Question about Ryobi 40-Volt Lithium-Ion Cordless String Trimmer
How do you remove cutting head from a 40 volt ryobi string trimmer? rfarbacher@verizon.net
3 Suggested Answers
SOURCE: Ryobi Electric string trimmer
TJ, I've had the same problem since yesterday and I found the solution (lots of googling - that's how I found your post BTW).
It turned out that the switch malfunction is a common problem.
The part number for the FA3-4 switch is:
ut41002a-36 ("switch assembly")
Available here (thru Amazon):
http://factorylawnandgarden.com/product/553902/B000PLVCX8/SWITCH_ASSEMBLY_UT41002A_36/
It's a Homelite part, which is identical to Ryobi.
Here is the manual showing it (part 6):
http://www.m-and-d.com/pdfs/ryobi_tool/RY41002.pdf
Here is the thread with the solution:
http://www.ryobitools.com/dc/dcboard.php?az=show_topic&forum=112&topic_id=597&mesg_id=597&page=3
HTH,
Adi
Posted on Jun 25, 2008
woobie dog
  • 1273 Answers
SOURCE: how do you remove the head off of a string trimmer
It should pull straight off.
Best regards, --W/D--
Posted on Aug 18, 2009
Ryobie 40 volt lithium cordless trimmer has string jammed under spool head. Now it has stopped working. Please send instructions on how to fix it myself. Thank you, have a good day.
Replacing string in Ryobi 40volt cordless weedwhacker Restringing Ryobi 40v Expand it TrimmerTry and remove bump nut on bottom of cutter head. Try and lift spool out, if it doesn't want to come out take a pair of small side cutters and start cutting string until the head is free. IGod luck
Jul 04, 2017 | Garden
Remove ryobi S430 trimmer head
it has a left hand thread which means that to unscrew it you have to turn it in a clockwise direction like putting a nut on a bolt
Jul 02, 2016 | Ryobi Garden
How to install string for ryobi 50 volt string trimmer
Line Trimmer Line Replacement of a Ryobi One+ 2013 ...
? 2:33
www.youtube.com/watch?v=8jEER8lHUQk
Feb 22, 2013 - Uploaded by TheLegoCityBoys How to replace line in a garden Line Trimmer. ... Ryobi 40-VoltLithium-Ion Cordless String Trimmer RY40210 - Real World Review & How To ...
Aug 08, 2015 | Ryobi Garden
How to replace the spool head
Once you remove the spool cap and the spool, you cannot remove the head from the motor. It is not a replacement part.
Ryobi P2002 Cordless String Trimmer Parts
Aug 31, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Ayrobi 40 volt trimmer
https://www.ryobitools.com/power-tools/support/contact
manuals.ryobitools.com
Aug 14, 2014 | Ryobi 40-Volt Lithium-Ion Cordless String...
How do I get the old line trimmer spool off of my Ryobi 18 volt cordless trimer
When looking at the head, you will see to two gray rectangle pieces. Press them both at the same time between your thumb and forefinger and then pull. It should come unlatched and reveal the line spool on the inside
Jul 25, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Cross section of ryobi 18v trimmer
the wiring maybe disconnected, either at the switch or down near the head of the trimmer
Sep 09, 2012 | Ryobi Lithium Ion 18 Volt 18v Cordless...
HOW DO I INSTALL A NEW STRING IN A PRO CUT 11 for Ryobi RLT30CD trimmer
LINE REPLACEMENT (Fig. 8) (For Reel EasyTM Head) Use 2.4mm monofilament string. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Cut one piece of string approximately 7.6m in length. n Rotate knob on string head until line on knob aligns with arrows on top of string head. n Insert one end of string into eyelet located on the side of the string head and push until string comes out through eyelet on the other side. Continue to push string through the string head until the middle section of the string is inside the string head and string outside the string head is evenly divided on each side. n Rotate the knob counterclockwise on the string head to wind the string. Wind the string until approximately 20cm remains protruding from the string head. INSTALLING STRING IN PRO CUT II STRING HEAD Use monofilament string between 2.4 mm and 2.7 mm diameter. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Gather two of the pre-cut lengths of trimmer line provided or cut two pieces of trimmer line, in 28 cm lengths. n Insert the strings into the slots located on the sides of the string head. String should be pushed in until approximately 2 cm protrudes from the holes on the top of the string head. n Remove old string by pulling it from the holes located on the top of the string head. http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Oct 29, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Replacing the cutting head on Ryobi string trimmer.
There is a nut above the head, place a wrench on the nut then unscrew the head from the shaft, unless yours is different from mine this is how it works. I hope this helps.
Jul 05, 2009 | Garden
Ryobi 40-Volt Lithium-Ion Cordless String Trimmer Logo
98 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
