Question about Proview PL926WBi 19" LCD Monitor
Driver monitor preview fv926w - Proview PL926WBi 19" LCD Monitor
Where can I find driver?
Normally I go to the manufacturer website for the device I need a driver for. They have the updated drivers and are usually tested.
Nov 23, 2011 | Computers & Internet
Hi, I have a 22" monitor with upper left square segment is lit differently. Do I have a bad driver in the monitor?
Go into settings on the monitor itself. It's some type of preview pane. I've seen it when playing with the settings. Just play with the displays settings til you find the one that makes it go away. I would tell you where that is but my monitor is not connected. Here looking for a problem cause my AOC 22 keeps blinking off. Good luck.
Nov 01, 2009 | AOC Monitor
Darker fatter letters every 2 inches apart from top to bottom
it is called phase you can attempt to let the lcd monitor auto set or you can disconnect the power over night then plug in and then do not auto set this default usually seems best some times
Nov 29, 2008 | Proview PL926WBi 19" LCD Monitor
Streaks make letters fatter every 2 inches apart across screen
this is called phase it can be set auto by the button or you can disconnect the power and next day reconnect and leave it in default which can be better than letting the monitor try to set the phase.
LCD display Proview
If the screen is pinkish chances are the panel is defective.Should follow-up with Company Proview and do some correspondence.
Samir
May 23, 2008 | Proview PL926WBi 19" LCD Monitor
19 inch wide Tftlcd monitor FV926w comes on then goes black
There is power problem in your monitor maybe in the high voltage section. maybe there is capacitor that leaky that cannot hold the power. Need to bring this to the expert technician to fix it
Apr 15, 2008 | X2Gen MG19MY 19" LCD Monitor
Print is right when preview is very magenta (like 40 pts magenta)
This sounds like a calibration problem. The first thing I would try is to un-install the driver, download the latest drivers from the manufacturer's website then reinstall the new software.
I'm not familiar with the drivers of this printer but look to see if there is a printer/monitor calibration area try the settings there.
The other obvious place to look in is the software you are printing from. Try printer/Monitor calibration in the help menu
Jan 24, 2008 | Epson Stylus 2200 InkJet Photo Printer
Screen goes dark
it indictes problem with ur crt tube in monitir
Dec 02, 2007 | Proview PL926WBi 19" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
107 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
