Question about Garden
Craftsman dlt 3000 engine chokes when blade engaged or put into gear.
Engine starts and idles smoothly in neutral. Engine dies when placed in gear or cutting blade engaged. Fuel and air filter has been replaced.Thanks for any advice.
  • 79 Answers
SOURCE: 18 hp craftsman 2 44 inch cut engine dies when blades engage.
HI
Check wires going to safety switch under seat.
Posted on Apr 07, 2009
GM Elec
  • 1000 Answers
SOURCE: Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
Posted on May 10, 2009
backwoodsctr
  • 169 Answers
SOURCE: DLT 3000 Intek 18.5 Carb Float Stuck?
If it starts cold and runs for 10 min then it sounds like the fuel cap is not venting properly, try runnin engine with fuel cap loose and see if it dies. 9 times out of 10 the fuel cap is the culprit. Let me know
Posted on Nov 30, 2009
  • 19 Answers
SOURCE: Craftsman DLT 3000 18.5HP - Engine Dies
sounds like the choke mechanism is stuck in closed position, causing a overly rich mixture, to check this removethe air filter cover, element and housing, there are two nuts and a 5/16 head screw somewhere that need to come off too, then pull off housing and you will be able to see the choke plate, it should only be closed when throttle lever is all the way up. when you determine if this is the pronlem or not you can email me if you want
thisoldtruck2@yahoo.com
Posted on May 18, 2010
  • 4 Answers
SOURCE: stalls when put in gear or engage mower
had same problem is safety switch by the deck causing your problem jump it or replace it
Posted on Jul 25, 2010
Zero turn mower is sputtering and dies
Check everything is clean. Check the air filter is clean, check that the engine cooling fan, cutting blades and cutting deck are free of grass. Check all the drive belt pulleys to ensure accumulated grass is not jamming anything. Check the fuel filler cap is clean and the breather hole works.
Jun 27, 2013 | Husqvarna Zero Turn Mower Z5426
My 94 full size blazer starts and idles fine in park and in neutral. When I put the truck in gear and hit the gas, it'll start, then act like it wants to die. The Catalytic converter is off, I'
yes try getting the fuel pump pressure tested by a mechanic. the other thing it can be is the injectors are plugged try running some lucas fuel system cleaner.
Jan 19, 2013 | Chevrolet 1500 Cars & Trucks
Why does engine speed decrease when blades are engaged?
need to clean grass from under mower change plug and air filter for better perfomance
Jun 15, 2012 | Garden
Engine dies when when you engage mower or gear
First I would check that the air filter is not stopped up. Second I would clean the carb very well as I believe the high speed circuit in your carb is obstructed. The mower will idle on the low speed circuit but I think it is getting insufficient fuel when you load it. This is where the high speed circuit comes in to allow the additional fuel for higher demand operations like moving in gear and especially the blades.
I hope that this helps.
Jul 15, 2011 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Have sx75 and starts fine. After about twenty min it starts to cut out and die. Almost like it is vapor locking. Wrapped fuel line with aluminum but didn?t help. Installed new plug and cleaned all...
Try this.
When the machine begins to stall, immediately loosen the gas cap.
If this works, drill out the vent holes on the cap.
Please post back to let me know if this works.
Gary
Mar 08, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Craftsman 42 in. deck lawn tractor. Will start and idle fine but when you let out on the clutch the motor bogs down and dies
few reasons will try to narrow down first start it and put in neutral and deck disengaged release clutch if bogs then fuel problem the carb may need adjustment or repair or fuel filter needs replacement----if no bog step on clutch no put in gear release clutch if bogs check drive belt -upper belt on engine pulley and check for binding an idler pulley problem -debris -or rear unit binding -needs service-drive pulley damaged-rear locked--if not bogging in gear step on clutch engage deck release clutch if bogs need to check deck -belts-pulleys -mandrels -bearings and for bent or binding blades good luck
Mar 10, 2010 | Craftsman Garden
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
