Question about Garden
Magna rototiller 500344 - Garden
I have a 1969 Cub Cadet 127 with a rototiller, and it loses power and stops spinning each time I lower the rototiller in the garden. I cleaned the rototiller and belts look good. Help!
You may have wear on the pressure plate and sometimes you can adjust the turnbuckle on the clutch rod and that will take care of the problem. If that doesn't help you may need to replace the pressure plate. Cub Cadet part # IH-473471-R1.... Hope this will help you.
May 23, 2017 | Cub Cadet Garden
I need a parts manual for a earthquake model 5020 rear tine rototiller
contact the manufacturer on the net and look for a pdf version if available.
Jun 17, 2015 | Ardisam 5.5 Hp Rear Tine Rototiller
What replacement engine would I need for my John Deere 624 Rototiller?
I go with the same motor. I wound try e-bay.
Apr 25, 2014 | Garden
Earthquake rototiller won't disengage
the tensioner is to tight and belt stays engaged loosen the tension below the handle
Apr 04, 2014 | Earthquake 6015V Rear Tine Rototiller
How do you start the Huskee Rototiller 190CC? My
Yes, the engine is identical to the ones used on several lawnmowers and the safety bar must be held in against the handle to enable it to start. Releasing it while running will kill the engine.
Apr 11, 2011 | Mtd Products Yard Machines 158CC Tiller
Broken rototiller
take the gear box is not in a bind.
Jun 11, 2009 | Garden
We require help with a broken belt on the rototiller
bring the broken belt to napa auto parts or kragen ,,or go to www.managemyhome.com they can tell you where to buy or get it
May 20, 2009 | Garden
Craftsman rototiller 3 5 model 917 299130 leaks
Sounds like you are speaking of the float bowl.
It should not have a hole in it.
You could purchase the part from Sears or a small engine shop.
If it were mine, I'd remove the bowl, clean it, and patch with a gasoline impervious material such as JB weld.
Apr 05, 2009 | Craftsman Garden
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
