Question about Sekonda Brown Leather Watch Brown
Putting back on watch - Sekonda Brown Leather Watch Brown
Why does the top left button on my remote glow and why are the other buttons on my remote not working?
The remote control need cleaning. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
https://www.youtube.com/watch?v=F8oYoZslgbs LG Remote control - Open - Search [How to open LG Remote control]
https://www.youtube.com/watch?v=do41DlsZHmA [ open, battery change Toshiba]
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Jan 17, 2016 | Televison & Video
How to re-close the back plate on a Dakota time/date warch?
Some of these watches have a notch where the stem goes. If you don't have the back in place it will not snap back into place. Also some are a slight screw back and will snap off, but when putting them back you must kind of screw it back in place. Good luck.
Jan 28, 2015 | Dakota Watches
Putting the back of my watch on after changing the battery
Hi Ken,
Some watches require even pressure all the way around the back at the same time to get it to pop on! You will need to have this done at a jewelry store or watch repair shop. Thank you! Lisa
Nov 07, 2013 | Watches
Can't press the back of the watch back on after replacing the battery - Do I need a jewelers press?
A jeweler's press provides an equal amount of force around the edges of the watch back without putting that same pressure on the watch crystal (which could cause it to crack or break). If you have a flat crystal, you might have success in putting the watch between two pieces of wood and using a regular vice to very gently push the front and back together. However, you risk doing damage to your watch crystal.
Your safest bet may be to go to a jewelry store or jewelry counter in a department store and ask if they could close the back for you with the proper tool. You may have to tip them a few dollars, but that is still far cheaper than the cost of replacing a broken watch crystal.
May 05, 2011 | Timex 27191 Wristwatch
I have a lorus mickey mouse watch just replace battery having trouble with putting the back cover back on..
You may need to have a local jeweler who has a watch press to put it back on, If you put to much pressure on the inside of the back, it may be warped. A knowledgeable jeweler should be able to fix that issue also.
Thank you for contacting FixYa..
Jewel
Aug 31, 2010 | Watches
Putting back on timex watch
There is a press to put this back on.
RECOMENDATION:
Seek professional help.
GOTO
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 11, 2010 | Bulova Watch
Remove the back of my freestyle cortez
Try putting your watch in a warm dry place to see if the cloudiness goes away.
If not take it to a watch repairer, as removing the mechanism (required to gain access to the crystal) can sometimes be trickier than it would appear.
Replacing the back seems to cause problems and if your watch is sealed, it can be extra troublesome.
Feb 16, 2010 | Freestyle Cortez All Ana Digi 78611 Watch...
I also cannot get the watch back cover to go back on.
Place the watch face down on a cloth, on a firm surface such as a table. find something the same diameter as the watch back and press firmly. Agentle tap may help
Jun 19, 2009 | Tissot T-Touch T33759851
Battery Number for Citizen Diver's Watch
Energizer 371/370 It uses 3 of them. Careful when opening. Make sure you put the screws back tightly. unit has a gasket. lightly treat with vasline before putting back gasket and screwing cover on.
May 03, 2009 | Citizen Aqualand Duplex JP104009E Wrist...
Sekonda Brown Leather Watch Brown Logo
675 people viewed this question
Top Sekonda Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Sekonda Health and Beauty Expert? Answer questions, earn points and help others
