Question about Edimax BR-6228nS 150Mbps 11n Wirless BroadBand Router/4 Ports Switch
Wireless g router 8 digit pin - Edimax BR-6228nS 150Mbps 11n Wirless BroadBand Router/4 Ports Switch
  • Edimax Master
  • 2,219 Answers
There is a 8 digit pin number on the back of the router.
Windows 7 however has a problem and there is a solution here. http://www.edimax.us/html/Faq/PIN%20code%20not%20existed%20on%20the%20router.pdf
Posted on Mar 03, 2015
Where do I find 8 digit pin number for RTA1025WE router so we can use a Wireless N Nano USB Adapter
There are two ways to do a setup for a wireless adapter:
* use an Ethernet cable to connect a computer to one of the LAN ports on the router; login to the router; and set the SSID (the name you are choosing for your wireless network). Then, put that Nano USB adapter into the computer, and it should load the device-drivers, and eventually will ask for the name of the SSID. Then, you can disconnect the Ethernet cable, and use the wireless connection;
* as you have discovered, some routers have (and some do not have) an 8-digit 'PIN' number.
Feb 02, 2015 | D-Link Computers & Internet
I am trying to connect my new wifi ext bt600 with no wps button on my router
Since your router does not have a WPS button, it is likely it uses a 9-digit pin number for WPS. The pin number should be on a sticker on the router or maybe in the router's setup guide.
Sep 19, 2014 | Computers & Internet
Router 8 digit pin number
go into the router page at: http://192.168.1.1 or http://192.168.0.1 or http://192.168.2.1 login then go to wps, thats the 8 digit pin. You can hack it using a rtl8187 wifi adapter, linux, aircrack-ng, and reaver-wps to crack the pin but it will take 6-8 hours from what I've read.
Nov 03, 2013 | D-Link Xtreme N DIR-655 Wireless Router
You need to make sure the password you are entering is entered correctly. Check for upper and lower case letters and to check it you should be able to find it on the underside of the router.
Aug 18, 2013 | Acer Computers & Internet
I need an 8 digit pin number for my wpn824 wireless router. I am trying to set up Web disk. There is no 8 digit pin number on the router or the packaging.
the 8 digit pin is usually located on the sticker under the router. it is labeled as security pin. or anything that is related to that phrase.
Aug 25, 2011 | NetGear WPN824 108Mpbs Wireless Router _...
Where is the 8 digit pin located on the modem in order to set up a wireless connection?
Hi, the 8 digit pin is indicated on the serial sticker of the router. Just look at the bottom part of the router. and you should see the pin numbers.
Thank you for using Fixya, your recommendation is highly appreciated for the free support.
Jul 21, 2011 | Computers & Internet
The internet guy was just here today in my new place but i wasn't here with him.To connect to the internet it is asking for a 8 digit pin code located on the bottom of the router. I can seee several...
When you say, "IT is asking for..." exactly what is "it?"
It sounds to me like you have a Linksys wireless interface (possibly USB) on your PC which assumes it is going to connect to a Linksys router, which would have that PIN code on it... but you don't own a Linksys router and therefore the whole PIN code protocol is futile.
Bypass the proprietary PIN code nonsense and enter the WEP or WPA password the installer gave you (if any; it's possible he didn't set any) to connect to your access point from your PC.
Nov 01, 2010 | Linksys Wireless-G WRT54G Router
I have two laptops and want to set up a wireless network. I have the wireless set up but it isn't secure. When I go in to the Homegroups page it asks me for a 4 or 8 digit PIN number found on the router....
If you don't know it, you won't be able to automate your Wifi Protected Setup (WPS). The pin is a very specific way to prevent yourself from always having to remember codes, keys, passphrases, etc. Without it, its like saying that you want to to connect to Bank of America, and that it's just okay because you want it to happen.
The following is taken from the ESR-9753 manual:
- Wi-Fi Protected Setup (WPS)
WPS is the simplest way to establish a connection between the wireless clients
and the wireless router. You don’t have to select the encryption mode and fill in a
long encryption passphrase every time when you try to setup a wireless
connection. You only need to press a button on both wireless client and wireless
router, and the WPS will do the rest for you.
The wireless router supports two types of WPS: WPS via Push Button and
WPS via PIN code. If you want to use the Push Button, you have to push a
specific button on the wireless client or in the utility of the wireless client to start
the WPS mode, and switch the wireless router to WPS mode. You can simply
push the WPS button of the wireless router, or click the ‘Start to Process’ button
in the web configuration interface. If you want to use the PIN code, you have to
know the PIN code of the wireless client and switch it to WPS mode, then fill-in
the PIN code of the wireless client through the web configuration interface of the
wireless router.
Jun 28, 2010 | EnGenius ESR-9753 SOHO Wireless Broadband...
Edimax BR-6228nS 150Mbps 11n Wirless BroadBand Router/4 Ports Switch Logo
109 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
