Question about LG VX6100 Cellular Phone
LG VX6100 blank screen
Phone #1. Screen is on (white) but is blank. Which module screen or logic bd? Phone#2. Screen is on and scrambled. Which module, screen or logic bd?
  • 44 Answers
SOURCE: LG VX8600 SCREEN WENT BLANK, PLZ HELP!!!
m8 sounds like your screen is faulty or your ribbon has been damaged in some way.to fix it you will need to open it and have a look at the ribbon if there is any damage vissible no matter how small it means ur ribbon is gone an you need a new 1.it could also be your screen if there isnt any damage on the ribbon then it could be the screen.it could be a combination of both. word of caution: if you try to open it yourself you could damage the ribbon.you wont notice it but its very easy to do.so be carefull. but if you want an expert to do it for try these guys http://www.mobilephoneservicecentre.co.uk/ good luck
Posted on Jun 27, 2007
  • 4 Answers
SOURCE: Flashing blank screen
If your phone is less then a year old bring it to a store that is owned by Verizon. You could also call 1-800-256-4646, then ask for the FRU (Factory Replacement Unit) department. They will get you a replacement phone.
Posted on Sep 08, 2007
Bajanguru
  • 7752 Answers
SOURCE: Verizon LG CHOCOLATE Phone
okay all of you take the phone to a mobile service center and have the flexcable replaced, this will correct the white screen issues.
Posted on Feb 28, 2008
SOURCE: LG CHOCO BLINKS WHITE
It is the ribbon cable
Common flaw with the slider mechanism rubbing the cable too much.
This will fix prettymuch all display problems not involving software problems.
Posted on Apr 04, 2009
SOURCE: my lg shine screen has gone blank
Change the Battery
Posted on Oct 25, 2009
My grandmothers lg vx6100 sometimes has a white screen. When this happens you can only receive calls.You can't make calls or change settings. Today the display looks like the attached pic. She is 102 and...
Take it to a phone repair shop. I think it just needs to have the contacts cleaned that join the circuit board to the screen.
And way to go for being 102! :>)
Feb 24, 2018 | LG Cell Phones
Lg vx6100 won't turn on or charge
There may be liquid damage present. First using a flashlight, inspect the battery contacts and data/charging socket for green mold/water damage. If nothing unusual is discovered you could disassemble and inspect the inner circuit boards for white residue that would be left behind from water calcium, clean the calcium from the circuit board with a slightly wet toothbrush and dry with compressed air or a hair dryer.
Dec 22, 2013 | LG VX8300 Cellular Phone
I have had my LG ks360 for just over a month now and it has not been dropped but the screen is blank and will not come on..Is there anything i can do to fix this problem?
I've had a similar problem. I lost half my screen and the other was scrambled...
My suggestions is to..
1. Take the battery out and put it back in
2. Leave it for a while
3. Charge it
If none of those seem to work.. Then you may have to consider getting a new phone. I know that if you do live in the Uk you can take it back to the store and ask for another.. Because that's clearly a fault...
Thats what I did and they replaced my phone.
Aug 25, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Vx6100 verizon phone screen white after charging
open the back cover of the phone and reconnect the flex to the pcb.
Jun 25, 2009 | LG VX6100 Cellular Phone
Black screen/no signs of life
NO THE PHONE SHOULD POWER RIGHT UP... THERE IS NO SPECIAL PROCEDURE TO GET THE PHONE TO TURN ON....... AS LONG AS THE PHONE HAS A CHARGED BATT THEN YOU SHOULD BE ABLE TO TURN IT ON... I WOULD SAY THAT YOU HAVE A DAMAGED PHONE AND IF AT ALL POSSIBLE I WOULD SEND IT BACK TO WHERE I GOT IT IF ITS A REFURB MOD...THANKS
May 24, 2009 | LG VX6100 Cellular Phone
LG VX6100
I was able to get mine to work for about ten to thirty mins with a new battery and using a toothpick to spread the charger port parts. The flat one with two notchs away from the black with the gold contacts. GENTLY press toothpick (nonconductive) against the two notchs part and GENTLY wiggle it away from the other. It took 5 snatch sessions to get all my stuff off. I used the battery that came with my LGvx8100 as they are the same. DO NOT CHARGE THE new BATTERY IN THE 6100.
Oct 01, 2008 | LG VX6100 Cellular Phone
SCREEN IS BLANK
I know this sounds crazy but it works Put the cell in the freezer without any leather case for 10 to 15 minutes this will give you around 5 minutes to get into the stored memory and retrieve your stored data if 15 doesn't work I have gone up to an hour don't worry these phones are very durable people use them in sub zero temps with no problem good luck !
May 27, 2008 | LG VX6100 Cellular Phone
My screen is blank it doesn't show anything
If it is a recent purchased phone, it would be best to leave it on charge for a while, after which you can switch the power button on. This should enable you to use your phone, hassle free.
Apr 20, 2008 | LG VX6100 Cellular Phone
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
LG VX6100 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
