Question about Magnum Fitness Commercial Grade Treadmill-220V
Magnum t 111 tread mill - error "belt over speed error and it shuts down" tried replacing motor-board with capacitors on it - nothing has fixed it yet
EPIC 400 tread mill starts but slows down &blows breaker moter run fine with no load belt backed off re set speed sensor changed power cord pluged .in to circit board ran fine for 2 hrs then stoped
motor brushes are bad. when they wear out, the motor loses torque and draws more amps. they can be replaced fairly easily once you get the motors out.
Oct 03, 2015 | Epic 400 Mx Treadmill
Turn tread mill on. counts 3 seconds and the belt does not move. the console goes blank after 8 seconds then e1 flashes.
follow this steps and fix it. See the diagram attached. God bless you
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.6698c5a0-3470-4d34-bd47-9422824cf011.gif
Of course you must lube the deck belt. see the video attached.
Sep 20, 2013 | Exercise & Fitness
Tread mill turns on, belts barely moves the shuts off
see the video and proceed according. God bless you
LUBE the rollers bearings too.
3) Test the drive motor, if there are voltage the motor need repair, see my personal TIPS for motor help
4) test the output voltage board, for input voltage motor, if there are NOT the board is faulty, see the b.diagram attached
God bless you
Dec 10, 2012 | Exercise & Fitness
I have the Ifit tread mill not sure what model, but when you Are running or walking on it and put your foot down it will pause. What can I do to fix this problem?
This happen because the lack of maintenance LUBE. Now you need to lube the deck belt, probably you have WORN deck belt.
2) LUBE the rollers bearing too.
3) Test the drive belt motor, for worn, crack or adjust if possible.
4) Test the input voltage motor, if there are the Motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 28, 2012 | Exercise & Fitness
What's your problem?tread mill stop working belt stopped turning
Dear Sir:
Hello I hope you are o.k
After Reading your problem, I will help you please follow the next step:
Your problema is Electrical:
If you can walk on your treadmill but it shuts down during a workout, it is normally caused by a friction problem with the belt and deck.
Here are the most common symptoms and solutions:
If you have questions, email us at doc@treadmilldoctor.com
Symptom: The treadmill operates for a given period of time and the circuit breaker on the treadmill (if
equipped) trips causing you to have to reset the breaker, or let it cool off then reset the breaker. The
amount of time required to shut down will progressively get shorter.
Solution: The walking belt is worn. The incline test is the best test for it if you don't have a way to take a
DC amp draw. Put the treadmill at full incline and walk normally. If it takes it longer to shut off or does not
shut off at all, you need to replace the walking belt. Be sure to inspect the deck for wear too. If you want to
go for a cheap fix (that we don't recommend) try lubricating the walking belt. The best fix is to replace the
walking belt and then regularly maintain it and keep the treadmill clean.
Symptom: The treadmill will show power but after a given period of time, the treadmill will simply shut
down. Once you let it cool off, you can restart it back up but it shuts down faster and the time required
before it shuts down gets progressively shorter.
Solution: Your treadmill is most likely equipped with a heat sensor which shuts down the motor and/or
electronics to prevent them from burning up. If this is the case, replace the walking belt. Be sure to inspect
the deck for wear too. If you want to go for a cheap fix (that we don't recommend) try lubricating the walking
belt. The best fix is to replace the walking belt and then regularly maintain it and keep the treadmill clean.
Symptom: The treadmill shuts down in an intermittent pattern...there is no rhyme or reason to when it will
shut down. I get an error code or nothing shows up on the panel. I have to either unplug the treadmill or
reset it to restart the treadmill.
Solution: If you get an error code, contact me with the code and make and model and we will try to help
you figure out what is going on. Typically we either find a loose wire, an intermittent short, a bad power
board, or a bad control panel . Unplug your treadmill and then check all
your wiring to make sure nothing is pinched, crimped or loose. Remove and replace each connector in
case corrosion is causing the problem. If the problem persists, you most likely have a bad control panel or a console.
Thank you in advance, sincerely. Blessing.
If you need additional Help, please contact us.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 28, 2011 | Exercise & Fitness
My matrix MX-T5x start running and stop in seconds. With the error code E7. What is the problem ?
By E7 it means Speed sensor feedback missing. You have to check the speed sensor mounted near the motor pully. Remove the speed sensor and clean it well Then refix it then check the tread mill by powering ON. If then also the problem remains the same , You have to replace the speed sensor.
ok
Aug 02, 2011 | Matrix MXT5 Treadmill
My tread mill looses speed during my workout. the
If you haven't adjusted the belt refer to your owners manual for the proper procedure if you still have the same results then it could be caused by a lack of lubrication under belt or a worn belt.
Apr 10, 2010 | Proform Exercise & Fitness
Error codes
error 1 is many times a speed sensor error. Make sure the speed sensor is in place, working and sending signal to the motor control board.
Jan 03, 2009 | Exercise & Fitness
Magnum Fitness  Commercial Grade Treadmill-220V Logo
32 people viewed this question
Top Magnum Fitness Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Magnum Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
