You do not have permission to modify the settings for this printer
Dell 745 and Dell 755 refurbished, tried to install 3 different printers, 1 parellel, 1 network and kodak wireless. All get the same error when nearly thru installing the CD's "You do not have Permission to modify the settings for this printer. " all ran as user with administrator priv
2 Suggested Answers
  • 110 Answers
SOURCE: No permission to install vista driver for samsung SCX-4100
You need to be logged in as administrator
Posted on Apr 07, 2008
I have an HP 3800 color laser printer. I installed a refurbished toner cartridge today and received a "49.2F05 Service Error" on its display after it completed self calibration. I am assuming it...
A critical firmware error has occurred.
1. Turn the printer off and then on.
2. Try printing a job from a different program. If the job prints, try printing a different file from the original program. If the message appears only with a certain program or print job, contact the software vendor for assistance.
3. If the message persists with different programs and print jobs, disconnect all of the printer cables that connect to the network or the computer.
4. Turn the printer off.
5. Remove all memory DIMMs or thirdparty DIMMs from the printer. (Do not remove the firmware DIMM in the lower slot J1).
6. Remove the printer EIO card.
7. Turn the printer on.
8. If the error does not persist, install each DIMM and EIO device one at a time. Turn the printer off and then on again after installing each device.
9. Replace DIMMs and EIO devices as necessary.
10. Reconnect all of the printer cables.
11. If the error persists, replace the firmware DIMM.
12. Replace the formatter and calibrate the printer.
Jul 16, 2011 | Office Equipment & Supplies
Auto play on Windows XP stopped working.
Follow these steps:
Control Panel/Administrative Tools/Services/Shell Hardware Detection/Return this service to Automatic.
Start/Run/Gpedit.msc/Computer Configuration/Administrative Templates/System. Check your settings in the right pane for Turn Off AutoPlay (and modify).
Start/Run/Regedit
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet\Services\Cdrom. AutoRun = 1
May 23, 2011 | Dell 948 All-In-One InkJet Printer
Stop printing ...Repace toner very soon...If you remove and restore toner it works for a few more pages
You haven't given much information on this, so please answer these questions to get a better feel of what is going on
1) Is this a new toner cartridge that you've installed? 2) Is it a refurbished cartridge? If so, manufacturer or clone? 3) How long has it been in the printer and when did this problem start? 4) Have you tried a different toner cartridge?
It could very well be the cartridge, especially if it is a refurbished/clone (not from the manufacturer)
May 11, 2011 | HP LaserJet P4015 Printer
Printer doesn't work after Canon installed driver for the fax. now the iMac wont read the printer. Replaced the USB cable, tried to download the drivers. NO LUCK
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx300#DriversAndSoftware
Choose your Operating System, and then download the driver for your OS Version, Mac OS X 10.2/10.3/10.4/10.5/10.6
After you install the drivers you should be able to find them manually in System\Library\Extensions or in Library\Printers. Things to try include
1) a different USB port
2) a different USB cable
3) repairing permissions, then shutdown and start up with a printer attached and turned on
4) use a utility program like Xupport to force optimization, then a restart will be required
You could also try using Gutenprint for Mac OS X: http://gimp-print.sourceforge.net/MacOSX.php
Mar 13, 2011 | Canon MX300 Office All-In-One Printer
My Dell aio 926 will not print my tabc cert. That is some kind of acrobat adobe file. As far as I know I have this acrobat adobe thing installed on my pc.
Your pdf file may have its permissions set to disallow printing (!!!). Open the file, click on File menu, then goto Document Properties. Click on the Security tab. Under Restrictions, look at the first one Printing. Off to the right, it should say Allowed. If it doesn't, this is probably your problem, but you would also get an error message about not being able to print.
It could be how the pdf is setup, you can also try saving into a different format (if permissions allow). With document open, goto File, Save As, and specify a different file type (like jpeg or Tiff), enter a file name, and click on save / okay. Then try to print the file that was just created.
Is your printer able to print in/from other programs?
Jun 28, 2010 | Dell 926 All-In-One InkJet Printer
How to change the date in a dell 1600n 3 in 1 printer
Have you tried to connect to the printer with a web browser? There should be a date setting in the web interface.
Jan 15, 2009 | Dell 1600n All-In-One Laser Printer
Ink for Dell Photo924 Printer
Here is a site that has refurbished, guaranteed ink for your printer:
http://www.4inkjets.com/Dell-Ink,Photo-all-in-one,924,Ink-Cartridge,2344,printer.html
Refurbished Alternatives for Dell 924 Ink Cartridges and Printing Supplies Our Alternative Remanufactured Cartridges to replace the Dell OEM cartridges for use in the Dell 924 have a one year 100% quality satisfaction guarantee. These cartridges are not refurbished Dell OEM Cartridges. They are Non-OEM products that have been modified and refurbished by a remanufacturer that is not endorsed or associated with Dell and are guaranteed by 4inkjets.com to work with your Dell 924 Printer. They are a low priced alternative to Dell OEM Cartridges. Our refurbished alternative cartridges to the OEM Inkjet Cartridges are manufactured to the highest performance and quality standards and will deliver optimal prints when used in your Dell 924. Since we import our products directly from the remanufacturers we can pass the savings on to you. copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 28, 2008 | Dell 924 All-in-One InkJet Printer
Trying to set up a network printer with DELL TRUEMIBILE 2350...please help
using windows xp on all the computers, when you connect to the printer windows should automatically install drivers.
1. Goto My Computer, Click My Network Places (Explorer Bar).
2. Click View Workgroup Computers (Explorer Bar)
3. Find the computer that has the printer physically connected to it, open it
4. Find the printer and right click it!
5 Select Connect... and wait for the drivers to install.
this should install the print drivers and install the printer on your computer. the printer should now be available in print dialogs i.e. word etc etc and from the Control Panel > Printers window.
Nov 03, 2007 | Dell Wireless 2350 Router
Says its ready till i try and print
Dell printer drivers try to 'phone home' with Ink usage stats .. even if you select 'no' when asked, they still try to access the Internet ..on install the driver modifies Microsoft Vista Firewall settings to permit this ...
So if you recently installed a non-Microsoft Firewall eg. ZomeAlarm your print driver will be denied access to the web and will refuse to print.
Note that 'deny' is different from 'time-out' ... to test turn off your wireless (or remove the ethernet cable) and ONLY THEN turn off your firewall - if it now starts printing you have your solution (go into Zone Alarm and Enable all Dell & MS print related software access to the Internet).
DO NOT browse the web with your Firewall turned off !!!!
Oct 14, 2007 | Dell Inkjet 720 Printer
196 people viewed this question
k24674
jasbo
jasbo
