
Aug 31, 2009 | Nike New Torque WC0068 502 watch
Backlight in my timex expedition stopped working-can only see a small blue bar on left side of watch-replaced battery but no help. All other functions work fine
HI
SEE EVEN AFTER THE REPLACEMENT OF BATTERY --BACKLIGHT IS NOT WORKING THEN THE PROBLEM MAY BE DUE TO THE DAMAGE OF THE Light is electromagnetic radiation WHICH CAUSE THE BACKLIGHT DISPLAY . THIS CAN'T BE SLOVED BY OURSLEVES SO IT IS GOOD TO APPROACH AN AUTHORISED SERVICE CENTER..I HOPE YOU ARE IN THE WARRANTY PERIOD.
THANK YOU
May 09, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
Just got a nike anvil comold but cant get the backlight to work
I had the same problem. The seller told me to reset the watch by pressing down on all four buttons at once. Sure enough, the backlight function was enabled again.
Feb 14, 2009 | Nike WR0099 017 Mettle Anvil Comold Super...
Casio G-Shock GW-300 2608
Change the battery. This happened with mine along with the battery needing charging more frequently. In my opinion, Casio's assertions that you won't need to change the battery is pretty much of a joke. My jewler concurred.
After changing the battery I can now press the light switch button and the watch works normally.
Tony
Feb 25, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Automatic backlight
PUSH AND HOLD THE MANUAL LIGHT BUTTON, SHOULD CHANGE TO AUTO MODE
Oct 21, 2007 | Casio G-Shock GW500A-1V Wrist Watch
Freestyle Shark Classic Mid Size Watch Logo
Top Freestyle Watches Experts
ray gallant
Are you a Freestyle Watch Expert? Answer questions, earn points and help others
