Question about Kenmore 22622 Top Load Washer
How do I disconnect the console from the washer body,
THere are no screws on the outside, normally there are two screws one on each side on the front bottom area.
  • 5,911 Answers
Using a putty knife, place under the corner of the console from the front. Pushing straight in, you should feel a retaining clip. Push in to release, while lifting at the same time. The console should pop off. I hope this helps you.
Posted on Aug 08, 2007
How to install a center console on a pacifica
Hi Melissa, I'm glad to help, here is the instruction below I said I'd send. Have an awesome day.
23 - Body/Interior/CONSOLE, Floor, Front/Removal REMOVAL [img id=LOPTableImg src="https://w05.dealerconnect.chrysler.com/service/mds2002/common/images/collapse.gif"> Click to display a list of Labor Operations associated with this procedure 1. Remove shift bezel. (Refer to 23 - Body/Interior/BEZEL, Shifter - Removal) .
2. Remove transmission range indicator surround bezel Figure 1.
3. Remove two screws attaching front floor console to the lower instrument panel Figure 2. 4. Open cup holder and remove two attaching screws to bottom of cup holder. 5. Open bin and remove two attaching screws to bottom of bin. 6. Remove front floor console sidewall attaching screws, three per side. 7. Raise front floor console and disconnect wiring harness. 8. Remove front floor console from vehicle.
374297.jpg Figure 1 - TRANSMISSION RANGE INDICATOR SURROUND BEZEL 1 - INSTRUMENT PANEL 2 - AUTOSTICK SHIFTER ASSEMBLY 3 - TRACTION CONTROL SWITCH 4 - TRANSMISSION RANGE INDICTOR SURROUND BEZEL 5 - KNOB SET SCREW 6 - SHIFTER KNOB 7 - FLOOR SHIFT BEZEL 8 - WIRE CONNECTOR 9 - INSTRUMENT PANEL WIRING HARNESS 10 - INSTRUMENT PANEL WIRING CLIP
374299.jpg Figure 2 - FRONT FLOOR CONSOLE 1 - FORWARD CONSOLE CLOSEOUT PANEL 2 - CLOSEOUT PANEL PUSH PIN RETAINER 3 - INSTRUMENT PANEL WIRING 4 - FLOOR CONSOLE BASE 5 - FRONT FLOOR CONSOLE ATTACHING SCREWS TO LOWER INSTRUMENT PANE AND BASE 6 - FRONT FLOOR CONSOLE WIRING CONNECTOR 7 - FRONT FLOOR CONSOLE 8 - ATTACHING L-BRACKETS
May 17, 2014 | 2006 Chrysler Pacifica
How to remove washer lid to replace lid lock
Remove power to the unit.
Locate the console and remove two phillips head screws. Most
models have them in the front, bottom of the console. In some of the newer models they are located in the back, bottom of the console. Some washers require you to remove two end caps on the console to access the screws.
After you remove the two screws, slide the console slightly forward and then up. The console will then hinge to the back of the washer.
With the console now hinged back, locate the lid switch harness.
Disconnect the harness and check for resistance between the 2 grey wires (outside) on the lid switch connector connected to top of washer. With the lid down the circuit should read no resistance. If the circuit is open(infinite resistance) then the switch needs to be replaced. You can also use a insulated jumper on the lid switch harness to determine if its the switch.
To replace the lid switch you will now have to remove the cabinet. Use a flat head screwdriver to remove the two clips holding the back of the washer to the outer shell of the washer.
Disconnect the lid switch harness(If not still disconnected).
You can now pull the outer shell away from the washer. Do this by
grasping the outer shell (I open the lid and grab it there.) and tilt the shell forward (toward you) and out. The shell is now removed and you can see the tub. Be careful not to bend the outside walls of the shell when removing and setting aside. This will help greatly when reinstalling the shell. Remove the 2 screws attaching switch to cabinet. Remove the screw connecting the ground on the cabinet. Use a flat blade screwdriver to push tabs on lid switch connector block to remove. Finally remove the whole harness from the 2 remaining retainer clips under the cabinet. Install new lid switch harness assembly and reassemble washer.
Apr 09, 2014 | Washing Machines
Water leaking. A small amount of water leaks when
The usual cause of such leak is a damaged or worn drain pump. Replace it to solve the problem. It can be accessed from the back if it is a belt drive machine or from the front if it is a direct drive. Make sure to unplug the machine before servicing.
Cabinet Removal Procedure (Direct Drive machines)
Remove the console depending on the model of your machine.
  1. If the console is secured by screws, simply remove the screws, lift the console up then flip it to the back of the machine. On some models, the screws are hidden under the console's removable end caps. Pull the end caps to the front of the machine to access the screws. If the console is not held by screws, use a putty knife to release the retaining clips under the front corners of the console. Insert the putty knife blade and push it until the clips are released.
  2. Disconnect the lid switch connector from the body of the machine.
  3. The body of the machine is held on to the back panel by two retaining clips. Use a flat blade screw driver and insert it to the lip of the clip and push it to the back of the machine.
  4. Lift the lid and grab the front of the machine's body. Brace the machine's body with your knee, lift and pull it towards you to remove it. You now have the access to the drain pump.
  5. Reinstall the cabinet in reverse order of the procedure above.
For belt drive washers, remove the access panel on the back of the machine to access the drain pump.
