Thermador RDDS30 Dual Fuel  Kitchen Range
Problem for Thermador RDDS30 Dual Fuel (Electric and Gas) Kitchen...
Taking a long time to heat up
By bill581 on Mar 14, 2009
It takes 20- 30 minutes to pre-heat oven to 350 degrees
Best Solution
posted on Mar 15, 2009
Very Helpful)
gilles_dumai
Rank: Wiz
Rating: 82%, 38 votes
sound like you may have a burnt fuse causing to run on half voltage check your fuses thanks from gilles
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Thermador RDDS30 Dual Fuel
Questions and Unsolved Problems for Thermador RDDS30 Dual Fuel
Do you recommend Thermador RDDS30 Dual Fuel (Electric and Gas) Kitchen Range?
Answer
Answer
Our Thermador rdds30vrs oven suddenly stopped working. The whole electrical display is black, no... (More)
Answer
Temperatur display on the control panel became dim, I cannot read it, repair is possible or I need... (More)
Answer
RDSS30 - Bottom heat element in oven will not heat up. Top element is working so there is electric... (More)
Answer
oven cleaning does not work because oven door will not lock. Turned the clean cycle on and the door... (More)
Answer
I'm having trouble with the left hand burners. The left rear one does not spark at all and the left... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Kitchen Ranges Experts
Top Range & Oven Repair
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
