Question about Santa Fe Classic Dehumidifier
Classic dehumidifier M#3824-525
How do I get my classic dehumidifier into dehumidifier mode?Just bought it today,instructions does not tell me how??
I have a Danby which has the feature for heat on the left-hand side. I just bought it a month ago, but can't lay my hands on the instruction book right now. Can you tell me the proper procedure for...
Lori, the Danby Humidifier, Model # DDR2504 does not have a heating function. It's just a 25 pint dehumidifier. In fact, there are no Danby Dehumidifiers that have a heating function.
By, chance do you have Multifunction Air Conditioning unit, rather than a dehumidifier? If so, please provide the correct model number.
Thanks for choosing FixYa.
Sep 11, 2011 | Danby DDR2504 Dehumidifier
Classic dehumidifier cdr4500e blowing hot air
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 12, 2011 | Danby DDR2509EE Dehumidifier
Have a kenmore dehumidifier 42-54501 - I bought it w/o instruction book. Can you tell me where to get instruction book??? Thank You
Since it's a Kenmore ( a Sears house brand) that was made by Whirlpool. You can download the Owner's Manual at Sears Parts Direct or Sears Parts Central.
Hope this helped you, Joe.
Jun 05, 2011 | Kenmore 54501 Dehumidifier
No water in Dehumidifier
1) low outside temp means low inside humidity
2) If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 20, 2009 | Dehumidifiers
No water is collected.
Return the unit, it is obviously faulty, & Kenmore stands behind their products very well.
Jul 01, 2007 | Kenmore 54501 Dehumidifier
No instructions
only two fan speed - fast or slows. use fast humidity - cuts out appliance when required humidity is reached. set it about half way note that is f bucket if full, then a float switch will cut out the appliance
May 21, 2007 | Ebac HD880 Dehumidifier
Santa Fe Classic Dehumidifier Logo
232 people viewed this question
Top Santa Fe Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Santa Fe Dehumidifier Expert? Answer questions, earn points and help others