Drain Pump Replacement Procedure
  1. Remove the spring clamps that hold the hoses to the pump. Compress the spring clamps and move it away from the pump.
  2. The pump is held on to the motor by two retaining clips. Pry the clips away to remove the pump from the motor.
  3. Remove the hoses from the pump and install the new pump in reverse order of the procedure above.
Jan 20, 2010 | Kenmore 15864/15862 Top Load Washer
Removing the windshield washer reservoir in a 2002 Chrysler T&C
REMOVAL
  1. Disconnect and isolate the battery negative cable.
  2. Remove the engine fresh air housing inside the engine compartment.
  3. Disconnect the washer hose at the in-line connector forward of the cowl grille so that the in-line connector remains with the washer hose from the fresh air plenum.
  4. Disconnect the washer hose from the hose clip located on the front fender side shield.
  5. Remove the filler tube screw.
  6. Hoist and support vehicle on hoist or jack stands.
  7. Remove the right front wheel and tire assembly.
  8. Disconnect the left right front wheelhouse splash shield and move aside.
  9. Drain washer fluid from the reservoir and into a suitable clean container. This can be done by disconnecting the windshield washer hose from the front (outboard) washer pump and allowing the washer fluid to drain into a container through a temporary jumper hose connected to the front washer pump.
  10. Disconnect the electrical body harness connectors to the washer pump motors and the fluid level sensor. Slide the red lock on the connector to the release position, then, depress the black tab and pull the connector off the pump or sensor.
  11. Remove the two reservoir mounting screws.
  12. Disconnect the reservoir from the body mount by raising the reservoir upward slightly and then down so that the reservoir filler neck and front washer hose pull through the opening in the front fender side shield.
INSTALLATION
  1. Push filler neck and front washer hose through the opening in the front fender side shield. Connect the reservoir to the body mount by lowering the reservoir down.
  2. Install the two reservoir mounting screws. Torque screws to 8.5 - 11.3 Nm (75 - 100 in. lbs.) .
  3. Connect the electrical body harness connectors to the washer pump motors and the fluid level sensor. Slide the red lock on the connector to the closed or locked position.
  4. Assure that washer is properly routed to prevent pinching and possible inoperative washers.
  5. Connect the left right front wheelhouse splash shield and move aside.
  6. Install the right front wheel and tire assembly.
  7. lower vehicle from hoist or jack stands.
  8. Install the filler tube screw. Torque screw to 8.5 - 11.3 Nm (75 - 100 in. lbs.) .
  9. Connect the washer hose to the hose clip located on the front fender side shield.
  10. Connect the washer hose at the in-line connector forward of the cowl grille.
  11. Install the engine fresh air housing inside the engine compartment.
  12. Connect the battery negative cable.
  13. Verify system operation.
Apr 01, 2009 | 2002 Chrysler Town & Country
Cabin air filter
it;s under the cowl vent panel.
Cowl Top Vent Panel Removal
  1. Remove the windshield wiper pivot arm (17526) . Refer to Section 01-16 for the removal procedure.
  1. Remove the front door weatherstrip (20530) to access the windshield outside side moulding screws.
  1. Remove the five windshield outside side moulding screws and the windshield outside side moulding (03136) .
  1. Pull the windshield outside moulding (03144) from the windshield glass (03100) .
  1. Remove the three Phillips-head screws from the cowl top vent panel (022A68) .
  1. Remove the three plastic screws by turning them 90 degrees to unlock.
  1. Remove the six pushpins from the front edge of the cowl top vent panel .
  1. Lift up on the cowl top vent panel and disconnect the windshield washer hose (17A605) at the Y-connector.
  1. Remove the cowl top vent panel .
Mar 15, 2009 | 1998 Mercury Villager
Replacing my washer lid assembly.
If your washer is a kenmore /whirlpool then you need to flip up the control panel after removing screws on either side of the console. Some models have plastic shoulders that hide the screws some have the screws int he read. Flip up the console and unplug the lid switch quick connect. Pop the 2 clips on the rear of the washer and tip the body foward.
On a GE you get the front panel off by compressing spring clips between the top and front. then remove screws from the facing that hold down the top. You will then wiggle out the top and unplug the disconnect. On a maytag washer you remove the control console to get to the lid switch.
Dec 17, 2008 | Washing Machines
Washer repair
on rear of console remove the 2 screws 1 on each corner..console lifts and rolls backif switch on right under lid remove clips on each side cabinet then lifts from back to front and lifts off if switch ic under left side of lid at rear make sure hinge scres are tight on left hinge and lid hinge is striking switch solid if not push hinge at curved section toward back of washer
Jun 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
How do I remove the cabinet on a Kenmore Model 11022882101 top loading washer?
You need to remove 2 screws in console. They might be in back, on ends or in front ends. If you can't see any, they are under the console end caps. To remove end caps, pry off by pulling caps towards outside from center part of cap. Pry toward you and towards outside. Then remove 2 screws and flip console up and back. Unplug connector to washer cabinet. Remove 2 gold colored clips by inserting straight screwdriver in them and prying back. Make not of their position first. Now tilt cabinet toward you and slide forward and off base.
To replace, tilt cabinet and slide under frame in front. Now lower cabinet on to frame, making sure cabinet is on frame on sides. Re-install clips by placing them in position and pushing down with palm of hand. Plug in connector, lower console and install screws.
Nov 21, 2007 | Washing Machines
Cannot open washer and remove console
The console should come off by placing a putty knife under the front corner of the console. Push straight in, while lifting up. The console should pop off exposing two brass colored clips that hold the main body on. Remove the clips and the whole casing should come off the frame. I hope this helps you.
Aug 08, 2007 | Kenmore 22622 Top Load Washer
Kenmore 22622 Top Load Washer Logo
20 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
